Question about Dishwashers
No kinks in the line. Vent at sink is clear. Will pump some water just not all of it. Pulled left side panel off and removed hoses-no blockage. Pulled drain hose off and turned plump on, seemed to have good pressure/volume. Is this a timer issue? or control panel? Model SHU4022UC/U06
  • 1 more comment
  • alaskatim Jul 19, 2009
    This is a draining problem not filling. Sorry if I didn't make that clear.
    Screen is clear. I removed the drain hose and turned the cycle knob to a drain position. The pump pushed plenty of water with pressure.
    Thanks I'll get the part ordered.
  • 3,037 Answers
Alright, so you have a Slow Filling Dishwasher. In order to keep small particles of dirt and minerals out of the pumps and nozzles of dishwashers, manufacturers install a small screen in the primary inlet water line to trap any contaminants. Over time these screens become clogged and limit the amount of water entering the dishwasher, hence the dishwasher fills slower than it did when new. This applies to both portable and fixed dishwashers.
Cleaning the screen should rectify the problem.
1.
Turn off the power using the appropriate method;
shut off the appropriate breaker at the main electrical panel, or
remove the fuse from the fuse panel, or
unplug the dishwasher.
2.
Turn off the water supply valve to the dishwasher (usually located under the sink), or disconnect hoses from the faucet.
3.
Below the dishwasher door is a panel. The panel is either held in position with screws and is removable or is hinged to allow it to fold downwards. Remove or open the panel. This panel provides access to most of the dishwasher components.
4.
Installed in the front area of the opening will be an inlet valve, see Figure 1. This is where the incoming water supply to the dishwasher is automatically turned on and off depending on the dishwasher's working cycle. Each manufacturer's inlet valve looks somewhat different (a sketch of a basic unit is shown), and the mounting configuration could place the outlet on the top or side, however you should be able to identify the unit, quite easily.
Location of dishwasher inlet valve
Figure 1 - Location of dishwasher inlet valve
Hex fitting at end of incoming water line to dishwasher
Figure 2 - Hex fitting at end of incoming water line to dishwasher
5.
Newer dishwasher installations will have copper piping or a flexible armored hose connected to the inlet valve, while older units will have a rubber hose. Most will be connected using a hex fitting, as shown in Figure 2. Using a wrench, or pliers loosen the fitting and pull the pipe or hose away from the inlet valve:
NOTE 1: There will be water in the line and it will most likely spill out when the hex fitting is released. It is wise to have a large sponge and some rags available to pick-up the spilled water to avoid any damage.
NOTE 2: In order to undo the hex fitting it may be necessary to remove the wires that supply power to the inlet valve. In most cases the wires are connected to the inlet valve using quick connect terminals. To remove the wires use a pair of needle nose pliers and pull on the connector that is attached to the end of the wire. DO NOT pull on the wire itself as it is more than likely that you will pull the wire out of the connector. Identify which wire goes to which terminal before removing the wires.
6.
The filtering screen will be located in one of two places:
Inside the hex connector of the incoming hot water line, or
Inside of the male threaded connector attached to the inlet valve where the hex connector screws too.
7.
Using a small flat head screwdriver remove the screen from its location. Remember which side of the screen was on the inside.
8.
Clean the screen under running water using a soft brush and dish washing soap. If necessary you can use products such as CLR or vinegar to remove calcium or other minerals.
9.
Prior to replacing the screen in either the hose or inlet valve Inspect the insides of both fittings to ensure that no dirt or grime came off during the removal of the screen. Clean away any debris that may be present.
10.
Replace the screen, making sure it is installed in the correct direction.
11.
Replace the hose or copper pipe connection and tighten the fitting.
12.
Turn the hot water shut off valve on until you hear water flow, check the fitting and ensure it is not leaking.
13.
Replace the wires to the inlet valve (if they were removed), making sure that each wire is connected to the correct terminal.
14.
Open the hot water shut off valve all the way and again look for leaks.
15.
Replace the removable panel or raise the hinged panel as the case may be.
16.
Turn the power back on to the dishwasher.
Let me know how this turns out
Benjamin
Posted on Jul 19, 2009
  • Benjamin Patri
    Benjamin Patri Jul 19, 2009
    There is still a screen for the drain, The above apply for both incoming and outgoing water
  • Benjamin Patri
    Does this happen on all cycles that you run? If so, then the next thing would be the control panel that sounds like it is the problem and isn't leaving enough time for some reason. You can get a new one from repairclinic.com and if replacing it doesn't work, then return it within 30 days.
4000 series
There is some blockage in the pump unit and will need to be opened.
Usually the impeller is stuck or there is a blockage.
Will look something like the part on this link.
Drain Motor Assembly
Aug 02, 2014 | Bosch Dishwashers
General Electric dishwasher model potscrubber 1410 will not pump out final rinse water
So due to this water is still left in the bottom correct? you would have to remove the drain line where it connects into the sink area and also check inside the hole that the hose connects into the sink for any blockages if there are none found here then you would deinstall the dishwasher pull the unit out and check where the drain line connects to the pump. If you also found nothing in the other end of the line then you would disconnect the pump and assure nothing is stuck in the pump and that the impellar can spin freely. lastly you would reassemble the pump and drain hose but you would drain the unit into a bucket and still have the unit pulled out then start the dishwasher and assure there are no leaks. IF you have any further questions message me back Thanks Rick
Sep 25, 2011 | Dishwashers
Lights are flashing with OE flashing stopped washing
OE is a drainage problem. Check all lines, and drains for kinks.blockage. Ours was blocked in the T connection where the drain goes into the sink( in the black ABS sink part.) Used a screwdriver to simply clear the t connection with the drain hose disconnected.... ran the DW( where it fills w/ water) ,then turn off, and put the drain hose into a bucket... if its pumping water out well, then it could be the sink drain.
If not... a line somewhere is plugged.
Nov 25, 2010 | LG LDS4821WW 24 in. Built-in Dishwasher
Water is clogged in the bottm of the unit. how do I clear the drain?
The drain filter is clearly visible at the bottom of the wash compartment but there are several possibilities as to why there is still water in the bottom of your washer:
1. Blocked drain filter
At the bottom of the wash compartment, there is a fine mesh grille and a plastic cylinder which protrudes from it. Grip the plastic cylinder, twist anti-clockwise and pull it upwards. To clean it, remove any debris from the cylinder, rinse then replace in reverse order of the above.
2. Blocked/kinked waste hose
Check the waste outflow hose at the back of the washer for any kinks or other damage. Also remove the hose where it attaches to your sink (or waste outlet) and check for any blockages.
3. Blocked waste disposal / sink trap / waste outflow
Make sure your sink is draining efficiently. Clean as necessary
4. Faulty waste pump
If all of the above check out, you may have a faulty pump. Please post back for further advice regarding this after completing the above checks.
Regards,
BElectric
Nov 11, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Hotpoint wf860 door wont open
Lay drain hose down, and drain it into a bowl or bucket, if door still does not open, then you have another prob.
Please rate my solution.
Thanks.
Sep 13, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error "nd" trouble
Nd, means no drain... a blockage in the drain line from the tub. Access from the back panel, you can remove the hose from the machine and check for blockages... this would be on the tub side of the hose... take the hose loose from the machine and check for blockage at the tub. squeeze the hose to check for blockage within.
take the hose loose at the pump to check for blockage there as well... watch out for water ...be ready to mop... let me know how you do..
May 26, 2009 | Maytag MAH2400A Compact Front Load Washer
Water left in dishwasher
  • Check sink drain and drain hose for restrictions . The drain hose can cause the dishwasher to fail to drain properly. The recirculation hose can be responsible for problems with poor rinsing of dishes.
  • To access the drain hose remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel.
    The drain hose connects to the pump and runs to the sink drain (or to the air gap on top of the sink). The pump has a second hose that recirculates the water back into the dishwasher. The drain hose is roughly 1 1/2 inches in diameter. While inspecting the drain hose, check the recirculation hose as well.
    If checking for leaks, feel the hoses where they connect to the pump, for wetness and check the ground right under the connections. If they are wet, it may be a loose or improperly mounted clamp, a damaged pump housing or a leak in the hose itself.
    If checking for blockages, disconnect the drain hose from the pump, pinch the wire clamp with pliers and slide it up the hose. Place a shallow pan beneath the pump to catch any spillage. Remove the hose from the pump; wiggling the hose may help to loosen it.
    Check the hose and nipple to the pump for any debris. The only way to be certain the drain hose is completely clear is to disconnect it from the sink and run water through (such as spraying a garden hose through it at full pressure). Disconnect the recirculation hose and check it in the same way.
  • Unjam the motor
  • Unjam the pump
  • Check the drain valve
  • Check the drive belt
  • Test the timer motor
  • If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
Aug 26, 2008 | Dishwashers
LG Dishwasher model # LDS4821 Constanly giving a OE error on the control panel
On the display a D looks much like an O. You probably have a DE error code which indicates a drain problem. Check your drain line, make sure the hose isnt kinked and the drain line is not blocked especially at the connection to the sink or garbage disposal. If that is all clear you may have a blockage in your drain pump....or the pump itself could be bad.
Jul 30, 2008 | LG Dishwashers
Water drainage
sounds like you're dealing with a pressure problem...from the pump or the circulation channels.
Jun 03, 2008 | Miele 24 in. G892SCU Plus Built-in...
No draining
Following a cycle, a small pool of clean water inside the tub is typical. Excessive water means the pump isn't pumping water out properly, the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up. If dirty water spews from the air gap, the drain line is kinked or clogged. Note: If you've recently installed a garbage disposal, be sure the knockout plug for the dishwasher was removed when the connection was made (see your disposal instructions). 1) Remove the cover from the air gap at the top of the sink (usually a short chrome domed cylinder that sits at the back of the sink) and, using a wire, clean it. Also check the entire length of the drain hose for kinks and blockages, especially at the drain connection to the disposer or drain line. 2) Once the dishwasher is cool, shut off the power to it, and--if your dishwasher is made to allow this-- remove the strainer, located under the bottom spray arm at the base of the cabinet (see illustration). Unscrew the hubcap, lift the spray arm off, and remove any clips that hold the strainer to get it out. Scrub it clean with a brush, then replace it. 3) Determine whether the sink trap or house drain line is clogged. 4) If it still doesn't drain properly, the drain hose may be clogged or the drain valve may need replacement. At this point, it's usually best to call a repairperson. You can check the drain hose for obstructions, but this sometimes involves pulling the dishwasher out from under your counter to access the hose, disconnecting the hose at both ends, and flushing it out with a faucet or garden hose.
Jan 18, 2006 | Hoover 24 in. DT999 Free-Standing...
Dishwashers Logo
41 people viewed this question
Top Dishwashers Experts
