Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
22hp Briggs problem. Loading up, runs
22hp V-Briggs problem. Loading up, runs rough-barely enough power to spin the blades. When you idle it down, and then back up, you get a lot of white smoke, but no oil smell, and the oil level is fine. Plugs look a little wet. It's two years old and is on a Craftsman GT5000
Try checking the prefilter on your air filter. I had a similer problem and mine prefilter was completly covered in dirt. I changed the air filter and it solved my problem. Also make sure the air intakes are not partially clogged with dirt or other stuff.
Posted on Jul 20, 2009
    Scholar:
  • 148 Answers
White smoke looks like water in the gas... flush the gas and put fresh one. By flushing i mean put it in your car, its the easiest way to get environementaly rid of it!
Posted on Aug 05, 2009
22hp bs wont idle
always check spark and compression first spark needs to be blue and compression should be 120 but will barely run on 80psi if both are fine rebuild and acid dip carb
May 22, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Craftsman lawn tractor 42in w/briggs 22hp -low power up hill and cutting
white smoke is more than likely a water issue. Oil usually has a bluish tinge to it but is some cases, it could be white. Drain the gas a fill with fresh to try and eliminate the possibility of water in the gas. Watch the oil level to see if it changes after using the mower. it may take a few times but if it is burning oil, the spark plug will look "wet" and oil soaked, with possible black soot type build up.
Aug 13, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I need an owner's manufal for a Cub Cadet RZT mower with a Kawasaki FR651 22HP engine.
http://www.google.com/url?sa=t&source=web&cd=4&ved=0CCoQFjAD&url=http%3A%2F%2Fwww.mymowerparts.com%2Fpdf%2FCub_Cadet%2FCub_Cadet_Service_and_Repair_Manuals%2FCub_Cadet_RZT_Series_Zero_Turn_Service_Repair_Manual.pdf&rct=j&q=Cub%20Cadet%20RZT%20mower%20manual%20pdf&ei=sWbITayPEoSbtweSvqmSBA&usg=AFQjCNEAreyaCVOyDN0SaP-6A0cxzha8bA&cad=rja
May 09, 2011 | Garden
I started my craftsman 21hp 42in deck today it had a rough idle with backfire and when engade mower it seemed to not have enough power
Backfiring is a sign of too rich on gas and not enough air. Not enough gas will cause the mower to bog down when blades are engaged as it isn't powerful enough to run the motor AND turn the blades. Check your carb and see if you need to clean it and replace diaphgram. Sounds a lot like a carb problem.
Jun 21, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
1,407 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
