Question about Microsoft Xbox 360 Console
I put a new disc drive in my xbox 360 but it dosent read games
When i put a game in it says play dvd and i start it and it says put in an xbox 360 to play this disc.
    Scholar:
  • 151 Answers
Why you replaced the dvd drive i do not know, The problem is if you have installed a non microsoft xbox dvd driver it will not work! If your original dvd driver is broken as to why you have replaced it, contact microsoft or your local games shop for another xbox 360 or drive. You can also by a addon driver, you can see it here
http://www.amazon.com/Xbox-360-HD-DVD-Player/dp/B000JHO4L0
Posted on Jul 19, 2009
This happens when your 360 starts to break ...like a simptom of flu or a cold, you should see about sending it away
xboxexperts
  • 19 Answers
SOURCE: 360 reads game discs but it won't play game and it says play DVD
The problem is that the laser is either dying out, is dirty, or is not getting enough power.
so try to fix it using these steps...
- first open the 360 and pull out the dvd drive and open it up too.
- clean everything out good with compressed air, and q-tips dipped in alcohol.
- now you need to adjust the power going to the laser.Sometimes you may have to try multiple settings before getting it justright. Just keep adjusting the resistance lower and lower until itworks.
- if you tried multiple settings and still get the errors, then either get a replacement drive, or a new laser for it. Click Here for how to properly install the new laser.
- if you get a replacement drive, please not that there is a key in the pcb of the drive that must match the key from the motherboard, so you must either spoof firmware with the key, or swap out the old pcb board and put it in to the new drive.
If you need more dvd drive repair help click here
Posted on Mar 06, 2009
xboxexperts
  • 19 Answers
SOURCE: i have a xbox 360 witha benq drive it won't read the games
This is a pretty common problem in the 360 and sometimes it will act a little crazy with errors like "please put into a 360 console", or it thinks games are dvds and just says "play dvd" after putting a game in. This is usually caused from the laser which is either dying out not getting enough power. You can either fix it yourself which will void the warranty, or send it in to get fixed which will cost around $100 for a new drive.
first open up the dvd drive and clean it good, including the laser. Then try the dvd drive POT Tweak
if you decide to get a new laser, then click here for instructions on how to install it properlly.
If you don't want to get a new laser or do the pot tweak, you can get a replacement drive on ebay or somewhere. It must match the key stored on the motherboard, so you would need to taked the pcb board out of the old drive and put it into the new one for the keys to match.
Posted on Mar 09, 2009
  • 133 Answers
SOURCE: disc drive problem
You need a new laser and/or motor. Games require a higher RPM to play.. DVDs do not
Posted on May 28, 2009
cyclik
  • 10 Answers
SOURCE: my xbox 360 drive wont read games it will only dvds and cds
Your laser either needs to be cleaned or is going bad. I have seen this many times before. Try taking the drive apart and cleaning the laser aperture with 91% alcohol and a cotton swab (carefully). If that doesn't work then you need to replace the laser (or get a new drive).
Posted on Jun 08, 2009
dealt_soul
  • 296 Answers
SOURCE: XBOX 360 Elite won't play disc; says "reading" then "open tray".
If the console has never been opened to change the dvd drive then eather your laser lens or one of the 2 motors in the drive needs to be changed. 90% of the time its the laser lens. You cant just use any laser for the xbox 360. There are 3 different drives. Toshiba, BenQ, Samsung, so you have to see what drive model you have before you try to order one yourself. I repair these often with 99% success.
Posted on Jan 24, 2010
Xbox 360 - Please put disc into an xbox 360 console to play
Try getting a disc drive cleaner. (Maxwell).
www.walmart.com is and example retailer.
May 24, 2010 | Microsoft Xbox 360 Console
Game wont read says put disc in xbox 360 but i am using xbox 360 also it says its a dvd not game just wont let me play no more
If you have recently tried to mod your Xbox 360 then you did not get the drive key installed correctly. Otherwise the laser lens is either dirty/ starting to weaken. You can either replace the laser lens in the disc drive, try to clean it, try the POT tweak or replace the whole disc drive. Keep in mind if you replace the disc drive you will need to swap the PCBs or the drive keys. Hope this helps.
GATpro
May 21, 2010 | Microsoft Fable 2 for Xbox 360
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
My xbox 360 loads in but when i put in a game it dosent load in the game
You could temporarily upload all your games to your xbox360 hard drive using your pc to play or buy a new disc drive but you would have to flash the firmware or manually swap the bottom internal boards inside of the new disc drive with the old one.
http://www.llamma.com/xbox360/repair/xbox-360-repair.htm
Nov 13, 2009 | Microsoft Xbox 360 Console
Won't recognize and load games, only DVD's.
hey problem is the drive key on your dvddrive doesn't match the new m/board you put in...??
you need to get the drive key off the new m/boards original drive and flash it tot your driv.... each m/board has a matching key on there dvd drive.
Jul 27, 2009 | Microsoft Xbox 360 Console
Xbox says play DvD when there is a game in the Disc drive....
Hi. You need flash the firmware from the old drive to the new drive.
Jun 11, 2009 | Microsoft Xbox 360 Console
My xbox 360 doesn't play my games
the lens of the disc drive needs a check up...
May 29, 2009 | Microsoft Xbox 360 Console
Will not play games
Make sure discs are not scratched. Try cleaning the discs using rubbing alcohol and a soft cloth.
Jan 31, 2009 | Microsoft Xbox 360 Console
Dec 23, 2008 | Microsoft Xbox 360 Console
Will play dvd wont play games
bad dvd drive common for these to have.
Dec 19, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
533 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
