Assuming you have vacuum controls at the heater control head, you have a classic vacuum leak in the hose from the engine intake manifuold to the control head, or the vaccum storage canister somewhere in the engine compartment. It is required to fail to defrost by law.
Climate Control Assembly
The climate control assembly has 3 system controls:
- The function selector switch combines a vacuum selector valve with 2 electrical switches to supply battery positive voltage (B+) to the blower motor control circuit and the A/C clutch circuit (if equipped).
Vacuum Control Motors
The 2 vacuum control motors:
- are actuated by vacuum from the function selector switch.
- position the plenum doors to direct system airflow to the vehicle's interior as determined by the function selector switch setting.
The vacuum reservoir is behind the driver fender well, black plastic ball.
If you have diesel, then you will have a vacuum motor under the hood.
please rate if this helps.
check your vacuum pump and the vacuum resovior.
