Question about Tektronix Phaser 740P Laser Printer
Phaser 740 Transfer kit error. Unit was working fine started getting error 33 cleaned second bias clutch and solenoid. Got same error message.Replaced second bias clutch, same error. I have 2 new transfer kits, reseated with different transfer roller, same error
  • 5 more comments
  • dmiller511 Jul 19, 2009
    No paper in the paper path. I have removed imaging unit and fuser.
    no paper in the paper path. removed fuser and imaging unit. all pathways are clear
    Removed fuser and imaging unit all paper paths are clear
    Where are the dirty contacts on the transfer kit? The transfer roller kit only has a roller and a tray.
    I find no contacts on the transfer kit. The kit consist of roll and plastic tray to catch toner.
    Phaser 740 Transfer kit error. Unit was working fine started getting error 33 cleaned second bias clutch and solenoid. I have 2 new transfer kits. Paper paths are clear and I have reset transfer roller many times removing and reseating.
  • 2,359 Answers
FYI,I can only give you troubleshoot steps. I'm going to give you the simple one to start with and the more advance step will be on the bottom.
Get a new rim of paper.
Check the package on the side.
One better paper,they have an arrow the point to print surface and a rough surface (for the roller to pull in the paper)
Fill the tray so the print side will face away from the pick up roller.
The pick up roller can dry up. Check the condition of the rollers.
There are two springs that are near the tension pressure rollers. They can also be the trouble maker.
Open the unit and vacuum out the entire unit. There are few optical sensor that detect where the paper is located or jammed.
CLEAN CLEAN CLEAN and clean some more!
This unit can be dated back to 2004. It can use a PM.
Get some light lube and pass a little by all the gears and bearings,
Compare the former jam location and see is it going closer to the fuser roller.
Also check and make sure the fuser roller is clean and does get hot.
Do test print and let me know where it's jam at.
Good luck.
Posted on Jul 21, 2009
    President:
  • 1,462 Answers
Here is the solution for your problem,
Solution 1:
There is a clutch on the feeder behind a black plastic cover on the side that faces the rear of teh printerthat sometimes will slip of not turn at all. Alot of times removing the clutch cleaning it and applying a thin coat of lithium grease will have it working again.
SOLUTION 2:
Do all the cleaning and adjusting procedures. Remove any stock from the multi-media tray and closed that door. always leave it open with media loaded. u shouldnt have had no jams from the main tray. I've only printed 15-20 pages, and nothing bigger than a 4 page document, but it's still better than I had been getting! If this continues, and I will soon have to print a large report, the problem may have had a very simple solution!
Note:
The photos with the illustration is given in the below link may help you better...
http://time-step.org/printer/
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Posted on Jul 20, 2009
  • Vinod Kumar
    Vinod Kumar Jul 21, 2009
    Does my solution works?
  • Mike Jan 15, 2011
    Before replacing the small black clutch....although it could use lubed. People with less skill can spray lube it. ANYWAY. On that clutch shaft under the paper path plate ( the plate that has the several black ribs on it) are two cams . THESE SHOULD BE REGREASED. With white lithium grease or the like. That WILL help your old clutch and help a new clutch that still sometimes causes a error 33. And stop blaming the transfer kit. Thats not the problem.
  • 3,037 Answers
Have you checked everywhere for paper jammed in the machine? Possibly a sensor is out of place but I think that you still have paper jammed somewhere if you still get this error after replacing the transfer kit. Unplug it, give it a small shake (upside down too), and then tear it apart looking for any small object that may be jammed in it. Let me know how this turns out.
Benjamin
Posted on Jul 19, 2009
  • Benjamin Patri
    Benjamin Patri Jul 19, 2009
    Possibly then you have a broken sensor that senses a paper jam or you have dirty contacts on the transfer kit that can be cleaned with a soft clean cloth. You should also try unplugging the unit for a minute and seeing if that resets the error. Even if you have tried any of the above already, please try them again.
  • 3,741 Answers
THE FUSER IS BLOCKED OR NEEDS REPLACING,
----There is a clutch on the feeder behind a black plastic cover on the side that faces the rear of teh printerthat sometimes will slip of not turn at all. Alot of times removing the clutch cleaning it and applying a thin coat of lithium grease will have it working again.
All descriptions of parts and placement are the same. As you are looking at the transfer kit from the back of the printer, the clutch in question is on the far left with a 3/4" tab protruding from it. Take it apart, clean and grease it and it works great.
Being ever so grateful for a free and quick fix, I posted some pictures identifying the part in question:
The photos provided gave me the confidence to fix my Phaser 740 plus and that was 3 months ago. I printed lots with no more jamming.
CLICK THE LINK DIRECTLY
http://www.spektrumdigitalsolutions.com/phaserfix/
thanks.please do rate the solution.
  • charlymonty Jul 19, 2009
    check out the transfer kit tray.if its loose and not holding the toner.then the error occurs.
    keep updated.
Hp color laserjet cp3525
CP3525-59.FO ERROR. 1. TRANSFER BELT FLAG/ACTUATOR, WORKING? 2. SENSOR CHECK BEHIND CYAN TONER CARTRIDGE, WORKING? THESE 2 ARE IN THE BOOK AND EASY TOO CHECK. 3. MY ISSUES WAS THAT I REPLACED THE FUSER PRESSURE RELEASE MOTOR ASSY, BUT DIDN'T REALIZE GEARS WERE MISSING FROM SECOND HAND UNIT COMPANY ORDERED.:(. GOT MACHINE WORKING, BUT CYAN CAM IS OUT OF ALIGNMENT AND HAVE TO REINSTALL MAIN DRIVE AND CALIBRATE.. THIS ALL STARTING BY NOT USING HP SUPPLIES. BAD TONER CARTRIDGES HAVE TURN THIS JOB REAL UGLEY!!
Apr 17, 2013 | HP LaserJet Office Equipment & Supplies
Getting transfer kit error
I can send you a new transfer kit for 150 € + shipping cost.
comercial@ofiexpertos.com
Feb 19, 2010 | Tektronix Phaser 750N Laser Printer
I need to know how to replace...
The transfer belt cleanning blade is under the transfer belt.Remove 2 screw and change it.The bias transfer roller is mounted in two bushings,remove the bushings and 2 springs.The fuser unit : upper fuser roller,lower fuser roller and the cleaning rollers.
Aug 25, 2009 | Office Equipment & Supplies
I have a Tektronic Color Laser Printer Model 740. I am getting an error message 33. I have replaced twice the transfer roller (new), cleaned and vacumed the the interior of the paper feed unit. I have...
hi,
the paper jamming problem is generic to most printer models of this capability. one way to circumvent this is to use a multimedia-tray while printing.
the reason is probably the two springs that hold down a silver metal pressure roller in the feeding unit. The tension is uneven due to old springs and the paper pulls crooked. If you follow the paper path in the fedder mechanism, you will see the roller I am referring to. The springs are at either end of this bar.
If you are good mechanically, you can replace the springs yourself, although they are a ***** to get back on (some disassembly required).
try this for details on doing it.
cheers
Jul 23, 2009 | Tektronix Phaser 740P Laser Printer
I just put in a yellow cartridge. Previously the printer was working just fine. Now it is showing an error code: 10.92.00 So I put the old yellow cartridge back in. The same error code now appears? He
Hi ron0911170:
This is your problem.
10.92.YY CARTRIDGES
NOT ENGAGED
alternates with
Open and close
front door.
The cartridges are not engaged,
poor primary transfer bias contacts,
defective high-voltage supply, or
control signal errors.
YY Description:
00 - Black print cartridge
01 - Cyan print cartridge
02 - Magenta print cartridge
03 - Yellow print cartridge
1. Open and close the front door to fully
engage the cartridges.
2. Reseat the print cartridges.
3. Check the printer primary transfer bias
contacts to the transfer unit. Clean if
dirty. If the contracts cannot be
cleaned or they are damaged, replace
the transfer unit.
4. Replace the high-voltage power supply
PCB.
5. Replace the DC controller PCB.
Hope this helps
May 24, 2009 | HP LaserJet 3600n Printer
Phaser 740 Printing Cyan only
The problem is usually caused by a faulty imaging device, specifically a bad cleaning blade.
Occasionally this error can also be caused by a sticking cleaning blade clutch.
In this case the grease that was used to lubricate the part becomes gummed up and the moving parts begin to stick and don't move freely as they are supposed to. This is especially common on these printers if they are not used heavily or have sat for long periods between uses.
Sometimes you can free up this gummed up grease by running the solenoid diagnostics several times over. You do this by turning off the printer and then powering up while holding buttons 1 and 3 on the front panel display. Button 1 is the exit button.
This will put your printer into service diagnostics mode. Page through the diagnostics menus until you come to the clutches and solenoids menu. Here you need to hit the start button, then scroll through till you see the test for the cleaning blade. Press start to run the test.
Let this test run for about an hour then hit the stop button and turn off and restart your printer.
If your printer is printing normally again then the sticky clutch is your problem and you will eventually need to remove it and clean off the old grease and relube it. I recommend a high quality lithium grease.
If your printer does not print correctly again after doing this test, then chances are that your cleaning blade on your imaging unit is bad and the imaging unit will need to be replaced. You can generally find them on ebay for a reasonable price.
This problem applies to both the phaser 560 and 740 models. The imaging units on both these printers are also interchangeable. So if you have a phaser 560 you can use an imaging device from a 740 and vice versa.
Jun 11, 2008 | Tektronix Phaser 740P Laser Printer
Phaser 7700 Accumulator Belt Replaced, upon startup there is an error
POSSIBILITIES
Problem:
1st BTR Contact Failure or 1st BTR Retract Failure Message is displayed after replacing the Accumulator Belt Cause:
A Phaser 7700 Accumulator Belt was installed in a Phaser 7750. The Phaser 7700 Accumulator Belt does not have retractable 1st Bias Transfer Rollers; so these errors will be reported if one is installed in a Phaser 7750 printer. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Remove the Phaser 7700 Accumulator Belt and install a Phaser 7750 Accumulator Belt. TRY FIRST (Solutions without parts):
1. Check that all shipping restraits have been removed.
TROUBLESHOOTING TIPS AND HINTS:
1. Test the 1st BTR motor in diagnostics to verify proper operation. 2. Test the 1st BTR sensor in diagnostics, then run the 1st BTR motor test and recheck the 1st BTR sensor. Sensor state should alternate between L and H. The sensor is part of the accumulator belt.
PARTS:Parts are listed in the order of highest probability for repair.
NUMBER QTY DESCRIPTION
116177400 1 *KIT IBT - UNIT
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers, exit rollers and guides; replace if
necessary.
2. Clean feed rollers and exit rollers only when dust or
debris is visible.
3. Remove and clean all paper trays.
4. Clean the Laser Scanner Unit window.
5. Inspect the image density sensors; clean if necessary.
6. Inspect the accumulator belt home sensor; clean if
necessary.
7. Inspect the fuser assembly; clean if necessary.
8. Print the Error Log, diagnose and repair any problems as
indicated.
9. Print the Usage Profile, diagnose and repair any
problems as indicated.
10. Check version of all installed firmware; as
appropriate, install the latest version of firmware.
11. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
Problem:
Jan 25, 2008 | Tektronix Phaser 860DP Thermal Printer
14h error
14: 2nd image transfer pressure/retraction failure
Relevant Electrical Parts
Retraction Position Sensor /2nd Image Transfer
(PC5)
Pressure/Retraction Solenoid /2nd Image Transfer
(SL4)
open cover, remove image transfer unit, behind ITU is 2nd image transfer roller, move it with hand, check solenoid and sensors, thaht they moving freely.
restart
good luck
Nov 11, 2007 | Konica Minolta magicolor 2400 Laser...
Tektronix 740 fuser
found solution, was the clutch on the accumulator shaft
Nov 06, 2007 | Tektronix Phaser 740P Laser Printer
Tektronix Phaser 740P Laser Printer Logo
852 people viewed this question
Top Tektronix Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Tektronix Office Equipment and Supply Expert? Answer questions, earn points and help others
