Question about Sony Cyber-shot DSC-W70 Digital Camera
The Sony battery that came with the camera no longer works
After the battery was depleted, I charged it and now I get a "Use compatible battery only" error when I turn on the camera.
    Problem Solver:
  • 5 Answers
I had the same problem and tried cleaning the contact points with alcohol on cotton swabs and it didn't work so I tried using a clean pencil eraser and after cleaning both the battery contact points and the 3 contact points within the camera using a twisting motion, it works!
Posted on Jul 27, 2009
DSC N1. Why won't it shoot new photos?
From looking at the screenshot, it appears the battery may be almost depleted. Have you tried replacing or re-charging the battery ?
Dec 27, 2015 | Sony Cameras
Sony DCR-HC40E when turned on using battery (NP-FP50) power will display the following mesaage "Use InfoLithium Battery Pack" and then switch off.When on DC power it works fine. Also, when I...
It means the camera has detected that the battery is not genuine or not compatible. sony batteries has the data chip that provides the 'info' in infolithium.
check with the vendor who sold you the battery.
Sep 21, 2011 | Sony Handycam DCR-HC40E Mini DV Digital...
Camera says battery not compatible
maybe the battery is not the original battery.
you can buy cheap replaement batteries for your digital cameras.
US shop:
http://www.sales-battery.com/digital-camera-batteries.htm
UK shop:
http://www.global-battery.co.uk/digital-camera-batteries.htm
Oct 29, 2010 | Sony Cameras
The main batter will not hold its charge when left in the camera.
After 12 months use camera batteries will not hold a true charge, but they can still be used for clocks, or remotes. Buy new ones. We all have the same problem.
Mar 08, 2009 | Sony Alpha DSLR-A100 Digital Camera
Battery compatibility
There's not much you can do about the problem because the problem is inside the camera. A faulty component is probably the cause. (I think its receiving more or less that the needed amount of power so that's the error with compatibility)
If still within warranty, take it back to the reseller and ask them for a replacement or get it fixed. If they refuse, ring up SONY.
Oct 02, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Camera powers off
I think battery went on protection mode and if you give couple of hours rest to battery by take out from camera and place it on shelf. Hope this trick will work.
May 28, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Flashing lights
This sounds similar to a problem I had. I brought the camera in under warranty and the repair shop fixed it. They shop text is cryptic.
Problem: Camera light keeps flashing, not charge
Solution: Troubleshoot to intermittent switch block control, replace with new one, test OK.
Feb 17, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
SONY DIGITAL HANDYCAM DCR-TRV340 PROBLEMS AS NOT CHARGING
Do you have any issues when operating the camera using the AC? If not, then the battery is most definitely your culprit. Batteries have a limited life span and they do tend to have a shorter lifespan as the years go by. If you can try depleting them and seeing if then they recharge, it's worth a shot. Otherwise a simple battery replacement is in order.
Also, try and use another battery and see if it charges. If it doesn't, then it just may be the charger. I'd also check Sony's website to see if there's a firmware update for your camera. Download and install it.
JD
Digital Camera HQ
Dec 01, 2007 | Sony Handycam DCR-TRV340 Digital Camcorder
Sony Cyber-shot DSC-W70 Digital Camera Logo
316 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
