Blower seems like its not blowing hard enough when cooling the house is there a way to adj the speed of the fan
    Champion:
  • 233 Answers
If it is a psc motor it may be a five speed..(most are) there is a wiring diagram usually on the back of the blower door, and a diagram on the motor isself to tell which speed is the highest speed (colored wire) the units are usually factory wired for the highest speed connected to the circuit board for "cool" it may be possible that it has been changed. also, if the run capacitor is bad, the motor will not come up to full speed, it may need to be checked and changed, and lastly, the filters, squirrell cage and evaporator coil cleanliness need to be verified.
Posted on Jul 19, 2009
Fan speed wont change speeds on heat or cold cycles
Sounds like the Blower Motor Resistor. The range from 10 to 75 dollars depending on what kind of vehicle. Pretty easy to change.
Blower Motor Resistor Repair Heater Fan Speed Control Chevy Blazer GMC...
Nov 09, 2014 | Cars & Trucks
Ac fan doesn't blow hard enough 1985 300zx
If very little air comes from the vents, the fan on the blower motor may be damaged, or there may be a restriction in the vents, or a blend door may not be open completely.
Aug 23, 2012 | 1985 Nissan 300ZX
Ac fan speed
Replace the blower motor resister,this is the speeds for the blower motor,it is located very near the blower motor,and is mounted on the blower box,and it actually goes inside the box,to keep it cool.The reason for it`s failure is the blower motor,even though the blower motor sounds,and runs good,it is drawing too many amps.If this was at all helpful,please rate,thank you.
Jul 27, 2010 | 2001 Ford Expedition
Blower Motor Speed - It was suggested
BJ
I'm using the comment section of the original posting to communicate with you.
Pat
Feb 25, 2010 | 1999 Jeep Wrangler
The a/c is cold enough and the system is charged but it dosent blow hard enought to keep the truck cool... what to do????
ARE THE AIR INLETS FOR THE BLOWER FAN CLEAR? I HAVE PLASTIC BAGS IN THEM MANY TIMES, DOES THE BLOWER WORK ON ALL SPEEDS?
Aug 12, 2009 | 2006 Dodge Ram
Air Conditioner Problems
Check for a vacuum leak. The vacuum cannister under the evap. case will crack and cause a leak. I just install a new vacuum cannister,check valve and hose going to inside of van.
May 28, 2009 | 2002 Ford E350
2002 saturn heater
The problem is the blower motor speed control resistor, it is located near the blower motor in the housing.
Nov 23, 2008 | 2002 Saturn Sl
Does ac blower have a fan relay ? It doent blow ******* max
if it doesnt work on all speed its the blower motor resistor that broken thanks pierre
Jul 30, 2008 | 1979 Pontiac Firebird
My blower motor doesn't blow air out the air ducts why
Check for a frozen cooling coil. Turn the fan to the on position at the thermostat and the cooling to off. Your cooling coil may be iced over. Allow it to run in the fan only mode until the coil has had a chance to defrost. At the outside unit you may see the large line is frosted. This is the visual indication for a frozen coil. When you return the A/C to cooling use it with the fan on while in the cooling mode.
May 26, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
80 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
