RVs Logo
W
Wendy lessard Posted on Nov 05, 2016
Need wiring diagram for 38 ft dutchstar a class for 4 coach batteries 6v works great except when plugged in to 120 gets very hot quickly
Need wiring diagram for 99 dutchstar 38 ft for 4 coach batteries 6v...works great except when plugged in to 120 gets hot quickly
How do we hook up the breaks to a 2006 38 ft praire schooner 5th wheel
If you have a 7-pin tow plug the brakes are activated with the blue wire,see diagram. If you have a brake controller
Oct 17, 2018 • RVs
2answers
Replaced coach batteries and still not working
There is a relay that operates when you hook up to shore power that switches from battery power to converter power. It also charges the batteries. If you do not have battery power then suspect a faulty relay. It is located inside the power converter.
My coach battery isn't transferring voltage to the coach.It has a TS30 Power switch and an inverter. It is a Class C 1999 Jayco Eagle. Any suggestions? Thanks in advance!!
Check the fuse panels. If you are not hearing the "clunk" when you cycle the power switch on and off then it's probably a blown 10A fuse for the battery power solenoids.
Feb 25, 2015 • RVs
How do I get my Thor Freedom Elite outlets working? I have already pushed the reset button on the GFCI but stlll not working. any suggestions?
First, the GFI runs on house current aka shore power. Make sure you are plugged in! Most GFIs have a light showing power on.
Check your breaker - not a car type fuse - in the fuse panel. GFIs are nothing but a quick-disconnect in case of a short. (Quick description)
You really need a wiring diagram for this. Try and get one online or from the mfg.
Start by tracing back towards power source from GFI. Remove GFI and check for power on the wires. Be careful, it's 120vac house current. If you have power, replace the GFI. If no power, look at the diagram and proceed to the next outlet/GFI on the same circuit. You might have to go all the way to the power distribution panel. Sooner or later you will find the open wire. Might be nothing more than a screw vibrated loose disconnecting the power feed.
4answers
How do I locate the charging system wires at the converter ?
Should have the basic schematic in your owner's manual. If not, contact the mfg and see if you can download one or have it mailed.
No luck? Google it. If persistent enough, you can find one.
How can i get a wiring diagram?
Wiring diagrams are not available as the manufactures to not publish them. On the back of the stereo system there will be a basic diagram that may be of assistance.
Top RVs Experts
David Spradling
David Spradling
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you a RVs Expert? Answer questions, earn points and help others
