Question about Patton (HASF1016UC) Stand (Pedestal) Fan
Model 1010, style SFE74SP 120v 3 amp 60 hz 350W-off/on switch
The fan motor has a pull chain for off/on which broke off - can I replace it and how do I get to it???? took out all the screws, but cannot access motor?????????
3 Suggested Answers
PegBox60965
  • 51 Answers
SOURCE: Looking to replace Patton fan motor, model 1010mp, style TJ74SP
If you are up to disassembling your motor, you will find a thermal cutout near the windings which frequently fails open. Replacements are readily available, or just jumper it out. If the bearings are shot or the windings burned you're out of luck. Trust me, a new motor will cost more than a whole new fan.
Posted on Jan 01, 2009
  • 8 Answers
SOURCE: where do i find a replacement motor for my patton
Before you replace it, try oiling it -- look at the little oil hole on the back of the motor housing. Or try taking it apart and cleaning it, then oiling.
Did it work before, but gradually slowed down and then refused to start? See other threads on this topic for that fan model.
Posted on Sep 07, 2010
Where can I purchase a Jin you e70469 ceiling fan switch.
ebay 14 bucks
Jin You E70469 Pull Chain Switch for 3 Speed Ceiling Fan 4 Wire 1 2 ...
https://www.ebay.com > ... > Lighting Parts & Accessories
item 2 ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire -ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire. ... item 3 OEM ZING EAR ZE-208S 3 SPEED CEILING FAN PULL CHAIN CONTROL SWITCH E-89885 DR73 -OEM ZING EAR ZE-208S 3 ...
Exhaust Ceiling Fan Switch 2 Speed Pull Chain Blower Jin You ...
https://www.ebay.com/itm/...Ceiling-Fan-Switch...Jin-You-E70469...-/132376583704 Replaces Jin You E70469, Santa, Gardner Bender GSW-33. The control module provides two speed setting for your fan. 2 Speed Pull Chain Switch. 3" (7mm) Brass Chain. Spark Electric Components LLC. Width 11/16" (18mm). ' eBay!
Jin you e70469 ceiling fan switch Google Search
Dec 12, 2017 | Dryers
What current Zinger switch would be used to replace a Zinger ZE 208S?
How many wires on the capacitor & which color wire goes into which slot of the pull chain switch?
Aug 12, 2014 | Hunter Dryers
Need to transform 120v power to 240v
Bad news:
UK has 50 Hz electricity, and appliances are rated for local power..
Any appliance made for US market is rated 60 Hz.
50 Hz and 60 Hz electricity are different.
Look at label on your mixer, and then look at labels on local appliances. You will see 50 cycles or 60 cycles. Rarely appliances are labeled 50-60 cycles.
http://www.worldstandards.eu/electricity.htm#voltage
http://waterheatertimer.org/See-inside-main-breaker-box.html#Hz
http://waterheatertimer.org/What-is-3-phase-electric.html#120-240
Hz Hertz or cycles or frequency is number of rotations the electric generator turns per second.
Some appliances are rated 50-60 cycles and will work worldwide.
However most appliances are rated 50 or rated 60 but not both.
60 cycle motor will not perform as expected when connected to 50 cycles. And might overheat.
Generally, most motors can be converted to different voltages by taking motor to motor shop (if you can find one these day)
However electronic controls cannot be converted between 120V and 230V, nor will 50 Hz electronics work with 60 Hz power
Sorry Sue.
Buy another mixer.
Business will benefit from surge of consumer buying.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 28, 2013 | Hardware & Accessories
Need wireing diagram for AO Smith 1HP motor S#C56A97B08 Ser32409J2
less hassle replace whole pump if motor over heated possible bad seals and distortion to pump housing will leak
Dec 04, 2017 | Pool & Spa
The remote control for my Zenith XBR413 is lost. Where can I find a replacement?
Model # IS 4070
AM/FM Stereo Receiver
With Phonograph and Cassette Play/Record
Serial # W288209
Power Source AC 120 V 60 Hz
78 Watts 0.65 Amps
Unswitched
AC 120V 60 Hz
200 W Max
Nov 05, 2012 | Zenith XBR413 DVD Player/Recorder and VCR...
I have an old zenith is4070. I am trying to figure out how many watts it pushes out to my speakers.
Model # IS 4070
Serial # W288209
78 Watts 0.65 Amps
Unswitched
AC 120V 60 Hz
200 W Max
Jul 09, 2011 | Zenith Audio Players & Recorders
How do you open a wu pin switch. the chain broke & went inside switch
My chain was broken about 1.5 - 2 centimeters inside the wu pin. I took a chain connector (with some chain hanging off one end) and fed it into the hole, trying to connect it to the broken chain. After a couple of tries I managed to get the end of the broken chain inside the wu pin to connect to the chain connector by gently pulling down once it was somewhat inside the chain connector. I hope this works for you. I was so glad I didn't have to resort to cutting any wire or making a trip to a home improvement store!
Jun 13, 2011 | Westinghouse Electric Westinghouse...
GE Box Fan Motor ? No Capacitor?
mcdevito75 here, It could be bad brushes in the motor also, or a bad bearing or bearing cap in 1 of the motor ends.
Jul 27, 2010 | Dryers
Jan 01, 2009 | Patton (HASF1016UC) Stand (Pedestal) Fan
Patton (HASF1016UC) Stand (Pedestal) Fan Logo
511 people viewed this question
Top Patton Dryers Experts
Mohamed Ismail
Mohamed Ismail
Are you a Patton Dryer Expert? Answer questions, earn points and help others
