Question about Refrigerators
Kenmore Side by Side Refrigerator stopping
My Kenmore refrigerator freezer side went completely warm and defrosted everything. After a couple of days it started working again. Two days later it was warm again and this time the whole refrigerator was not cooling. I called a tech who came out and said he thought it was the compressor and told me to call Sears which still had the warranty. I called Sears and of course it started working again the night before they showed up. When the tech showed up he said since it was running he couldn't check anything out and offered the solution it might be the defrost timer since it goes on and off the way it does. Is this true? Can the refrigerator not be tested if its running? I got the feeling that he was trying to put me off and wait for the warranty to expire ..which is does in a couple of weeks. He then wanted 132.00 to come out which he decided not to collect from me. He said I would have to call back when the refrigerator is down but there is no way to get service that quick from Sears. Any advice you can offer please? I'm not sure what to believe at this point. Thank you!
  • loree Nov 20, 2007
    Thanks for your comment. Actually, I don't hear the buzzing. This refrigerator is my second and is in the garage so I don't hear all the usual refrig sounds. When the first tech was out here, it was in a down mode and all warm..he just kept turning the numbers higher and lower and when he finally got some "click" sound is when he said it was the compressor. That's when we got Sears involved. When you say that all he would have to do is cycle the unit, is that done from behind the refrigerator or the interior? I just want to make sure the next time someone comes out they are checking the right stuff. Thanks again for your reply.
  • raymud Jul 08, 2008
    freezer not working ,cycle swich ,and it runs until shotoff then does not start again push ice excelerate and it works again until shut off ,does not restart
  • 447 Answers
Ok this is a huge issue on many refrigerators of all brands that are using a tecumseh compressor. Let me guess that you hear a buzzing for a few secs then a click. And then 15mins or so later buzz...click??The compressor wont start for hours... sometimes even a whole day. Ive gone into detail the whole cycling senario in some early posts in my profile. This explains why you said it stopped cooling. Finally it starts. Only to stop again soon. I cant believe that a tech would tell you he cant check it. All he would have had to do is cycle the unit several times and he would have seen ,most likely, the issue. Inexperience is all that is. But anyhow make sure you get that compressor replaced while its still inder warranty. Dont take no for an answer or youll be stuck with a large bill. Let me know if If i was accurate here thanks.......
Posted on Nov 19, 2007
Frezzer stuck in defrost cycle
You have a bad thermostat . The piece the refrig temp knob is on ( not the freezer knob , it works off an adjusting rod ) .
Nov 12, 2009 | Kenmore Refrigerators
Kenmore 52532101 side by side freezer and refrigerator not cooling - any suggestions? Doesn't appear to be frozen up.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 25, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator side that gets warm and the freezer does not stop r
YOUR DEFROST SYSTEM HAS FAILED,CHECK TO MAKE SURE FREEZER FAN IS WORKING,YOU NEED A METER TO CHECK THE DEFROST HEATER IN FREEZER,YOU NEED TO FIND OUT IF THE DEFROST TIMER IS MANUAL OR ELECTRONIC SO YOU CAN CHECK IT,LET ME KNOW MORE AND I WILL TRY TO HELP YOU MORE-MIKE PS YOU CAN DEFROST IT MANUALY WITH A HAIR DRYER AND IT WILL WORK FOR A COUPLE OF DAYS
Mar 02, 2009 | GE GSS25LGM Side by Side Refrigerator
Unknown water leak from the ice maker, thus freeze build up
the frost on the back wall tells me its not defrosting.this will happen 2 to 3 times a day.if defrost system working their would not be frost.hencethe term frostless.to con firm this sence you defrosted this unit it should work in all ways for a day or 2 lets stop here and you let me know what happens
Dec 31, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by Side Kenmore Elite
hi thanks for the question well you have a no defrost problem with no power go to the cooling nit you will see a small disc with 2 wires going to it buy one first its called a defrost termination switch replace the switch thanks the appliance doc
Sep 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Freezer/fridge won't get cold enough
Madezmom, you have a defrost issue. If your model starts with 106 you more than likley have a bad defrost bi-metal, I will attach a picture of bad one. This sits on the evaporator in the freezer section behind the panel. You will have to remove the shelves and remove the back panel. Defrost the evaporator completely. The part number for the bi-metal is 2196155. See if yours is bulged like the one in the attached photo. If so, that's your problem..Catriver..post back.
Aug 28, 2006 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
258 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
