MY Maytag washer simply stopped I plug an appliance into the plug of the washers and it had power. The washing machine filled with water and now will not continue further. Rolling the dial knob to restart and begin over also does nothing. I have not figured out why I now cannot get it to do anything? Frank
  • 6,784 Answers
HI, the timer control module will need to be replaced in the case. the mechanism has failed.
Posted on Jul 19, 2009
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Maytag atlantis washer water won't stop filling with water even when power is off.
water fill valve have a particle of trash or deposit from water.replace water valve and problem solved.
Jan 31, 2013 | Maytag Atlantis MAV6000 Top Load Washer
The washer keeps filling and won't stop. Sometimes can get it to stop on the wash cycle but won't stop filling at all on the rinse cycle. Any solutions?
I get this question a lot. Washer is flooding the house, water everywhere, won't stop. The first thing I say is unplug the washer. If the water is still coming in,(which it will on a stuck valve) shut off the water faucets. If that is not possible shut the water meter off. If you can stop the washer with the timer then I would say instead of a bad valve you have a plugged water level pressure hose. Look at this diagram: water%20level%20operation.jpg As you can see the rubber tube from the bottom of the tub allows air pressure to push against the switch till it shuts down the valve and starts the wash cycle. Remedy this problem: Simply remove the tube from the switch and blow it out. Use them lungs!. Get that sand and trash out of the sump. Reconnect the hose tightly and pump out any standing water. Then restart the machine. If you have a good tight connection the machine should start working like normal. No parts needed! LOL!
Sep 12, 2009 | Maytag Performa PAV2200
1999 maytag neptune washer stops after filling up with water
There are a couple of common causes for a problem like this. First is a bad door lock assembly that also damages the machine control board (in the control panel). If this is the case the R11 resistor on the machine control board will be burnt.
Maytag has identified seven resistors that relate to specific components that need to be checked or replaced if the resistor is damaged. Listed here are the resistor identification, the circuit involved, and the recommendation:
R9 / pressure switch / check for loose connections or high resistance on switch contacts; replace pressure switch if necessary.
R11 / door lock wax motor / replace door lock mechanism and machine control board.
R51 / hot water valve solenoid / replace water valve and machine control board.
R52 / timer motor / check for loose relay terminal connections and replace machine control board.
R53 / cold water valve solenoid / replace water valve and machine control board.
R143 / (-) 24 Volt DC / contact was made between neutral and the 24 Volt DC circuit.
R162 / electrical buffer circuit / wire harness and machine control board.
Another common issue is a slow water fill fault. If the washer does not fill within a certain time the control will stop on a fault. Usually when this happens the START button can be pushed to continue the cycle.
Washing machines that won't fill or fill slowly often have a restriction in the incoming water supply -- usually in the screens of the inlet hose washers or the water inlet valve itself. Remove the hoses to inspect this condition. If the water inlet valve screens are plugged, replace the water inlet valve.
Go here for: Maytag Neptune Washer Parts
RepairClinic.com
Appliance parts, help & more
Apr 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer water doesnt stop
raise top or remove front panel(can't remember which) rear corner left small hose attached to connector on tub pull and clean probably plugged up with crud also ck connection on tub
Dec 12, 2008 | Maytag HAV3460AWW Top Load Washer
LL SIGNAL ON CONTROL PANEL
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Jul 30, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Checkign lid switch for maytag washer
unplug the power cable open [panel chech wiring detached /mostly some wiring detach was the line of starter switch / the water valve wiring detached / the machine will pour water if valve are malfanction insert the wire . then ok.
Dec 26, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
