Question about LG WM2077CW XL Front Load Stackable Washer with 7 Washing Programs
LE CODE AND A BURNING SMELL - LG WM2077CW XL Front Load Stackable Washer with 7 Washing Programs
  • 6,784 Answers
The LE code represent a failed or locked motor. the replacement of the electrical motor will be needed in this situation.
Posted on Jul 19, 2009
Burning smell Kenmore 50558
If the burning smell is an electrical smell it could be motor or wiring problems which are best handled by a professional. If it smells like burning rubber it is probably the belt. If it smells like burnt wood it could be the belt slipping on the brush roll, if the brush roll is made of wood. Dust and debris can also accumulate behind the end caps of the brush roll causing friction which can cause a burning wood smell.
Mar 30, 2014 | Kenmore 5055, 50557 and 50558...
Gears arent going and no acceleration and burning smell
You need to have a look at your clutch. The burning smell is the clutch slipping.
Mar 22, 2014 | 1995 Holden VR Statesman
Fisher Paykel Intuitive Eco Washer IWL12 fault code 37
Pump Ohms to low will smell like burning enamal
The pump will need replacing,
Apr 06, 2013 | Fisher and Paykel Washing Machines
Lg washing machine WT - R852... LE error..bad burning smell
For LG washers 'LE' stands for Lock Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Apr 21, 2011 | LG Washing Machines
What does the LE code mean on the LG front loading
The main cause for this error code is because you used too much or the wrong kind of detergent in your washer. This code is set off by too much suds in the washer. Not only will this set off the alarm code, but it may also cause your washer to leak and even start to have a bad smell from the dampness getting where it should not be.
OR
LE is a locked motor error. Not to worry as 95% of the time it is just a bad hall sensor (the motor position sensor). For your model the part number is 6501KW2002A.
Please check the below link for an detailed article about LE error code
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
COURTESY:HEATMAN101 - A senior and experienced expert of fixya
Jun 06, 2010 | LG WM-2277HW Front Load Washer
Just brought this car used for my son. rides
HAVE AUTO ZONE SCAN IT FREE AND THEY WILL TELL YOU THE TROUBLE CODE.IF BURNING SMELL OCCUR WITH CAR RUNNING IF YOU SEE BLUE SMOKE COMING OUT EXHAUST TAIL PIPE YOUR ENGINE BURNING OIL.
May 25, 2010 | 1995 Subaru Legacy
Samsung washing machine smells
the LE error code is an over suds error.
the smell could be coming from lint and foreign object matter collected in the rubber bellows that is conected to the drain pump this should be cleaned out i hope this helps
Sep 07, 2009 | Samsung Washing Machines
TV won't stay powered on, there is a odor and the power led is I believe flashing a 312 code
if the smell is like after a thunderstorm,it is ozone from a high voltage leak in the transformer.if it a burning smell,it could be semiconductors or resistors burning
Jul 08, 2009 | Philips Televison & Video
XEROX PHASER 3500. 8220 FUSER FAILED #8221. OVER HEATING AND BURNING SMELL.
LE HE CAMBIADOS DOS VECES EL FUSOR A LA IMPRESORA XEROX 3500, SE HA DAñADO SUPUESTAMENTE POR CAUSA DE LA ELECTRICIDAD, USTEDES ME RECOMENDARIAN USAR OTRA O SABER SI EL FUSOR REALMENTE HA SIDO REPARADO Y POR ESA RAZON VUELVE A DAñARSE.-
Jun 24, 2008 | Xerox Office Equipment & Supplies
LG WM2077CW XL Front Load Stackable Washer with 7 Washing Programs Logo
124 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
