Question about Garden
I have a bolens trimmer and cant seem to wind it correctly so that while i am using it i can bump the head and the string will come out after it gets short sorry also it is a 2 string trimme
    President:
  • 1,486 Answers
The head should have arrows showing you witch direction the string is to be wound.
Posted on Jul 19, 2009
I changed the string in my ryobi 725r and since then it feeds the string so fast it wraps around the shaft. What did I do wrong?
multiple failures with bump advance string trimmers - GardenWeb
forums2.gardenweb.com > Garden Forums > Tool Shed
Jul 5, 2008 - I have indeed hurled my own ryobi across the yard in a fit. ... Some heads are not designed for curved shaft trimmers or on engines under a .... the fence so thestring won't wrap around the fence instead of whipping in and out.
Sep 30, 2015 | Ryobi Garden
Restring bolens bl150
There are two ways to re-string a weed trimmer.
  1. Wind new line on the inner reel
  2. Install a prewound inner reel
Check the owner's manual below for detailed instructions.
Bolens BL150 Manual
Mar 31, 2012 | Garden
I cannot get the line to feed as it is used up. bumping does no good. the spring is in place. thanks for your help
Did you wind in the new string in the correct direction? The string should be wound in the SAME direction that the head spins.
Jun 16, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
I was given a used 31cc trimmer but can't get the spool off to replace it. how do i do this?
A typical trimmer has a small bump knob, an inner spool with the plastic string wound on it and the housing for that which is the string head.To remove the small bump knob, hold string head firmly and turn the bump knob counterclockwise. To remove the head entirely, first remove the bump knob. Next, remove the inner spool with string. What should be left is the spring with the end of the gear shaft showing. Some heads are locked on and some just slip over the end of the shaft. Check the gear drive just above the string head for any holes in the collar. An object can be placed in one of the holes to lock the drive and twist the head off.Ryobi's use retaining clips on the shaft which have to be removed.
May 06, 2011 | Garden
While trimmed is in use, how do I release more trimmer line?
Bumping the string head lightly on the ground will release more trimmer line if the line was loaded properly and spooled in the correct direction. If the line was loaded wrong, doing this procedure won't help. Make sure your line was loaded correctly. Do this bump as the engine is slowing down or running slow. Most all gas trimmers work this way, but some of the electric ones have automatic line feed and no bumping is necessary.
Oct 10, 2010 | Homelite Mighty Lite Lawn Trimmer
No directions on how to re-string the spool on my TB-720
On the bump mechanism, line up the two arrows, then unscrew the bump, this will release the spool, then you wind the two strings in the opposite directions, the arrow on the spool will tell you the direction to wind the string, replace spool, spring, bump feed, and you are good to go. I hope this has helped you.
Jul 06, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
String will not feed when bumped
I've never had any luck with those stupid bump heads. Every time I would refill them, the string would get caught up. They bind up. I finally replaced the bump head with a string head that you place short pieces of string in. They're not perfect either. You have to pre-cut the string to about 9-12 inches in length, and just replace the piece when it's time.
Jun 28, 2009 | Troy Bilt Tb70ss Gas Trimmer
Homelite curved shaft timmer line problem
So, is this trimmer suppose to feed the string automatically? If not, then it sounds like the string is wound up on the spool the wrong direction.
Jim
May 28, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Garden Logo
364 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
