Question about Microsoft Office Professional 2007 Full Version for PC
Keyboard mouse keys don't work when Office is loaded on Vista
Have brand new Dell Inspiron and loaded Office 2007. Now mouse keys on touchpad don't work. Called Dell and they sdaid to resote OS. Did and re-loaded and had same problem.
  • 17 Answers
Basically office 2007 is very heavy. it must be some driver problem. take this link. find your drivers http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen&~ck=mn
Posted on Jul 19, 2009
Touchpad
Just look out for a mouse-pad symbol on any of the function key of your keyboard.
And then press the 'fn' key on your keyboard with that key which has symbol of mouse-pad on it. I guess you will be able to access your mouse pad.
** You can also avail our technical support by visiting our website: http://www.vtechsquad.com.
May 06, 2013 | Dell Inspiron 1300 Notebook
Brand new computer can't get my touchpad to work, how do I unlock it?
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Dell Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
May 19, 2012 | HP Computers & Internet
My laptop Dell inspiron N4010 touch pad is not working.. wats the solution
May 11, 2012 | Computers & Internet
Unlock the mouse in dell inspiron m5030
1) Examine your "Function"/"F" keys and look for a touchpad icon. If you find one, hold the "Fn" key and press the touchpad icon button to unlock the touchpad. Move on to Step 2 if your laptop doesn't support this feature.
  • 2) Plug a USB mouse into an open port on your laptop. Click the Windows "Start" button. Click "Control Panel" in Windows XP and double-click "Device Manager." Type "Device" in the search box in Vista and Windows 7 and click "Device Manager" from the results.
  • 3) Click "+" next to "Mice and other pointing devices." Right-click the touchpad and select "Enable." Your touchpad is now unlocked.
  • Feb 06, 2012 | Dell Inspiron M5030 Laptop
    Inspiron Keyboard Jumps Around
    Install the latest touchpad driver from support.dell.com
    There is a setting in the touchpad tab of the mouse driver. Either Enable PalmCheck or Disable touchpad when typing (Depends on Synaptics or Alps drive I believe)
    With palmcheck enabled, the touchpad is disabled when typing
    Jan 24, 2010 | Dell Inspiron 1420 Notebook
    Inspiron 1545 keyboard problem
    This is going to sound really weird but I found a fix. I've got a Dell studio XPS laptop and was getting annoyed by the same phenomenon. I discovered the problem was more common when my thumbs were close to/touching the touchpad. I cranked down the sensitivity of my touchpad and things got a lot better. Probably works for many different kinds of laptops.
    For my machin - Steps to fix:
    Mouse Control Panel: Dell Touchpad Tab: Click to change Dell Touchpad Settings: Touchpad Settings: Touchpad Sensitivity: Move it from near "Light Touch" to the middle.
    I hope this helps someone. :-)
    Jun 18, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
    Touchpad not working
    Hello, my best solution would be to check ebay and order one there. If you are familiar with removing the power button bezel, do so and remove the keyboard as well. Then check the connection for the mouse. Its a small little ribbon cable coming from the mouse area.
    Here is a direct link you can get these parts from:
    http://computers.search.ebay.com/Dell-Inspiron-6400-touchpad_For-Laptops-Notebooks_W0QQcatrefZC6QQcoactionZcompareQQcoentrypageZsearchQQcopagenumZ1QQdfspZ32QQfromZR2QQftrtZ1QQftrvZ1QQsabfmtsZ1QQsacatZ158885QQssPageNameZRC0022QQ_trksidZp1638Q2em120
    I hope you have a great day, Please rate my solution.
    May 20, 2009 | Dell Inspiron 6400 Notebook
    Dell inspiron tochpad only works by holding down key on keyboard
    It is likey the connection for the touchpad has come loose. As this connector is under the keyboard it would make sense that putting pressure on the keyboard causes it to work. If you are comfortable with removing a few screws, refer to the service manual on Dell's website on how to remove the keyboard. You will then see a ribbon cable connected to a plastic mechanism that secures the cable to the connection on the motherboard. Simply slide the top of the plastic mechanism forward or back to release tension on the ribbon cable, make sure the cable is straight and all the way forward, then slide the mechanism back into place and you should be okay. If you are not comfortable with removing anything, any computer repair shop should be able to do this for you relatively quickly.
    Mar 19, 2009 | Dell F3534 Touchpad
    Keyboard and mouse won't work after start up
    Pls check that the press button on the top of touchpad, most probably its disabled by being accidently pressed.
    Dec 11, 2008 | Dell Inspiron 1521 Notebook
    Microsoft Office Professional 2007 Full Version for PC Logo
    135 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Alun Cox
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
