Question about Cameras
Olympus u730 zoom error
When you switch on the camera the lcd screen is blue and in red a message appears for a couple of seconds "zoom error"
  • shegar281 Mar 22, 2010
    when I switch on the camera the lcd screen is blue and in red a message appears for a couple of 'zoom error
SOURCE: pictures appearing black- olympus FE 170
You checked the obvious, lens cover? (sorry had to ask) any grinding noises when you take a picture or focus\zoom?
Posted on Aug 26, 2007
Jesse Techno
  • 19 Answers
SOURCE: Help with Olympus C-5000 Zoom camera
OK, I went and found what you need on http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/.
Find yours on the list (I found it on there so it is there).
Hope this helps :)
Posted on May 29, 2008
hemantraj
  • 638 Answers
SOURCE: Olympus SP560UZ 18X Optical Zoom,
take it to the repair center.major damage
Posted on Aug 29, 2008
BillB-SA
  • 2761 Answers
SOURCE: Olympus SP-560UZ "Zoom Error" then shuts down
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Posted on Sep 14, 2009
SOURCE: Olympus Stylus 710 Problem with lens
Turn on camera. Blurry pic. Wirly grinding noises. Blue screen.
Codes on blue screen:
5 f 0 8
5 e 0 2
5 f 0 8
5 e 0 2
Sometimes smacking the **** out of it fixes it. Today it doesn't seem to do the trick any more.
Suggestions?
Posted on Nov 27, 2009
Zoom not working - Screen goes blue and codes 1e13 3403
Was not fixed. Do not have this specific camera.. Is a different Olympus.
Jun 16, 2009 | Olympus Camedia C-50 Zoom Digital Camera
Blue screen error
try this and see if it works for your problem as well. this is from another fixya post.
Mar 04, 2009 | Olympus Stylus 700 / 700 Digital Camera
Olympus SP-570UZ-zoom error
Had 570UZ for 2 weeks and "ZOOM ERROR" occured. Seemed hopeless. Changed batteries several times, bought new Alkaline.
No change. Finally decided that it is probably a connector problem.
Turned Camera Off. Held Camera by the lense barrel. Held palm of other hand and thrust the back of the camera ( LCD side) into the
other hand. The idea being to jostle the camera contents without cracking the LCD. Did this a couple of times, turned camera on and it works fine. At least for this evening. At least for now it seems like a classic component connector problem somewhere inside the camera.
Oct 30, 2008 | Olympus SP-570UZ Digital Camera
I have an Olympus SP 320 camera, zoom error comes up and it shuts off
I just pulled my 320 out after not using it for 4 months and the lens extended and zoom error began flashing on the screen. After reading a few other post on the net about how much it cost I decided the camera was a goner. For good measure I banged it on my mouse pad a couple times and the lens suddenly retracted and it is now working fine. Doubt it will work very often but might be worth a try. Make sure you hit it on something soft to prevent other damage.
Sep 15, 2008 | Olympus SP-320 Digital Camera
Zoom Error
We had this problem for about 2 weeks, we discovered that having the camera auto retracted after the "ZOOM ERROR" message, giving the camera couples of light slaps (slap the camera's LCD side and aim the camera down), this fixed the camera right away
Mar 03, 2008 | Olympus SP-550 UZ Digital Camera
Blue screen error code
the lens open halfway, the picture on the LCD is blurry and one second after the lens close and an error appears of the screen saying "D: 5f08 5e02". what does this mean??? can you help me fixed this one??
Oct 13, 2007 | Olympus Stylus 700 / 700 Digital Camera
Pictures appearing black- olympus FE 170
Aug 26, 2007 | Olympus FE-170 Digital Camera
Blue and red squares over my image
A histogram is a graphic representation of the distribution of brightness values in an image. The C-5500 has two histograms. One displays a real-time graph on the LCD screen as you compose your images and during the Quick View of images after they are shot. The DIRECT histogram displays potentially over and under-exposed areas in the image with a grid of squares—red for over-exposure and blue for under-exposure. You can set the histogram to OFF to prevent the histogram from appearing.
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Cameras Logo
307 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
