Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox 19" LCD TV: no sound
Turning the TV on after it has been off overnight worls for a few seconds, then the sound goes off. None of the controls works after that ( ON/OF, change channel etc.).
Pulling the power plug off, waiting a few seconds and replugging it turns the TV on, again for a few seconds. This dance needs to be repeated 4 or 5 times and then the TV works for the rest of the day.
  • 31 Answers
It sounds like a dry joint,where the solder cracks if you tap it on the side and it alters its state then you have to locate this cracked solder and re solder,sometimes not visible though
Posted on Jul 19, 2009
Why does my TV on when the power button is off?
You need to spare yourself a lot of frustration and just replace the TV
Jul 13, 2016 | Astar Magnavox 19MD358B 19 in. LCD TV
PICTURE GOES OFF AFTER A FEW SECONDS. SOUND OF TV
have youtryehave you tried going to menu options and turning off the power save you might try changing the scart cable any interferance will cause the tv to turn of. my little boy often knocks the scart lead on my set an the tv turns itself off when he does this ,. hope this helps good luck
Dec 11, 2010 | LG 42LG30 42 in. LCD HDTV
Dog knocked over my magnavox 19" LCD TV. I tried turning it on after i put it back up and it did not turn on with the power button or the remote control. Any ideas on what might be failing? Please and...
Almost anything could happen when aTV or any appliance hits the floor. You can just about say this TV is totaled. If you know of a hobbiest in electronics, have them remove the back cover and inspect the boards for cracks. You might be able to save.....just maybe. Chances are not real good, but have a look and thanks for asking, and show a few hands of support!
Oct 17, 2010 | SNK Magnavox 19MF338B/27 19 in. LCD TV
My magnavox 42mf438b lcd tv will be fine for about 10 minutes when i turn it on, then the screen goes completely black but it still has sound. it stays like this even if i turn it off and back on. i can...
that set is highly rated by users .. it first came out in early 2009 (i think) so you might check to see if any warranty remains ... the display is illuminated by several lamps .. each lamp has its own high voltage inverter .. all the innverters are powered by an output of the low voltage power supply (often 18 volts)... i would suspect a problem with that low voltage power supply.. either a bad capacitor or a thermal issue .. .. ..
Apr 10, 2010 | SNK Magnavox 42MF438B/27 42 in. LCD TV
Picture comes on for a few seconds then it goes black. Sound continues to work but no picture. After turning off and on a dozen times in a row, the picture may stay on
These t.v.'s have a microprocessor in them, similar to a computer. Try unplugging it from the wall for a few minutes then plug it back it. If that doesn't work try removing the cables and plugging those back in.
Mar 29, 2010 | Memorex MLT1912 19 in. LCD TV
Magnavox 19" TV shuts itself off.....won't stay on
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jun 04, 2009 | Philips Magnavox 27MS343S 27" TV
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
Magnavox Mod. # HD 2715 C 202
Your set in in closed caption mode text 1....Go into your menu and un-do the closed caption mode.
Feb 18, 2008 | Philips Magnavox 27MS343S 27" TV
How do I remove on screen tutorial
first question... can you go through the tutorial?
Aug 01, 2006 | Philips Magnavox MT1931B 19" TV
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
224 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
