Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Same problem - Kenmore top loading washing machine 80 series
My husband thinks it's the belt and is trying to check as I write this but he can't find a way to get to the belt. Is there a diagram available or directions on how to get beyond the motor to get to it?
  • Phameous Jul 19, 2009
    Just printed out your recommendations and handed them to my husband, who, before I gave them to him, realized that there wasn't a belt;-) So, I'll let you know what happens once he gets everything put back together that he took apart trying to find one. This is such an awesome website! Thanks very much!
    President:
  • 744 Answers
Hello, from the limited information I have this sounds like it's going to be a broken coupling. Kenmores are usually direct drive machines made by whirlpool, this means they don't have a belt. Instead the transmission is connected directly to the motor via a coupling. This is what a coupleing looks like: Same problem - Kenmore top loading washing machine - 0c6b869.jpg To confirm this pull the machine forward enough that you can lean it back and it will stand back under it's own weight. Wedge something underneath the chasis so it does not fall on you while your accessing the bottom. Go under the Machine and locate the motor, You will see the pump connected to the motor connected to the transmission. 1. Unplug the wire harness from the motor then. 2. Use a screw driver remove the 2 clips holding the pump in place and remove or push the pump out of the way. 3. You will need to remove the 2 screws from the brackets holding the Motor in place with a nut driver. 4. With a screwdriver remove the 2 clips holding the motor in place (be carefull to support the motor as the clips comes off) 5. remove the motor and drop it onto the floor. Now you will see the coupling..one side on the motor the other side on the transmission the rubber connector inbetween. Replace the coupling if broken or worn and reassemble the washer in reverse order. Now you should be all set. Be aware you may smell rubber on the first couple loads this is normal after replacing a coupling. Good Luck!! if you have any other questions or concerns please feel free to comment again. Mike p.s Please remember to rate my solution since this helps me to help other people :) Thanks!
Posted on Jul 19, 2009
  • Mike Price
    Mike Price Jul 19, 2009
    p.s don't forget to unplug the machine before servicing ;)
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
There is a moldy smell coming from my washing machine. I have run bleach, lysol, and vinegar throught the washer but nothing seems to alleviate the problem. My husband has also checked under the washing...
I had the same problem once and I had a leak behind the wall, I fixed the leak but still smelled it for a while. I had a small opening in the wall, so I sealed up the hole with that expanding spray filler and it went away
I think the smell is moisture mixed with lint setting on soaked
hope this helps
rick
Jul 15, 2011 | Kenmore 24032\24036 Top Load Washer
Clicking noise. BUT DRAINS FINE!
kenore don't have belts they have couplers,check the lid switch-mike
Jul 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
Sep 02, 2008 | Kenmore 24032\24036 Top Load Washer
Need cu size of my broken washing machine.
it is a 3.0 cubic foot.
  • I would do some research before spending a lot of money on a front loader.
Aug 05, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer 4yrs old
suspect gearcase problem or broken brake release on bottom side of basket drive
May 20, 2008 | Kenmore 22422 Top Load Washer
If the motor is starting? it will be just a belt replacement belts range 15-40ish
Jan 03, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
665 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
