Question about ASUS Eee PC 1000H Laptop
Asus 1000he red vertical line in monitor will not
Asus 1000he red vertical line in monitor will not go away
  • 20 Answers
Hi
If you have External Monitor check by connecting it
if you get display on external monitor without line it means Display screen is Bad, if Line appears on external display as well then there is either Display driver issue or motherboard problem.
Posted on Jul 03, 2010
What is the cause and is there a fix for the two vertical lines in the center of my LG monitor.
Check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 11, 2014 | LG M4225CCBA 42 LCD TV
Line on monitor
Here's a video VISHAL NAYAK suggested as a solution to your problem from YouTube:
How to Fix Vertical Lines Laptop Screen FOR FREE/EASY
May 08, 2013 | Apple Computers & Internet
I need to change the keyboard o my laptop - eee pc 1000he laptop problem -but having taken out 8 nuts i cant seem to be open it up to get the keyboard out....help
ASUS Eee PC 1000H DIY 1000HE chiclet keyboard upgrade
ASUS have been gradually transitioning to chiclet-style keyboards on their Eee PC netbooks, with the latest model to get the new style being the Eee PC 1000HA. If you're an existing owner looking longingly at the new layout, meanwhile, and specifically have an ASUS Eee PC 1000H, you can fudge your own update with the keyboard from the Eee PC 1000HE.
It's not just an aesthetic upgrade, either. ASUS bizarrely played around with the keyboard layout on the 1000H, one of the most obvious changes being the right-hand shift key getting nudged across by the up arrow. The 1000HE keyboard, however, has a more standard layout.
There's a little modification required before the keyboard panel slots in - basically snipping off a few metal tabs - but it looks relatively easy from EeeUser.com forum member Barovelli's photos (some of which are reproduced here). Not all users are reporting 100-percent key success, however, so don't throw away your old 'board.
The replacement 1000HE keyboard is priced at $15 through ASUS; however, it's currently listed as out of stock.
Mar 25, 2011 | Computers & Internet
I am using the Asus VH236H for video game playing on my playstation 3 and xbox 360. I was playing marvel vs capcom 3 last night and notice a red vertical bar appear on the left hand side of the screen and...
Flat monitors work on a grid method, if one of the grid is failing it creates a horizontal or verical line. its not something you can fix, so send it back.
Mar 17, 2011 | ASUS VH236H 23 inch Monitor
A long vertical red line in right side last.
That is a waranty issue, I have delt with that problem myself and there is nothing to do but get it replaced.
Jul 14, 2010 | ASUS PW191 (Black, Silver) 19 inch LCD...
My ASUS 1000HE works off line, but no Internet connections
Firstly connect to your router by typing 192.168.0.1 in the internet address bar (sometimes 192.168.1.1) and this should connect to your router. Now log into the router i dont know what router you have but mostly its admin and admin or password = password. Make sure all the settings there are correct like your ISP login name and password. Hope this helps
Oct 31, 2009 | ASUS Eee PC 1000HE Netbook
Want to use my tv as a monitor, how do I activate the vga output?
Hi adiazjr.On the Asus 1000he, in order to switch to an external monitor you need to press the function key (Fn) at the bottom left of the keyboard and the F8 key at the top. When you press both of these keys at the same time it will send the video signal to whatever external monitor or TV you have connected. Hope this helps!
Aug 28, 2009 | ASUS Eee PC 1000HE Netbook
Vertical lines on screen , is there a processor driver download to fix this problem
Vertical lines on a screen is not a processor problem, vertical lines is going to be a problem with the monitor or the video card. Try a different known working monitor on your computer and if the lines go away then you know that the original monitor is bad.
If the lines don't go away then try replacing the video card. If you have integrated video then the motherboard would need to be replaced. A processor driver download is not going to fix a vertical line problem.
Aug 08, 2009 | Dell Computers & Internet
Thin red vertical line length of screen(right side)
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new monitor.
Feb 20, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
A single vertical red line
That means the LCD panel itself (the actual glass) is broken. Don't delay, return it and get another before it's too late! The problem will most likely NOT go away, and there is no fix other than to replace the panel itself. The panel, when purchased separately, can cost more than the monitor itself.
Dec 27, 2007 | LG L1915S 19" LCD Monitor
ASUS Eee PC 1000H Laptop Logo
993 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
