Question about GPS
Model MN2707 It turns on but doesnt seem to load data.Off to one side it says (it is important that digital map and PO)and that is all I can read .None of the buttons work and neither does the touch screen.
    Brigadier General:
  • 4,090 Answers
Can you recalibrate it.. screen shift is usually off calibration. But the rest of your problems are unrelated and major
Posted on Jul 22, 2009
What could PO 302, PO 300, PO 105, PO106, PO 110,PO 115& PO 120 CODES Mean on a Toyota Camry 2000 model sedan car?
what engine, what size. that is first question.
misfire, map ,maf, iat, ect,tps and cat fail and low coolant temps.
very odd mix there. did you pull connections, key on???????
it means they all fail a test.
DIY? or just curious?
login to alldata.com
the question is , which is the most important.
all are cept 420, (last that, and bet goes way. later.)
reset the ECU, and see which come back.?
check all fuses.
then post codes that repeat, after fuse checks.
does the engine get fully hot running, 180F minimum?
Nov 27, 2013 | 2000 Toyota Camry
Code po105 pops up i had it reset and every 3-4 days it lights back up what does it mean ?
Generic code results from http://www.obd-codes.com/p0105 :
P0105 - MAP Circuit Malfunction
Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
The MAP (Manifold Absolute Pressure) sensor is part of the fuel management system. It reacts to changes in engine manifold pressure. The PCM (Powertrain Control Module) monitors the MAP sensor continually to properly run the engine. Changes in engine load require changes in the amount of fuel injected, and timing of the ignition system, etc. An engine under load has more manifold pressure(or less vacuum) than an engine that is coasting. As the load changes, the MAP sensor voltage signal to the PCM changes accordingly. To check the MAP sensor operation, though, the PCM watches other sensors to verify that the MAP sensor is working properly.
For example, the PCM compares the TPS (Throttle Position Sensor) signal to the MAP signal to verify the MAP signal isn't "sticking". If the PCM doesn't see a MAP sensor change immediately follow a change in the throttle pedal sensor, it knows there is a problem with the MAP sensor and sets P0105. Or, if the PCM notices that the TPS indicates the engine is under load, but the MAP signal indicates that the engine is "coasting" it, again, knows there is a problem with the MAP sensor or TPS and sets P0105.
FB.init("dd7d9e9681341cde77587bc6a2029f6f"); OBD-Codes.com on Facebook
Symptoms of a P0105 check engine light code may include:
  • Poor running engine
  • Engine runs rich
  • Engine won't idle
  • Engine backfires through tailpipe
  • Engine misfire under load or at idle
  • MIL (Malfunction Indicator Lamp) illumination
  • In some extreme cases there may be no symptoms other than MIL illumination
A P0105 DTC could be caused by:
  • MAP sensor vacuum hose disconnected or plugged
  • Bad MAP sensor
  • Bad TPS
  • Damaged or problematic MAP sensor connector
  • Damaged or problematic TPS connector
  • Damaged wiring
  • Short to reference voltage on signal circuit of MAP sensor
  • Loss of ground to MAP sensor or TPS
  • Open on signal circuit of MAP sensor
  • Bad PCM
Using a scanner or code reader, turn the ignition on and engine OFF; what does the MAP sensor voltage read? It should be about 4 Volts for sea level. If you are at a higher altitude, it should decrease about half a volt or so for each 1,000 ft. of altitude (this will vary from model to model) Or if you have a separate MAF (Mass air flow) sensor on your vehicle, they are usually equipped with a Barometric pressure reading. If so, the Baro reading should match the MAP reading (they both measure ambient air pressure). If they're roughly equal, then, check for Freeze Frame data of the MAP sensor (if available).
NOTE: Freeze Frame data is the PCM recording a fault when it happens. It captures the readings of the various PIDS (parameter identifiers)available to troubleshoot what happened. It's like a recording of the problem as it happened. At idle a typical MAP sensor Voltage reading should be about a volt, and at WOT (wide open throttle) it should approach 4.5 to 5 Volts. As for the TPS, at idle, the voltage reading is about 1 Volt or less. As the throttle is opened the reading will increase to 4.5 Volts at WOT. Do the two readings make sense? For example, if the TPS reading on Freeze Frame data shows 2.5 Volts (indicating partial throttle) does the MAP sensor indicate a reading that isn't at either extreme? Using the Freeze Frame data (if available) compare the MAP reading to the TPS when the problem occurred. This can help you identify what happened
If you have no access to Freeze Frame data then check if the MAP sensor voltage changes when you apply vacuum to it. You can do this by mouth or a vacuum pump. The voltage should increase as you apply vacuum. If the reading doesn't change as you apply vacuum, make sure there are no obstructions in the hose to the sensor. If the hose is clear, the MAP sensor is usually bad, but it doesn't rule out the following from causing the problem: Does the MAP sensor appear to be stuck at less than .5 Volts? Then:
NOTE: This code shouldn't set if the MAP is stuck at extremely low voltage, however, I'm adding it in because there's no way to know for certain for which vehicles a low voltage condition may set a P0105.
  1. Inspect the wiring harness and MAP sensor connector. Repair any damage
  2. Unplug the MAP sensor connector. Also, at the PCM connector, remove the MAP sensor signal wire and check for continuity to the MAP sensor connector. If there is infinite resistance, then repair open in MAP signal circuit. If the signal wire has continuity to the MAP sensor connector, then check for 5 volt reference voltage to the connector and a good ground. If both are present, then re-install all removed wiring and replace the MAP sensor.
Does the MAP sensor appear to be stuck at full 4.5 voltage? Then:
  1. Inspect the wiring harness for damage. Repair as needed
  2. Remove the MAP sensor signal wire from the PCM connector. With a voltmeter measure the voltage with KEY ON ENGINE OFF. Is there 4.5 Volts? If so, unplug the MAP sensor and recheck. If it is still present, then repair short between the signal wire and 5 volt reference wire.
  3. If unplugging the MAP sensor causes the voltage to disappear, check that the ground is intact. If it is, then replace the MAP sensor due to internal short.
Feb 27, 2011 | Jaguar X-Type Cars & Trucks
I have this eobd code problem p0105 in my elantra, where those sensors?
P0105 - Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
* Poor running engine
* Engine runs rich
* Engine won't idle
* Engine backfires through tailpipe
* Engine misfire under load or at idle
* MIL (Malfunction Indicator Lamp) illumination
* In some extreme cases there may be no symptoms other than MIL illumination
Causes: A P0105 DTC could be caused by:
* MAP sensor vacuum hose disconnected or plugged
* Bad MAP sensor
* Bad TPS
* Damaged or problematic MAP sensor connector
* Damaged or problematic TPS connector
* Damaged wiring
* Short to reference voltage on signal circuit of MAP sensor
* Loss of ground to MAP sensor or TPS
* Open on signal circuit of MAP sensor
* Bad PCM
Possible Solutions:
MAP sensor codes include P0106, P0107, P0108 and P0109 .
LOCATIONS:
Manifold Absolute Pressure (MAP) Sensor: The MAP sensor is located against the firewall to the left side of the engine.
Barometric Pressure Sensor: This sensor is installed on the VAF sensor; Volume Air Flow Sensor Is located in the air intake plenum assembly.
Hope this helps.
Jan 24, 2011 | 2001 Hyundai Elantra
My Garmin shuts off in the loading maps screen every time we try to turn it on. It will flash the Garmin logo when it gets turned on, go to the loading maps stage and then just shut off. Any ideas?
first I would try to load the current firmware from garmins website. if that doesnt work then try a master reset by holding the bottom right corner of the screen, holding that and turning it on. it will however erase all user data.
Aug 12, 2009 | Garmin Nuvi 660 GPS Receiver
Nextar mn2707 firmware update
I had this problem too with the one I got from my sister. If you tap your finger in the lower right of the touch screen mine came back on. I think it resets the screen with commands that come back into the screen area. Try that and let me know. Dale.
May 09, 2008 | Nextar X3B GPS Navigation System
Not seeming to read SD map Data Card anymore
I have seen this before, if you turn off the unit while its saving data such as your last position or your last destination, especially if you shut it down while its still navigating. the card data can get corrupted. the only way to fix this is to reload the map data. Fine Digital is out of business so I created a DVD that has the last issue of map data and firmware for these units. you can find this dvd on ebay by searching for finedrive dvd. its way cheaper than what fine digital used to sell upgrade dvds for ( $150)
May 02, 2008 | Fine Digital FineDrive 400 GPS Receiver
Navman S50 wont load maps
Hi, my probelm is very similar I turn it on and it shows a laptop, usb connection and the navman with a usb cable connecting them together,it also has circle running back an fourth
Feb 08, 2008 | GPS
When I turn on my GPS a white screen over a blue screen comes up which never used to happen
tap right hand lower corner of screen to get it to continue loading. I then upgraded the firmware to the P7 and I no longer have any problems with the unit... and it runs faster.
Oct 17, 2007 | Nextar P7 GPS Receiver
GPS Logo
95 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
