Question about JBL PSW-D110 Speaker
Another broken speaker
I think i over played my home sub. i was listening to it kinda loud and now the power light wont even come on and it smells burnt. is this one done for good?
From my experience's, this model is not that good a lot of people have had problems with the amp going bad.
Posted on Nov 27, 2007
How do I get sound from my subwoofer
Need more info, is it powered or passive, is audio making it to the speaker cabinet? Make sure by hooking the wires or cable to another speaker. If you have done that already then it is time to see if if the voice coil is burnt(indicating the sub was played too loud too long). Access the speaker and gently push on the cone. Any resistance or scratchy sound would indicate a burnt VC. Time to replace the woofer. Any other problems you would need to be much more descriptive. Make, model, how you were using the sub when it failed, etc.
Oct 10, 2014 | Audio Players & Recorders
Planet Audio PX1500M Amplifier Problem
Check the FUSE to ensure that current is not cut off.
Jul 16, 2013 | Planet Audio PX1500M - 1500W MOSFET...
I think I blew the fuse on the machine... heard a loud pop followed by the smell of something burnt... Please tell me this can be fixed...
If there was a bang and a burnt smell then you have destroyed the breadmaker. It would be cheaper to buy a new one than trying to get it repaired.
You should have connected the breadmaker to a stepdown transformer from 240 volts to 110 volts.
Nov 25, 2011 | Cuisinart CBK-200 Bread Maker
Hi i have a bnps102 subwoofer system along with a pyle 1400 watt amp. my amp is getting power to it hence the green light lighting up and the subs sounded great but last week during a song they both...
You are right about the scratching sound meaning the speaker is blown. The other one by it not playing it could mean the voice coils in it are blown or burnt.The safest way to check the speaker is to connect it to a standard 9 volt battery and listen for a popping noise when you make the connection and look the see if the cone stands up as long as the connection is made n returns to normal and no noises when disconnected from the 9 volt battery. To test this while the sub is plugged in to the amp but out of the box move the cone as far in and as far out as it will go. If it comes on while u hold it on either one of these positions but when released it goes back to not playing then the coils in it are blown or burnt and is no longer any good. As for selling the box its on you, aim anywhere from 2/3 to 1/2 the price you paid for it minus the speakers.
Aug 22, 2011 | Pyramid Subwoofer Box Dual 10" 1000w ...
My mtx thunder 421d I just got has the red light staying on all the time, I have hooked up a rca converter and the amp wont play my sub, is that light supposed to be red all the time.
The LED should be red. If you are not getting power to the sub, make sure the speakers are connected properly to the amp. Also make sure that the gain control is turned up. If it is all the way down, you will not hear anything from the sub(s). If none of that works, it is possible that you have a blown sub. If you smell a burnt smell near the speaker magnet, there is damage to the voice coil in the sub.
Feb 25, 2011 | MTX Thunder 421D Car Audio Amplifier
Loud noises
your torque converter could have went. i feel its definetly your trans. i need more input
Dec 15, 2009 | 1987 Chevrolet Blazer
My power pyramid sub is smoking i think its the jl 1000/1
If the sub is new, they need to be broken in.
All sub woofers need a break in period of about 5 to 6 hours at medium volume.
The reason is because the glue needs to be cured. This is done by the heat from working.
If you are giving it too much volume too soon, you are burning the glue.
Back off the subs and only play them at medium volume for about a week.
Nov 22, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Amp cut off
Hello there:
Yes you may have overloaded the amp if you still have a warranty with the amp use it if not and you feel that you may want to troubleshoot it deeper yourself
open the amp up and there will be a small fuse that sits on the electronic board that may need to be replaced also while you are in their check the board out real good to see if you see any burned areas or you smell anything burnt this may indicate a fried part on the board ok?
I hope that this has been very helpful for you
best regards michael
Nov 11, 2009 | Kenwood KAC-9104D Car Audio Amplifier
Solo x 10 dual 2 ohm smells burnt and smoke
there is no such speaker as a solo-X L5.
The Solobaric L5 is 450Watts RMS and 900 Peak.
Check your documentation, and no warranty except Massive Audio covers Burned Voicecoils as it is deemed customer abuse.
If it is a typo, and not an L5, your combination (as long as each is level matched) should be ok to run on that sub. When wiring it as you describe, the two amplifiers need to be identically matched in order for both coils to play at the same level.
Seek professional installations so your warranty is intact.
Dec 21, 2008 | Kicker Solo-Baric L5 Car Subwoofer
Da2200w wont kick out sound....
try using another input device for sound like a differert stereo or an ipod or try using another input channel on the amp such as high level or low level please rate -jeff
Aug 31, 2008 | Digital Audio 2, CHANNEL 600 WATTS HIGH...
JBL PSW-D110 Speaker Logo
74 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
