Question about Whirlpool LER4634J Electric Dryer
Whirlpool dryer....heats but not enough to dry the clothes
  • 6,784 Answers
HI, check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Posted on Jul 19, 2009
    President:
  • 512 Answers
You could have heating element going bad, or a plugged dryer vent. Start with dryer vent, make sure all lint is out of it, all the way through it, even if it goes to the roof, or out the wall. Also vacuum out back of dryer and inside vent tube. This should help with problem. If not then replace heating element its getting weak.
Whirlpool dryer does not get hot enough to dry clothes.
Clean/repair the dryer vent. If the airflow is restricted the result is the one you just described.
Good luck,
Vlad
First Choice Appliance
Apr 20, 2010 | Roper REX4634KQ Electric Dryer
Slow to dry
Hi!!
Have you cleaned the filter and the exhaust duct??
Lint plugs therm up, the heat sensor shuts off heating element thinking it is hot enough. Result: Clothes not getting dry.
Unplug duct and clean it, also clean the exahust passage of dryer. (where duct hooks to dryer)
Click below if this was helpful, Good luck.
Mar 28, 2010 | Dryers
Have duet electric dryer model #9200Lw1 dries slowly
are you overloading the dryer, too many clothes would take longer to dry
Feb 03, 2018 | Whirlpool Dryers
Why it take so long for my whirlpool dryer to dry my cloths. When I put in a load of cloths it take about (2) hours to dry. I feel the heat in the dryer, but it not getting hot enough. Could it be the the...
try running the dryer with out the vent hose hooked up.if the dryer works well than you have a blockage some were in the vent line.also be for you pull the dryer out,look behind the dryer to see if the vent line is kinked or massed together.
Jan 24, 2010 | Whirlpool LER4634J Electric Dryer
Have to run dryer twice to get clothes dried
also check the exhaust outside of the house, i had birds nest in mine
Mar 25, 2009 | Whirlpool GEQ8858J Dryer
Gas Dryer Heats up very little, but not enough to dry my clothes
you need to check that for vent hose is not kinked if it is not then remove it from the dryer and see if it work right if it does then the vent tube that goes thourgh the wall has a blockage
Feb 24, 2009 | Whirlpool LGR3624JQ Gas Dryer
Gas dryer runs, cleaned hose, get warm does not heat up to dry
with a gas dryer in which your assured te hventing is free and clear of any obstructions, i would look to replace the coil pack located atop the gas valve itself, probably about $25 part number 279834... 2 coils simply mount atop the valvle
Feb 11, 2009 | Whirlpool Dryers
No heat
ok so you have some heat.your dryer unless an ge one has one element so if you have heat its working.then what you have is an exust problem.once you heat up the clothes and cause the moisture to evaporate then it must be able to leave the dryer or it reclings to the clothes,hence lond dry times.to test this dry a load with the venting undone and the dryer pulled out.dont worry it wont start a fire/never!its about 180 degress to 130 of moist air. if ok then confirms that venting is blocked.some times dryers get blocked internaly also but do the other first.God bless,tom
Jan 01, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool gas dryer is not hot .burner ignights but it is not hot enough
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
if this helps please give me a fix ya vote
Jul 14, 2008 | Whirlpool Dryers
Whirlpool LER4634J Electric Dryer Logo
217 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
