Question about Eureka Whirlwind Litespeed 5740 Bagless Upright Cyclonic Vacuum
New vacuum doesn't pick up....
I just bought my vacuum about 3 months ago and it doesn't pick up. When I try to use the extension it has no suction power. I have to go over the same spot over and over and it still doesn't pick up as good.
    President:
  • 1,486 Answers
Bockage on the pipe bend.open and clean out.
Posted on Jul 19, 2009
Hoover f8100900 will not suction
Here is a site which will guide you through possible causes that are causing the problem with your vacuum and help you pin point the correct one. Hope this helps. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Vacuum-Cleaner/113-203--/Hoover-Vacuum-cleaner-won-t-pick-up-no-suction
Jan 12, 2018 | Hoover F8100900 Upright WetDry Vacuum
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
I have a hoover steam vac F5915-900 I bought at walmart about 4 months ago. I used it about 5 times in differnet rooms. Today when I went to use it It won;t pick up the dirty water. I cleaned the filter...
Make sure the suction area of the face plate is clear of all debris. If anything else, call the number on the machine, it's still under warrantee if the machine doesn't work from normal use.
Sep 05, 2011 | Hoover Vacuums
The 70210 is a few months old. It doesn't ****. There is suction going into the canister, but it's not reaching the hose. I've ensured there's no blockage in the hose, blown it clean with...
IF you can use a broom stick to run through the hose to make sure that there is nothing in it, then you need to check the output filters. They get plugged up with fine dust particles and the suction is reduced. The output filters can usually be rinsed out.
Dec 18, 2017 | Hoover UH70210 Bagless Upright Vacuum
I have the same problem as discussed above. My Hoover Pet Cyclonic upright stops working while using it. The bottom feels hot when this happens. When it first occurred, I emptied the canister and even...
The vacuum is probably getting hot and the thermal sensor in the motor is shutting it off and then allowing it to come back on after it cools down. You mentioned replacing the secondary filters, replace the exhaust filter too.
If replacing all the filters did not solve it you may have a clog or restriction somewhere causing the loss of suction and the overheating.
Mar 09, 2017 | Dirt Devil Hoover Uh70085 Pet Cyclonic?...
I recently ( approx. 2-3 months ago ) purchased a dirt devil. Now it is not picking up properly. When I push vacuum forward it picks dirt up a little bit, when I pull it back all the dirt falls out of...
Hi sounds like your line is stopped up somewhere , check ur suction an make sure your brushes are spinning, if they are try a wire clothes hanger to the hose at the bottom hose to dislodge anything that mite be stuck
Jul 01, 2009 | Dirt Devil Vacuums
NO SUCTION COMING FROM BOTTOM OF VACUUM
even though the belt isnt broken you should replace it also make sure the height is raised up on the nozzle. try dropping a marble through the hose to double check there is nothing stuck ( the attachment hose and the small hose that runs to the floor )
Sep 07, 2008 | Hoover U5507900 Elite Rewind Bagless...
Eureka Boss - no suction in upright postion
when mine does that I find that the hose is not connected properly where it comes off to use the attachments.
If there is suction there, it is a straight shot to the floor unless it is loose where it fits together.
Jun 04, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Not working
If only 2 months old, take it for repair as it is under warranty.
Mar 28, 2008 | Dyson DC18 all floors Bagless Upright...
Eureka Whirlwind Litespeed 5740 Bagless Upright Cyclonic Vacuum Logo
276 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
