Question about Quasar SP-2723 27" TV
Audio not working. A humming sort of sound comes out that can be adjusted louder or softer by the volume control; but the audio itself doesn't work. The TV is directly cable connected to the VHF/UHF on the back of the TV. The sound was working find but the picture was flickering so I removed the back cover and adjusted the VHF/UHF receptacle to better align it with the incoming cable. This fixed the picture problem and the sound was still working fine. However, I must have done something when I tried to reinstall the back cover as it took me a while to figure out how to reposition the circuit board so the cover would properly slide back into place. Now the picture works fine but the sound is gone! Is this a minor problem that requires a slight adjustment?
  • 378 Answers
SOMETHING IN YOUR PCB BOARD WAS LOOSE CONNECTED. REVIEW THE THINGS RESOLDER THE PCB BOARD IN AUDIO CIRCUIT.
Posted on Jul 20, 2009
My Marshal Amp MG50DFX sound is very soft even tho the volume is on max. when I switch on the gains circuit and turn up the gains control there is louder sound, but a humming niose also, what can the...
First of all please check your cables because this kind of problems mainly arise due to cable errors.Second solution is check your input.For an example try a another input from a DVD player or etc.Third solution is ,you have to check your amp's mic volumes,please reduce your mic volume fully.Check you equalizer too,Please check and inform me if it doesn't work
Sep 15, 2011 | Audio Players & Recorders
Ok so 1 of my kidos has the RCA 20F420T tv, and i guess there is no headphone jack hole, so i went and bought adapter that plugs into the av jacks, still doesnt work can you please help!!!
Without knowing the specifics on this adapter - I can provide only provide some clues as to how this works.
Basically, the A/V jacks on a TV has a "fixed" audio output level - this means that the sound levels on the A/V jacks is NOT controlled by the volume control of the TV itself. You should be able to set the TV volume to minimum and then use the adapter's volume control to make the earphone / headphone sound louder and softer. Your TV however, may have a setting in the menu that can change the audio from "fixed" to "variable". If set to "variable", when turning the volume down for the TV's built in speakers will also turn the volume down on the A/V jacks as well. You do not want this to work like that as the sound in the headphones and the TV speakers will be same - instead of the TV speakers being off and the headphones on.
I hope this helps and good luck! Please rate my reply. Thanks!
May 26, 2011 | RCA 20F420T 20" TV
The master audio control is not shown in my toolbar..there is sound but i cant control it.. like i want to make it louder or softer or mute. what should i do?
Hello you can enable this option(showing volume control in task bar).This is how you enable it.You click on Start button and continue to the Control Panel item of the Start menu,then in the Control Panel window find Sounds, Speech, and Audio Devices section, click on it.Then click on Sounds and Audio Devices.In the Volume tab (top line of buttons) you will see a check-box"Place volume icon in the task bar" put a tick on it and click Apply.Now you are done and you should see the volume icon:)
Feb 03, 2010 | Compaq Presario 700 470024-192 Notebook
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
During television programming the volume fades and comes back
Could be a audio compression issue, try looking into the direct audio menu to see if you can set audio compression, this is common on cable box broadcast, could be more so with satellite.
Jan 27, 2009 | Pioneer VSX-D509S Receiver
Sound volume
have you tried a different set of speakers? you should be able to plug them into the headphone jack. speakers without a power supply are softer. my laptops the same way. i use vlc player when i play videos because you can turn the volume up to 200%.
Nov 16, 2008 | Computers & Internet
SA-AK95 volume control problem
This volume controls is actually what is called an encoder. The control itself needs to be replaced. Figure on $5-$10 for the part plus the local labor rate for the total repair cost.
Dan
May 01, 2008 | Panasonic SC-AK75 Shelf System
Microsoft VX-6000 audio problem - static noise coming from speakers
My webcam VX6000 picture is fine, but when i try to talk to anyone or do voice playback there is a loud echo and distortion both for me and the person i am trying to talk to. I have tried everything in support. I am running windows xp.
Dec 27, 2007 | Microsoft LifeCam VX-6000 Webcam
Quasar SP-2723 27" TV Logo
Top Quasar Televison & Video Experts
Radames Pagan
Radames Pagan
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
