I have an old crate blue voodoo amp head that wont work
I have an old crate blue voodoo amp head with matching cab. it used to work great until i couldnt get a sound out of it at all. i changed the tubes in it with the right kind and it still wont work. it will light up and look like it works but i cant get a single sound out of it. i cant seem to find another way to fix online.
heres a picture of the head
http://www.secondhandmusic.se/product_images/F309.jpg
  • 979 Answers
Good day sir, changing the tubes won't solve the problem, sad to say it but you may need to bring it to a veteran technician, that knows tube amps. there are simply lots of things to check for. hope this helps, thanks
Posted on Jul 21, 2009
Crate power head replace fuse how to /
did it blow a fuse or is it just dead?
Aug 02, 2014 | Crate Music
Why does crate blue voodoo 60 blowes fuse when power switch turned on?
because something in it is shorted..shop time.
Jul 13, 2014 | Crate Music
Crate flexwave 120 head effects malfunctioning
That is probably a momentary switch that is dirty and sticking. These onboard effects on guitar amps are usually nothing more than a computer sound card and I've found bad connections going to and from them as well. I do think that switch is dirty and sticking, though.
Feb 19, 2013 | Crate FlexWave FW120H Guitar Amp Head with...
I need a manual for a marshall mg15hfx guitar amplifier
I got mine here... http://www.marshallamps.com/downloads/files/MG4%20microstack%20hbk_ENG.pdf great amp, I bought a used one and it is now my main amp-over my Blue Voodoo 1/2 stack and Line 6 Spuder II!!!
Apr 07, 2012 | Music
I'm trying to add a Digitech X Series EX-7
You CANNOT use the Voodoo as it outputs DC voltage and the EX-7 requires an AC voltage and of 9 VAC and also 1.3 amps at that.
May 07, 2011 | Digi-Tech Digitech X-Series Synth Wah...
I have a crate PA 8 and it makes a crackling noise when I play through it. I hooked the speakers to my other amp and they sound good, I hooked the PA to my marshall cab and it still has the noise, so I...
Hi
The problem is with the amplifier itself. Crackling is usually capacitor related and you will need to have the amp checked over to properly identify the cause.
Some amps are also prone to pick up static from other electrical items which can also cause these problems. I had a crackling issue with an old Crate amp of mine which turned out it was due to being too near a computer/monitor so it is worth eliminating these things as a possible cause before having the amp checked.
Hope this helps. Thanks for using FixYa.
Oct 28, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Crate amp hums when it is turned but can work at times
has th amp got a valve if so the valve may need replacing or might need reseating..
Jul 31, 2009 | Audio Players & Recorders
Crate 100 head. Reverb doesn't work.
Check the input RCA plug going into the reverb tank (silver box with two wires connected to it). Make sure the amp is off when you do this. Sounds like the output is working fine if hitting the amp does it.
Jun 19, 2009 | Crate Music
Crate bv120.no power or sound..no lights..f6 fuse has 160 ohms...
did you change out the fuse? could be a tranny going south. if you change the fuse and you still get no power, then you have a fried power transformer. they are relatively easy to replace. look on ebay . get the numbers off of the existing one and start web searching. something will come up. if not email me on my contacts tab in my website yostamplifier.com we can troubleshoot. you should see the custom blue voodoo i built and gave to my little brother.
Mar 14, 2009 | Crate Blackheart BH15H Handsome Devil...
My Crate blue voodo amp head
Hi...
1st off , check the connections from the head output jack to the speaker cab. If you can get hold of a meter , check the continuity on the cable (center wire to center wire , ground wire to ground wire) both should be about 0 ohms.
Do you have another speaker cab you can try>?
You might have a speaker fuse internal on the amp too OR a secondary fuse on one of the power supply lines
Dec 21, 2008 | Audio Players & Recorders
533 people viewed this question
 Grubhead
Grubhead
