Question about Culligan Under Sink Water Filter
Inoperative Culligan RO water monitor (LEDs don't light up)
We bought a home with a Culligan RO system - maybe 16 years old. The water dispenser is equipped with a good water sentry monitor. There are two LEDs on the dispenser - green for good, red for bad, I guess. I changed the 9V battery, which was dead, but neither LED lights up when the water is running. The plastic box under the sink looks like it has two phone cord jacks plugged into it, along with a circuit board, a dip switch for setting PPM levels and the 9V battery. Any thoughts on what may be the problem? Thanks, Dave
  • 28 Answers
Dave,
If you have concern about the quality of water being produced by your RO system, I would recommend using a handheld or in-line TDS meter. Instead of a red or green LED, these meters will give you a reading of TDS (total dissolved solids) in parts per million (PPM). With either of these meters you are taking a reading from the feed water to the system as well as from the product water, you then can calculate the percentage of solids being rejected by the RO system (using the simple equation listed below). This way you will know exactly how well the RO system is working and when the membrane needs to be replaced. I have included links below to our selection of handheld and in-line TDS meters as well as an instructional video that explains how to use a handheld TDS meter.
Here is a helpful link that includes the formula for calculating percent rejection.
http://www.freshwatersystems.com/t-measuretds.aspx
Handheld - http://www.freshwatersystems.com/c-253-handheld-meters.aspx
In-line - http://www.freshwatersystems.com/c-255-in-line-monitors.aspx
Video - http://www.freshwatersystems.com/t-videos.aspx
Geoff D., CWS-I - WQA Certified Water Specialist
Fresh Water Systems, Inc - http://www.freshwatersystems.com 1.877.335.3339
Posted on Aug 01, 2009
Have an under sink Culligan RO system with 4 potential filters but it only uses 3 (was so installed by Culligan). Filters are labeled - reading left to right Sediment SED10 ...
Pre-filter and carbon block filter are changed annually. The membrane is only changed every 3-7 years depending on water quality coming in, TDS and usage. Fourth filter is an in-line carbon filter that goes on the line up to the RO faucet.
RJH2O
Aug 12, 2011 | Culligan Compatible RO Prefilter AC30AC15...
I own an old Culligan RO system with a particulate filter, carbon filter, RO filter and post carbon filter all connected by tubes in an open environment. Replaced filters and tank is only 3-4 years old...
It is quite common to loose air pressure in the RO over time. At times the tank will be full of water but will not have enough air pressure to push water out. Take the tank of drain as much water as possible, for 3 gallon tank bring pressure in tank to 7psi, for 10 gallon tank pressure should be 10psi.
RJ
Mar 05, 2011 | Culligan Under Sink Water Filter
When we use our sink faucet there is a loud noise coming from our culligan water appliance. Is this a bad connection or maybe the filter has to be changed? The problem has been happening for about 10...
This happens when the cold water is run. As cold water is drawn water is being pulled from the inlet of the RO system. This will cause a whine or squeal from the RO. Install an in-line check valve on the feed line to the RO system. This should alleviate the problem.
RJ
Sep 09, 2010 | Culligan Under Sink Water Filter
My undersink RO system leaks at all four tube connections on the manifold. I inspected the fittings and the o rings are fine. I inspected the tubes and I cut off the ends of each piece to make sure that...
The quick connect fittings need to be fully seated or when pressure is applied they will leak. If the feed is pressure is high to the RO I have seen this occur also. JG John Guest makes a small locking clip that goes on these fittings to hold them tight. Here is a link to JG which shows this application.
http://www.johnguest.com/Home/applications/beverages-and-drinks-dispense/Inch-Size-Accessories/LOCKING-CLIP.aspx
RJ
Sep 05, 2010 | Culligan Under Sink Water Filter
Leak at one of the fittings on my Culligan RO system
Too much pressure in holding tank will not cause leaks in the RO unit. All too much pressure in tank will do is cause low or no product water in RO tank. Older Culligan RO systems (H8, H83, H5) had fittings that used metal locking washers and these can cut the RO line after the RO has been moved around while changing filters. Newer styles (AC30, Water Tower) use quick connect fittings and the RO line may work loose after filter changes and system being moved around under sink.
Turn the incoming water off to RO, turn the water off on RO tank, open the RO faucet to relieve pressure and pull the line off feeding the RO tank, inspect (you may want to cut off a small portion of the line at the filter) check the o-ring and re-install.
RJ
Aug 01, 2010 | Culligan Under Sink Water Filter
How to sanitize ac30 culligan RO sytem?
It helps to sanitize the RO system each time you change the filters. Always test the RO water with a TDS meter to determine if the TDS rejection has dropped below 80% rejection. If it has the membrane should be changed along with the other filters. Always wear latex gloves when changing RO filters to prevent bacterial contamination. There are complete instructions on sanitizing the RO in the Culligan manual. Here is the link for the AC30 Manual.
http://www.freshwatersystems.com/support/AC-30.pdf
RJ
Dec 31, 2009 | Culligan Under Sink Water Filter
Hi, Same pb as davesal6 "Inoperative Culligan RO water monitor (LEDs don't light up)". i do not see how the solution address the question from davesal6. Do you need to have one of the switches turned On,...
The battery is either dead, the TDS meter is bad or there is a bad connection at faucet.
Replace the battery to see and run water for several minutes to see if light works.
RJ
Oct 28, 2009 | Culligan Under Sink Water Filter
How do i connect an RO culligan unit model no 20200112 if someone has a product manual I need to know where the different water hoses go into what connection
The number you gave is likely a serial number, so I am unsure as to which Culligan RO system you have. I have included a link below to a page with several different system manuals, many of which are Culligan.
http://www.freshwatersystems.com/t-manuals.aspx
Jul 17, 2009 | Culligan Under Sink Water Filter
Two led water purity monitor problem
The LED monitor should light up as Green when the membrane is producing the proper water quality (80%+ TDS rejection). If the LED light stays Red this indicates the RO membrane is bad, all the filters (including membrane) should be changed and system sanitized. The batteries in the TDS monitor should be changed yearly also. Don't have a lot of faith in that indicator light. The best way to test for TDS rejection is with a digital TDS meter which indicates the amount of rejection. Compare the incoming water to the product water of the RO.
RJ
Culligan Under Sink Water Filter Logo
656 people viewed this question
Top Culligan Tools & Hardware - Others Experts
Jim London
Jim London
Bill Boyd
Are you a Culligan Tool and Hardware - Other Expert? Answer questions, earn points and help others
