Question about Frigidaire FEF365AS Electric Kitchen Range
We had like a pop and a flash happen with the frigidaire oven near the back. took it out from the wall and the light was darkened black and looked like it could have melted. does this stove have some sort of reset button on it anywhere. mod: FEF376AQJ SER:124972 MD: NOV 26 03
    President:
  • Frigidaire Master
  • 1,922 Answers
No, check input voltage for 120/240volts then remove back cover and inspect all wiring components for hot spots or burned areas
Posted on Jul 28, 2009
  • 4 Answers
The solder on the oven relay melted on mine.
Inside the control, but it also melted the printed circuit on the board.
There should be a sticker on the control head when you take the cover off the back of the stove. Mine is 616207510. It looks like the control head is available from multiple sources starting about $115.
Posted on Apr 14, 2013
  • Richard Wick
    Richard Wick Apr 14, 2013
  • Richard Wick
    typo on the part number 316207510
What do the error codes for frigidaire elite electri clean oven
Hello friend, thank you for your post!
I see you have a Frigidaire wall oven and you are searching for error codes. Do you have a specific error code that your oven is giving you? Also, could I get your model number please? With that additional information I would be able to provide you more assistance. I look forward to hearing from you. -Matt
Aug 02, 2014 | Frigidaire 24" Built-in Single Electric...
Frigidaire FEB24S5AB 24 inch F10
Hello friend, thanks for the post!
I understand your Frigidaire wall oven is flashing a F10 code and not heating up. Based off of that information an F10 code stands for a runaway temperature, which could be an issue with a sensor probe or oven control. It could possibly be a miscommunication with the board and that could be cleared out by resetting your appliance. To reset your appliance disconnect power to it by unplugging the oven or flipping the household circuit breaker for ten minutes. If that step does not resolve your issue and you continue to receive the F10 code I would recommend contacting a technician to come and repair your appliance. I hope this information is helpful. -Matt
Jul 23, 2014 | Frigidaire 24" Built-in Single Electric...
Smh9187w vent fan popping noise
There are no bulletins covering a recurring issue with the exhaust fan on this model, so I would suspect the failing motor, an obstruction in the blades, a loose blade assembly, or a damaged wire arcing to the frame.
It will take some visual inspection with the oven removed from the wall (see your installation instructions) and the cover removed.
The service manuals for the variants are here:
http://www.microwavedisplay.com/smh7185_smh9187w_xaa_sm.pdf
http://www.microwavedisplay.com/smh7185_smh9187w_xac_v1.pdf
http://www.microwavedisplay.com/smh7185_smh9187w_xac_v2.pdf
http://www.microwavedisplay.com/smh9187b_smh9187w_smh9187b_xaa_sm.pdf
You can order Samsung parts from the Pros here or from Encompass here.
Dec 11, 2012 | Samsung SMH9187 Microwave Oven
How to change the element in the oven. I took the old element and I got a yellow wire on one side bu no wire on the other. Is this normal?
this happens alot,, im guessing you took it out by taking the two screws out and pulling it through,, sometimes the wire comes off before it makes it through the hole, you have to take the unit out and take the back panel off to get to it and plug it back in
Jan 18, 2011 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Our Frigidaire 24 in wall oven won't light. The igniter glows but there appears to not be any gas present.
The ignitor is weak and needs to be replaced. You can not tell by looking at it. You have to measure the amp draw through the ignitor.
Sep 01, 2009 | Frigidaire 24" Single Gas Wall Oven with...
FEFL78CQA FRIGIDAIR ELECRIC STOVE
Unplug your power cord from the socket outlet.
remove the back cover where the power cord connection is housed. visually check the connection, expose wire harness might touches the cover somehow. or the cover was dent that causes the bare wire to touched the cover. correct the dent if any, or tighen loose wire.assemble back cover. Reset your circuit breaker to your Stove because the pop sound might trip off your breaker. That should solve the problem.
Jun 28, 2008 | Frigidaire FGB24S5A Gas Single Oven
The clock started flashing as if the power went out. Then when we tried to
The plug receptacle may be bad. Check the plug for proper tension. If feels loose, have the receptacle replaced. Inspect the plug for discoloration. (a sign of a bad receptacle)
May 22, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
FGB24L2ABB Frigidaire wall oven
local outlety to buy rack for oven
jeff
May 20, 2008 | Frigidaire 27 in. Electric Double...
Frigidaire FEF365AS Electric Kitchen Range Logo
283 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
