Broken speaker i have a jbl home subwoffer and the box is broke. when it played it kept rattling and when i took out the cone, the box on the inside, is not all the way glued down. i tried to take the whole front of the speaker box off but the part that is glued down is glued down well. if i slap some glue around the edge will it work or am i just stuck
You will need to put special glue which usally you can get from the stero store or radio shack. If you can not find it you need to get some of the foam glue from home depot and use as liitle as possible
Refit the rubber, you can find itbon eBay, its called reconing actually in this case the cone is the inlybpart wich you dont want to replace... The rattling is beingproducer due to the fact the rubber normally holds the cone ibto positionering over the coils. This rattling is not good can defect your cone. So dont play it roll you got a new rubber fitted!
The voice coil in the big speaker could have been damaged if driven to loud. See if the burnt smell is strongest near the center of the big speaker. If the voice coil is fried, you may be able to still find a replacement as there is a part number for the voice coil (V/C Assy, EON-G2220-27005-00) and the cone (EONG2
Cone Repl. C2REON15P-2)
the braided wires from the speaker connectors to the voice coil could be broken (from repetitive movement) or it could be the voice coil it self that could be cut open from a miss alignment of the cone (ware and tear), delicately push on the cone and feel if it rubs, a simple test is to check the IMPEDANCE of the speaker with a OHMMETER, if you have a reading (4,6,or 8 ohms) than the speaker is fine, check the rest of the wiring, if it reads OPEN than you need a new speaker...
Check the incorporated capacitors (if any), also inspect the braid speaker wire on the bass speakers (i understand that these are cutting out).
The braid wires are located between the speaker connection terminal and the speaker cone - if these are damaged or broken, this can cause the speaker to cut out intermittently. To see if this is the case, try to push the speaker membrane gently inward when the speaker cuts out - if it momentarily regains function, then the braid is almost certainly damaged.
Braid wires can be resoldered, but it's not a very easy task because of the structure of the braid, which makes it difficult to clean and solder.
You should have it repaired by someone with good soldering skills or at a speaker repair shop, otherwise the alternative is to replace the speaker.
ive had that happen to me with 2 12in infinity subs . (my first system) haha i dont knwo what it is but it sounds like a piece of solder weld has broken off in there where the voice coils conect to the cone.. its a manufacture defect nothin you can really do about it without taking it totally apart ... then the hard part is putn it back together .. specially if it wasnt suposed to ba taken apart lol
