Computers & Internet Logo
C
Carol Gee Posted on Nov 05, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix the computer keyboard when the key has swapped with @.
Willem.
Level 2:
  • Expert 359 Answers
  • Posted on Nov 28, 2016
Willem.
Expert
Level 2:
Answers
359
Questions
0
Helped
107539
Points
881
You mean that the " key is swapped with the @ key.
It is often the case when a wrong language is chosen for the keyboard. E.g. English (UK) instead of English (US).
Go to the Configuration screen and choose Language.
Change there the keyboard setting to the one you need.
Keys on my logitech keyboard are not working
Without knowing which type of logitech keyboard it is, I'd suggest borrowing or buying another keyboard to see what the problem might be. The springs sometimes go bad, and it costs money to replace keys at retail prices, but sometimes it is easier to just swap keyboards, or takes keys from an identical keyboard.
Amazon and other online sites sell all kinds of keyboards and deliver them.
Amazon com Online Shopping for Electronics Apparel Computers Books DVDs...
German keyboard layout problem
The uses for mapping your keyboard are numerous, but remapping your keyboard's keys is not for the squeamish.
There are numerous software applications to map and remap a keyboard's keys.
The best part is that the software is free and easily downloadable via the Internet.
So, go ahead and swap those unused keys on your keyboard to suit your computing experience, and make your keyboard more effective without fear of damaging your computer
Place your mouse pointer over a key on the visual keyboard. Notice that the key is numbered.
To see what function the key is currently assigned to, allow your mouse pointer to hover over the key.
A pop-up displays what the key is attributed to.
Left-click the mouse pointer on a key you wish to change.
Click on Choose New Remapping from the drop-down menu.
Select Remap Key from the Control area on the interface.
You may also opt to disable or enable the key, and reset the default for this key.
Left-click Apply. Look at the list box at the top-left of the interface, labeled "Remapped keys currently in effect."
Ensure that the keyor keys you selected are listed in this list box.
Fix a mistake by resetting the defaults.
Click on the top button adjacent to the list box you just visited.
Pressing this button will remove all the changes to your keyboard mapping.
SharpKeys is a Registry hack that is used to make certain keys on a keyboard act like other keys.
http://www.randyrants.com/2008/12/sharpkeys_30.html
Some of the keys are not working like - shift, 4,5,6. And key 'p' takes too much time to repeat
Most likely something was spilled in the keyboard or is not getting a good connection at the USB port. Try swapping ports, if that doesn't fix it, try cleaning the keyboard (unplugged). If all else fails replace, these are fairly cheap keyboards.
2helpful
The keys #one #two arent working....what could be the problem?
Hi:
It isn't uncommon for laptop keyboards to fail, as they are not built that sturdily. The easy fix for you is to swap out the keyboard. They are inexpensive, usually $20 or less on ebay, and not hard to swap out. Even if you don't want to tackle it, buy a new keyboard, and hire a tech to swap it out, and you will be good to go!
I have a stuck key on my lab top computer but i do not know witch one is stuck how do i determine witch key is stuck. this is on my dell latitude c610 labtop
Hi:
There is not an easy way to see which key is sticking on your laptop. The good news is that a replacement keyboard will fix the problem, and it is easy to swap out, and not too expensive. They are usually only about $20 on ebay, and instructions are available too. If you buy a keyboard, and don't feel up to changing it, most computer shops will help you swap it out for not too much cash...
Hope you fix it!
My Key Board is Not Working
The swapping process you have used already have clearly shown that your keyboard is faulty. It may be that a key is pressed down permanently / faulty and this blocks the signalling - check all the keys carefully to ensure none is depressed. Or one of the Connector pins (the part that goes into the computer) is bent - you may need to check and use a tool to straighten it.
But it is good to know that Keyboards are cheap to replace. If the above did not help, you can buy another keyboard for as low as £5 and then continue enjoying your computer.
My keyboard since the computer crashed last week has a few errors. The pound key produces a hash symbol and the @ has swapped places with the" key. How can I fix this. I have reloaded the Windows...
hi there
the default language for the keyboard has changed.
look at the blue bar at the bottom of the screen
on the right hand side you will see the letters EN
click on them and select engkish uk as the default language
you can delete any others and restart the computer
hope this helps
if it does please leave feedback
beergut707
2helpful
5answers
Keys swapped
ok you do not have a bad chip - check you keyboard settings I have both an American keyboard and English upgraded, but like the keys where they were (English settings so i have English keyboard with an American keyboard therfor to get it back (tell me if I am correct please).
go to start In Win XP, to change the keyboard languages and layout, click Start , then choose Settings, Control Panel, and Regional and Language Options. Click the "Languages" tab, then the "Details" button, I hope this helps
Some keyboard keys don't work
you don't say which keys don't work and if the keyboard is more than 1 year old you may open case via the screws in back of keyboard please note down the keys that don't work then the keys that you don't use that often just swap the rubber conntacts on them if yours has the rubber membrain it needs to be sent back to the manufacture of the keyboard to have them replace the membrain but if the keyboard is in warrenty then get it sent back with the details of sale. look for all screws they may be hidden.
Grand Canyon Tech
Grand Canyon Tech
