Question about Toshiba e-Studio150 Copier
Toshiba e studio 150 problem
I recently installed a "Toshiba compitable" toner cartridge into my Toshiba e studio 150 copier. The cartridge seems to fit, but now my copies have a blank space in the middle of the paper. Any suggestions would be greatly appreciated.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Toshiba Master
  • 1,362 Answers
1-The unit that the toner goes in is probably not filling up with the toner or the unit has a problem. open copier take out drum unit and look at the unit where the toner goes into, there is a black roller with toner on it, is there a spot that seems to be missing toner? If yes it will require a tech too complicated to do for a non- tech.
2- If not, look at the black roller on the bottom of the drum unit is there toner there? clean and try.
Posted on Nov 20, 2007
Am looking for toshiba E studio 232
Cartridges have ink/toner? Cartridge bad?
May 26, 2016 | Toshiba E-Studio 232 estudio232
Check the color toner cartridge error message appears. I have changed all the color cartridges. Still same problem. Toshiba e- studio 281c
If changed new toner still showing replace toner cartridge, then probably the toner not able to go inside developer or the developer material is worn out.
Mar 12, 2015 | Toshiba E-studio 281c Copier
Detect installed toner cartridge
Toner cartridge is detected by the toner sensor contacts inside the copier. It is directly in contact with the toner chip when you slide inside a new toner. This sensor has spring contacts touching the toner sensor chip of the toner..
Nov 03, 2014 | Toshiba E-Studio 255 Digital Copier...
Copier wants me to install new black toner cartridge after I installed new one.
for e-studio 350 check if the developer tank unit auger broken or harden with moistered toner hope will lead u to the solution
Mar 03, 2014 | Toshiba e-Studio 350 Copier
Toshiba E-Studio 3511 Check Color Toner Cartridge
there is a sensor above the coloer developer unit clean it or change the sensor
Sep 30, 2009 | Toshiba E-Studio 3511 Color Copier
Toshiba E-Studio 202L cartridge does not match manufacture
Did you replace the waste (used) toner cartridge or the empty toner cartridge? These copiers have 2 "cartridges" .... one is waste (used) toner, the other is "new" toner for copying / printing etc. Some newer copiers have All in One units....Drum, New Toner, Waste (used) Toner. If you replaced the Waste Toner container (or dumped it) that should reset the code or error message.
Jun 23, 2009 | Toshiba e-Studio 202L Copier
Just wanna know
It is not terribly difficult, but you MUST use the correct toner to avoid all kinds of problems
Feb 09, 2009 | Toshiba 2060 Copier
Copier problem
Hope this will give you hints. Original is always better:) Place back any original toner cartridge(s). We'll see the result if there are different outputs. Now, access the copiers maintenance menu and have it print to check all the counters especially life of the drum's unit. Have a nice day.
Best regards,
Rosener
Nov 19, 2007 | Computers & Internet
100 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
