Question about Fellowes 3011001 Shredder
My OC-11cs shredder won't turn on. Nothing happens. It didn't jam or anything - just wouldn't turn onb aqgain after a successful session. Have cleaned paper debris from the bottom, reset all switches, checked power supply. Help!
  • 328 Answers
Have you cleaned the sensors with a dry cotton swab or with a little alcohol. Can you get the top off and check the fuse?
Posted on Jul 22, 2009
Rexel 100X. Why does it work for 2 seconds in reverse only, then jams?
From your description, experience tells me there is something jamming the mechanism. If plastic or clay coated material has been shredded, there will be residue between the grinding wheels that will require use of a utility knife and a pick to remove bit by bit. You will have to apply power periodically to rotate the mechanism and give access to new areas to be cleaned.
Dec 26, 2015 | Shredder Office Equipment & Supplies
Fellowes Paper Shredder PS-79Ci power switch not working -- will not turn on!
Have you looked at the shredder blade to see if anything is still there? Turn power off, check shredder blade, clear anything stuck, put back together, turn power on and try again.
Mar 05, 2014 | Fellowes Office Equipment & Supplies
It just stopped working, power light not on. Is my shredder dead? It didn't jam up. Just tried to turn it on one morning and it wouldn't turn on.
My wife put a plastic bag in the basket to catch the shred.
This will block the power switch on the back - bottom -corner of the shredder. The switch fits into slots on the waste receptacle.
Mar 08, 2013 | Tech Solution TS-4500 Shredder
My handyman took apart my Champion WQ120D paper shredder to remove the checkbook that was jammed. But it looked to him as if some transisters were burned. Once together again, minus a plastic shim at the...
It sounds like the shredder overloaded when you tried to shred the checkbook. If there is a smell of burned electronics this probably means that the shreader is dead. The plastic shims have nothing to do with the turning on and off of the shredder. Next time buy a shredder that is rated for at least 7-8 sheets, indicating a more powerful motor and sturdier blades. If the current shredder was repairable, it would be cost prohibitive over buying a replacement. Sorry for the bad news.
Sep 09, 2011 | Office Equipment & Supplies
My phone turned off randomly and now it won't turn back on,thinking it was dead I plugged it in using the USB charger because I lost the other one...but after plugging it in it still wouldn't turn...
First of all change your battery and try again if nothing happens don't do anything just go to service centre with a photocopy of purchasing bill.
Aug 04, 2011 | HTC Cell Phones
When I put a sheet in to shred, the shredder makes the normal sound but nothing happens. The same thing happens for reverse. This has occured after I had cleared a bad paper jam (there doesn't seem to be...
You dont give make or model???...however it sounds like you may have lost/broken a plastic gear inside..( the normal sound is the motor running??)...open it up to see what has been broken then contact the manufacturer.
This call was logged under "ROYAL" so if it is a Royal shredder you can contact them at 1-800-524-0799 for parts assistance once you know what is broken.
Dec 08, 2010 | Office Equipment & Supplies
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 25, 2010 | Royal 85X Shredder
Shredder will not start when paper is inserted. switch is on auto. This happened after a long session of shredding
Two possible problems;
  1. Teeth underneath lid are jammed; sometimes (especially after a long session) although the papers go through, debris builds up and can get caught in the teeth; to clear unplug and with tweezers or a tina flathead screwdriver, pull out shreds of paper still caught
  2. Motor is overheated; once cool, try it again (move switch to reverse to see if motor is still working). If motor is working, see Step 1 for a jam; some jams can be cleared by running it in reverse. Royal doesn't recommend "long" shredding sessions. My unit recommends sessions of 20 pages or less. If you try to overwork the shredder, it will overheat and in some cases, fry the motor.
I hope this helps answer your problem. Best of luck!
Greg
Nov 12, 2009 | Royal 10X Shredder
SHREDDER WILL NOT POWER UP. NO LIGHTS, NO POWER
you will need to open it and test the on/off switch, door switch, fuse all for continuity. turn the machine off and unplug it . unscrew it from the base. flip it over, unscrew the bottom. now test with a dm. if you are needing a tech i michigan please call 248-677-8112
Oct 23, 2009 | Royal 150MX Cross-Cut Shredder
Fellows Powershred OS-11Cs - not working
It's just the (On and Off) switch not working properly (loose contact). Try to disassemble it and take a look if it's in the center location to make contact with On or Off positions.
Sep 09, 2008 | Fellowes 3011001 Shredder
Fellowes 3011001 Shredder Logo
785 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
