I have an old Thorens TD125 Mk2 turntable with a SME pick up arm. I haven't used it for years and whilst it all lights up, unfortuntately the turnatable does not go round. I can feel resistance on the motor and have tried to help it to revolve but it doesn't want to know. Do I need to fit a new motor?
  • 189 Answers
HELLO
Right, first off I don't know the deck very well in question....this is more advisory. Have a look on the internet at www.theanalogdept.com and you will find many things regarding THORENS decks including links to other websites. Myself, I own a Thorens TD166mk2.
Judging by your posting it SOUNDS like something needs lubricating - not quite sure what though - all depends on where you had it stored. If it was just put into an attic, remember that heat and cold will affect the deck in loft spaces significantly.
If you have any doubts about looking at the deck yourself, then take it to a reputable hifi dealership for servicing.
Posted on Jul 20, 2009
How to fix my thorens TD 158 turntable that doesn't start automatically?
If the device opertated after you moved something then the chances are there is a switch attatched to the device you moved. This might have either got bent out of place or broken completly. Generally removing the bottom cover will reveal the inner workings. Where you can look around for the switch etc.
Sep 12, 2014 | Thorens TD158 Turntable
Turntable must be started by hand
This sounds like the stepper motor that drives the turntable is failing. Are there any good DJ shops near to you?
May 20, 2008 | Thorens TD-170 Turntable
My Thorens TD150 MK2 Phono Turntable Motor will not run or spin with the belt on but will turn without the belt on.What is wrong.
First replace the 0.33 microfarrad capacitor take a 0.47 with the same or higher voltage of a good quality and lubricate the motor top and bottom spindle bearings
sintered bronze buses with a ceramic high quality lubricant spray tecflow or other brand .
The best is to disassemble the motor only the top bearing is never enough also to control the both bearings.
Dec 31, 2012 | Thorens Audio Players & Recorders
Tone arm will not move over on self-start unless
Hi, they are not an auto start model turntable. To start lift tone arm off rest and move into position at start of record. It will automatically lift and return to rest as well as shut off at end of record. cheers john ,, Styluscity.com
Feb 21, 2010 | Thorens TD-190 Turntable
The tone arm of my Thorens TD 160 need adjustment
HI
My advice to you would be go to AudioKarma.org a hifi forum on the web. I'm sure they will point you in the right direction.
Jan 11, 2010 | Thorens TD-170 Turntable
Thorens Motor Replacement
All motors generally work the same, and 95% of them have the same power requirements. However, the only issue you might have is in the actual size of the new motor. If you can get it to fit where the old one sat, then your ok. If not, well, then it wont fit.
- OPTiC
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
www.1200s.com
Jul 19, 2008 | Thorens Audio Players & Recorders
Motor replacement
If the motor can physically fit where the replacement motor use to be, then you should be ok. The TD145 and the TD125 share similar power requirements, but I am not sure about the motor size.
- OPTiC
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
www.1200s.com
Thorens TD-124/II
Well, with a turntable that old, if it hasn't been restored it likely needs to be. Could be the power cord, the motor or the clutch.
Go to this web site for more info:
http://www.soundfountain.com/amb/td124page.html
Jun 09, 2008 | Audio Players & Recorders
517 people viewed this question
 Grubhead
Grubhead
