Question about LG Washing Machines
Washer vibrating badly
My front-loading washer vibrates really badly during any of the spin cycles. It visibly shakes and bounces. It is perfectly level. Help?
  • James Ely May 11, 2010
    Run a cycle without clothes. If it does not vibrate then your loads are unbalanced; try rearranging the clothes/sheets/blankets/ect. If it there IS noticeable vibration there is a worn bushing/bearing, loose motor mount, or bent shaft. Either way, a professional or experienced technician will need to service it.
    Sergeant:
  • 187 Answers
Hi, Try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
pls rate my suggestion......
Posted on Jul 20, 2009
Washer balancing load, during spin cycle wasker shakes and walks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Mar 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Our new GE front load washer shakes/ vibrates and moves during the spin cycle
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Aug 22, 2010 | GE WSXH208A Front Load Washer
My 3431 dryer takes too long to dry and it vibrates badly during the spin cycle.
You have two issues. The cycle time on this unui in the normal mode is 3+ hours. If it is longer than this you have a clogged condensate/dry duct which needs to be cleaned out by an LG tech. The balance thing is a matter of using a level and getting it perfectly level. Once you have done this, if it still bounces check the feet and adjust the one that is not solid on the floor while the machine is bouncing.
Jan 23, 2010 | LG WM3431 Front Load Washer / Dryer
An extreme vibration in spin cycle. It makes the
Because front load washers are VERY HEAVY, they shake if you have a wooden floor. If your front loader sits on concrete and it still shakes, then you have to make sure all is balanced. If it still shakes, then inside the system there are shock absorbers that need to be checked.
Nov 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Washing machine has a seizure during the spin cycle.
Try leveling the washer so that it is about half a bubble biased towards the rear. This usually helps front loading washers balance properly even if the installation instructions say that it should be perfectly level. This can also aid draining problems.
Also, some newer front loading washing machines are simply prone to dramatic vibration even when they is "anti-vibration" or "vibration reduction" systems. You can never go wrong installing an anti-vibration pad under the washer. Good Vibrations Inc, Kellett Enterprises and The Vibration Solution all have good products. The Vibration Solution seems to have figured out the best solution and offers excellent support and return policies.
Washer anti-vibration pads
If all else fails call the retailer and ask for an exchange.
Jun 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer drum shakes excessively during fast spin
y shaped piece that contains the spindle that attatches to the basket and allows it to spin is corroded and cracking. you can't buy just the spindle bracket, you must buy the basket too. you'll be buying the front part of the drum too, if you wait to long.
Feb 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Vibration during spin cycle
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 13, 2008 | LG WM2688HWM TROMM SteamWasher
Vibration
use motorcycle strapdowns and large eye hooks
Aug 19, 2008 | Maytag MAH8700A Front Load Washer
Loud noise during spin cycle
I bought the frigidaire affinity washer. It was quiet until it began the spin cycle, then it sounded like a jet taking off and began to bounce. Come to find out we set it up improperly. You must remove all shipping bolts on the back of the machine and make sure it is level. Ta Da!! it now runs perfectly quiet with little vibration.
May 05, 2008 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
305 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
