Question about HP Officejet 5510 All-In-One Thermal Printer
Paper jam, but i just hooked it up??
I cant figure out how the paper feeds, and ive tried toput the paper in every keeps saying that theres a paper jam andi dont know what to do??? i just got it from my uncle and he never used it
  • MERICA Feb 28, 2008
    my computer is saying that the hp officejet 5510 all in one printer is having a paper jam but I don't see any paper stuck what do i do? HELP
  • 3,587 Answers
The paper MUST be dry and non slick, other wise the mechanism can't handle it..
Posted on Feb 06, 2008
Hp Color Laserjet 1600 says Jam in tray 2 bt there is not paper jams
Open the paper feed area and the printer, examine the paper feed path and make sure there isn't a page or piece of paper jammed in the path somewhere.
Aug 21, 2014 | HP Color LaserJet 1600
I have a hp psc 2355xi and i have a paper jam issue after changing ink cartridges , no paper visibly jammed
hi there!
it may have damaged the feed mechanism, this usually happens when theres a paper jam and we just pull it out. try powercycling the printer (unpug power cord from the printer and from the wall outlet too) leave it for 2mins, plug it back in to the printer first then to the wall outlet. if that dont work, ive posted the link for that printer here, check out the manuals and troubleshooting steps too, they're all for free. you can also contact 800-HP invent or 800-474-6836.
Apr 07, 2011 | HP PSC 2355 All-In-One InkJet Printer
My printer keeps saying there is a paper jam and makes a funny click-click-click noise when I repower it.
There is probably something jamming the cog's that feed the rollers and paper,
If you cant see anything such as a paper jam, then try flipping the printer upside down, and give it a gentle shake.
It's surprising how many times a paperclip or something has fallen into the opening or paperpath of a printer.
Good Luck
Mar 24, 2011 | Office Equipment & Supplies
The roller on the feed tray keeps feeding through eventhough there is no paper there and the panel keeps saying there is a jam
If it doesn't do this with paper in the tray, it's a stuck paper present sensor flag.
If the machine thinks there's paper there, it tries to feed. Since paper doesn't make it to the timing sensor, it shows a jam.
Check for a stuck flag above where the leading edge of paper would be with the cassette inserted.
Mar 04, 2011 | Xerox Office Equipment & Supplies
We have a canon MP490 printer, and it says that there is a paper jam, but there is not. We have tried everything we can think of to fix it, including unplugging it, but it hasn't worked.
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jan 31, 2011 | Canon MP490 InkJet Printer
My Canon PIXMA Pro9000 InkJet Photo Printer paper jam error
Had the same problem with mine. Shook it upside down and cleaned it with air cans after reading this solution for other canon printers:
To my surprise, it worked perfectly... and was great stress relief.
Jul 06, 2009 | Canon Office Equipment & Supplies
My Epson DX4000 Printer keeps getting paper jams and wont print
still printing but the paper goes no further?. It may be the paper is locked by paper feeder mecahnics, Open case, check it, and may be there is something "material" broke.
May 24, 2009 | Epson Stylus Pro 3800 InkJet Printer
Canon pixma mp150 saying paper jam but cant see one
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Dec 11, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
'paper jam' error on canon pixma ip4300
ring canon support on 0844 369 0100
or try
they suggested i do a roller cleaning - but i cant find this option ?
Jun 24, 2008 | Office Equipment & Supplies
Paper jam cant fix it
Try for a re-set. See your manual How you do this can be a mystery because every make model it seems is different. If you have several button to press for various actions try this. Turn the printer off- press any two buttons together and whilst they are pressed switch on- holding the buttons down. Now I do not know how many buttons or combinations you can make on this particular machine so it will be a process of elimination. You could also get onto Canon Tech Support team. A useful site is also
Jul 12, 2007 | Canon Pixma MP500 All-In-One InkJet...
HP Officejet 5510 All-In-One Thermal Printer Logo
126 people viewed this question
Ben Johnson
