Question about Heavy Machinery
Is it BAD for the machine to feed small branches, twigs and leaves into a Vermeer BC900 brush chipper? Thanks
  • 749 Answers
Not for the machine. It may however be dangerous to do so.
Posted on Nov 20, 2017
  • 3 Answers
SOURCE: VERMEER CHIPPER BC 625AI MANUAL HOW TO GET ONE
well if you ring up jhon from vermeer he wll send it out to your address.
Posted on Nov 25, 2009
tunde007
  • 2382 Answers
SOURCE: b c 1ooo brush chipper
Hi, i think you have to talk to Vermeer technical support directly on Phone: (641) 628-3141, (888) 837-6337. They will be in the best position to let you how the tractor is wired and if there is a fuse or relay on it. We basically deal will small automobile..
Posted on Feb 26, 2011
tunde007
  • 2382 Answers
SOURCE: 2009 vermeer brush chipper b3.3
Hi, i think you have to talk to Vermeer technical support directly on Phone: (641) 628-3141, (888) 837-6337. They will be in the best position to let you how the tractor is wired and if there is a fuse or relay on it. We basically deal will small automobile............
  • 166 Answers
SOURCE: how do you change oil in a Vermeer feed roller
I would google the unit model number for oil change instructions, since I don't have the model number I can't do it.
Posted on Dec 31, 2014
Terry Corrow
  • 10875 Answers
SOURCE: why is rpm slow down when feed big logs onBC 1500 Vermeer Chipper
needs service and sharpen blades
Posted on Jul 11, 2015
How do you change oil in a Vermeer feed roller
Dec 31, 2014 | Heavy Machinery
Vermeer wood chipper
if you cant afford to fix it right sell it. its as simple as that
Feb 22, 2018 | Heavy Machinery
Wont run Steady
start by checking and cleaning ground from ground to engine and to computer. it sounds good enough to run but the vibration is causing it to short out.
Jun 17, 2013 | Heavy Machinery
This will sound VERY dumb..... I've got a job in the morn., to help my buddy chip brush(he rented a chipper), not sure what size.. I haven't ran a chipper in apx 18-20yrs. So I don't look like a jackwad,...
Ok so it really does depend on what size. Some have ram feeders. Some have pinch rollers that feed material in. Ok so you know what end first? Like any machine you want to start it first. Same procedure as any gas machine. Turn ignition on. If it's pull start, gas on , choke on and pull. Turn choke off, throttle up. IF it's electric, hit the start button. If it's a small unit (home version not diesel ) then when you pull the cord it won't pull very fast as you have quite a flywheel you must get turning. Be patient and it will start. IF it's real small unit, you'll have to push the branches in. If it says it will grind a 3" branch, the remember that's a straight 3" branch. Have a lopper handy to remove stubborn branches that won't go in the chute. Hope he got a self feeding one, much easier.
Aug 11, 2010 | Garden
I have a craftsman chipper / shredder and it doesn't do a very good job - is there a piece to change or a blade to sharpen?
The blade(s) should have usually two bolts on them depending how many blades you have. Mine only has one blade held on with two bolts and that is only on the side that cuts the larger branches up to two inches in diameter and should be sharpened on a grinding wheel because it has a specific angle to it. The other side that chips smaller branches and twigs it a type of flailer, meaning pieces of metal just swinging around to mash up the sticks and do not need sharpening.
Nov 24, 2009 | Troy-Bilt Chipper Shredder
I have a yard machinne 6.5hp chipper/shredder -
Oct 08, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
if you go on www.vermeer.com you can request a new manual and they will send it out to you.
Oct 13, 2008 | Heavy Machinery
Wood Chipper how to
Great input tina783. I have just one thing to add. Try to shred the branches within a reasonable amount of time. I found out that with my shredder, if I put older, dried up branches in, it tends to take a lot more time, as well as tosses chips back out at you. With newly cut branches, this wasn't nearly as much as an issue.
Aug 27, 2008 | AMANA TOOL 658060 PRESTIGE FINE DADO SET...
Heavy Machinery Logo
803 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
