Question about Maytag Dryers
Maytag MDG7600AWW dryer flame turns off after 15 secs.
I have a maytag MDG7600AWW dryer. The igniter glows, the gas supply is turned on & the flame comes on. The problem is that after 15 secs the flame goes away. After about a minute, the ignitor glows again & the flame fires off but turns off after 15 secs or so. This cycle repeats.
I checked the air vents & there is air coming out from both vents ( Dryer & out of the house).
Since the flame is coming, i believe that the ignitor & flame sensor are working properly & so are the gas coils.
Could the thermostat be the problem? What else could go wrong?
I haven't checked any electricals but they seem hard to get to without removing the side panels. Is that the only way to get to it?
Can someone tell me what to check next?
Thanks.
Washer_tech
  • 164 Answers
SOURCE: Maytag Atlantis MDG7600AWW Not Heating
the gas coils have a problem. as the dryer heats p the coils on the gas valve are failing causing the dryer not to heat. replace the coils and you should have no problem
Posted on Oct 23, 2007
  • 36 Answers
SOURCE: Maytag gas dryer model#NDG2330AWW heating problem
your gas coils are bad. they open up for the first cycle but fail to after. Replace your coils and this will solve your problem
Posted on Jan 02, 2009
SOURCE: maytag gas dryer not heating
You may want to disconnect the vent from the back of the dryer and try it. Flame rollback will cycle the burner off by the high limit.
Considering what you have already done to it, if the problem still exists you probably have bad coils on the gas valve. make sure you replace them as a set.
The thermal fuse is a one time device. If it opens, the burner will not come on at all.
Posted on Apr 29, 2009
  • 67 Answers
SOURCE: glow ignitor works, but no flame ignites. ohmed out gas valve coil with wires disconnected = OL is it my coil?
bad holding coil on the gas valve
Posted on May 18, 2009
SOURCE: starts up and rotates but no heat. It is a gas
check the gas valve coils ,they are easy to replace
Posted on Jun 25, 2009
Maytag gas dryer will not ignite
me id say there is either no gas or hi temp switch has went out
Mar 10, 2016 | Maytag Dryers
My Maytag gas dryer, Model No, LDG7500AAW will run but not heat. The igniter glows red, but the gas will not flow. What might be wrong?
Replace the 2 burner coils ,if the igniter keeps cycling trying to start the flame. If it doesn't replace the flame sensor mounted on the side of the burner tube.
Nov 06, 2012 | Dryers
Maytag LP Gas burner problem
are you sure the pin in the gas pressure regulator under the plastic cap and brass nut was turned 180 degrees to set it for propane gas?
Aug 20, 2012 | Maytag Dryers
When my mdg 6000bww is turn on heating element glows, flame ignites, then flames goes off within 5 minutes. After waiting approximately 15 to 20 minutes, until it seems to cool down can restart and goes...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag dryer does not heat. The ignitor glows hot, and the coils engage (click) which lets the gas ignite, but goes out after about 10 sec. So I figured it to be the thermo fuse at the burner,...
are you sure the vent is open and not lugger? if it can't flow then it may be overheating and that will turn it off. check the vent and inside the dryer as there may be a blockage inside it as well.
Dec 02, 2017 | Maytag Neptune MDG5500AW Gas Dryer
I have a Maytag Epic Z. The dryer turns on but with no heat
There are several things that can cause this. 1 st the thermal fuse(white plastic piece with 2 wires attached to it, then the igniter, is it glowing orange when you start the dryer, then the flame sensor located on the side of the burner assembly and finally the gas coils located on the gas valve close to the burner assembly. If the igniter is glowing orange and then going out without ignition change the gas coils, Hope this helps,
Feb 04, 2010 | Maytag EPICz Electric Dryer
How to check the igniter (continuity?)
If there is power to the ignitor and it does not glow the ignitor is bad. If it does glow,place a clamp on amp meter over one wire of the ignitor and turn the circuit on. If the ignitor reads less than 3 amps,replace the ignitor.
If the ignitor glows and registers 3 amps or more you must check the flame sensor for correct operation. If the ignitor and flame sensor are both good,replace the gas valve coils.
Oct 31, 2009 | Maytag MDG7600AW Gas Dryer
Alantis Gas Dryer MDG7600AWW not staying hot or lit
All you need to do is replace those pesky intermittant coils
aab79a0.jpgI wote a short essay on this problem. To keep from being redundant I have it HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 02, 2009 | Maytag Dryers
No flame
first check that the gas is turned on...then you may have a bad igniter .. if you have a amp meter put it on on wire of the igniter it need to pull 3.3 to 3.6 amps to open the gas valve ... if it does you need a new gas valve...
Sep 06, 2008 | Maytag Neptune MDE6700A Electric Dryer
Dryers Logo
146 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
