Question about Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423
42" SxS Viking Not making ice
While I was out of town, a friend of mine put some food in my freezer. When I got back, I realized she didn't close the freezer door completely. I dumped the ice in the bucket and now it is not making ice. Can you please help?
Thank You
  • 3 Answers
My son left the freezer door ajar one morning; by the end of the day, the heat exchanger turn into a block of ice (in trying to cool the space, the compressor was on all day and freezes up the moisture in the air on the heat exchanger).
I had to turn off the fridge, de-install rear panel to gain access to the exchanger, and pour hot water on the ice to hasten the melting process (use lots of towels). Next step was clean up and turn the fridge back on. all was fine.
Posted on Feb 26, 2013
  • 6,826 Answers
You may have to unplug the the unit and thaw it out with a hair drier,and get everything dry.Then close it up and set the temp,and plug it in.It will take a while before it will start producing ice again normally.If I can help,let me know.
Posted on Aug 20, 2009
  • Ronny Bennett Sr.
    Ronny Bennett Sr. Aug 20, 2009
  • Ronny Bennett Sr.
I have a viking Refrigerator Counter depth with bottom freezer. The condenstaion pan fills up and overflows every several months. Now the refrig. will not cool. I am not sure if they are related. Any...
i would defrost it first, while you are defrosting it clean the coils if it has them some fridges its incorporated into the outer skin of the fridge ,you want oil the fan in the freezer and make sure the (if it has ) coil fan is working.. wipe the inside down dry ,a fan helps speed things along during the defrost, cycles defrost can get screwed up if you have left the door open on the fridge,unscrew light bulbs and put them to the side(to see if this is part of the problem, instal them the next day.check switches to make sure they turn off ,door closed) or it is in high use in high humidity area,hot pans,food.. vikings are a kool product , but only do what there made to do. if you try to use this for food service (commercial) it's going to be a pain, viking makes ones for that app... hope this was of help..jay the electric motor repair guy in longwood florida
May 26, 2011 | Viking 36 in Designer Series Freestanding...
Our new 48" Viking side by side does not feed ice cubes adequately. If you need several glasses of cubes it stops feeding and when one opens the freezer door they are piled up and fall all over the floor....
I experienced the same problem several times with our VCSB483DSS also.
What I found was that the ice come down the chute side way and got stuck at the flap in the door. As you continue to press for ice, the machine pushes more ice & they all back up in side the chute and in the door, ready to dump on unsuspecting person who open the freezer door.
I think the the problems are:
1 - over application of foam insulation in the chute pathway in the door.
2 - possible bad timing on the flap opening causing the falling ice to get stuck.
My solution for the past 6 years:
1 - clean out the over application of foam insulation - this reduce the incident frequency from once a month to once or twice a year.
2 - inform my family member that if while you pressed for ice, and the ice is not dropping, but you hear the motor still cranking away, stop pressing for ice immediately. Stick you finger up the dispenser to make sure the flap is open, and push the ice to un-stuck them. And finally, be prepare to get 2 cups full of ice.
Viking may make professional quality fridge (13 years experience in restaurant business), but ice & water dispenser is not their strong point.
Oct 09, 2010 | Viking 42 in Built In Professional...
The freezer stopped working but the frige seem fine. no ice build up on the defrost timer.
No model # given to reference the symtoms. I would surly worry if you had ice buildup on the defrost timer. Some are in the fresh food side and some are outside the compartments. Extreamly rare to have one in the freezer.
Also if this is a standard SxS or top mount system...everything that happens in the fresh food section, happens because of the freezer. Air moves from the ff side to the freezer. The air is cooled down and recirulates back through the freezer and to the ff side. Issue could be ...evaporator fan bad or low RPM, freezer door switch, cold control not cycling on / back on. Compressor intermittantly cycling / bad start device / weak compressor, condenser fan slow or not cycling...should be on anytime compressor is running. Some of these items can be visually checked, some require advanced knowledge and a multimeter for test. Be careful of live voltage and sharp edges.
Ric
Mar 01, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
The refrigerator is not cooling
If your freezer is frosting up, fresh food section is warm: bad fan motor,defrost drain stopped up and forming slab of ice between the freezerand the fresh food section. Check heaters andterminator(defrost thermostat) unplug the ice box and let it defrostcompletely. Clear objects from drain. Check timer. Note to find thelocation of your timer look up your model number online here: APPLIANCEPARTSPROS.COM.
Check under the bottom for the fan motor to be running and the cobwebs, dust, dirt, and pet hair, off the condenser coils. If the fanunderneath has quit then the ice box won't get cold. BASIC REFRIGERATION REPAIR MANUAL
AMANA SxS REPAIR MANUAL
BOSCH MANUAL
Monogram Manual
KitchenAid SxS with variable capacity compressor
GE LATE MODEL SxS MANUAL
F&P Reefer
Jan 11, 2010 | Maytag Refrigerators
HOW DO I DEFROST FREEZER
Most modern freezers don't need to be defrosted, but should be washed out and cleaned periodically. Following are steps for defrosting freezers that need it -generally when ice builds up to a thickness between 1/4 inch and 1/2 inch.
  1. Step 1 Turn the freezer off. Controls may be inside the refrigerator.
  2. Step 2 Remove all food from the freezer and store in an ice chest while you are defrosting.
  3. Step 3 Remove ice in the freezer compartment. This can be done by: a) letting the freezer door stand open until ice melts; b) putting a pan of hot water in the freezer compartment and closing the door, then checking for melting ice and reheating the water every 10 to 15 minutes; c) using a hair dryer by aiming warm air at ice in freezer until it melts.
  4. Step 4 Pick up ice and water as it melts with a dishcloth or sponge and deposit into sink.
  5. Step 5 Use a sponge or dishcloth and a bowl of warm water to thoroughly wipe out inside of freezer once the freezer is cleared of ice.
  6. Step 6 Turn the freezer back on, close the door and let run for 10 to 15 minutes before returning food to the freezer.
  7. Step 7 Put food back into freezer and close the door.
You can also look at the Video :-
http://www.videojug.com/film/how-to-defrost-a-freezer
Hope i helped you.
KINDLY RATE THE SOLUTION IF 100% SATISFIED.
Thanks for using ' Fixya ' and have a nice day!!
Sep 06, 2009 | GE GSS25JF Side by Side Refrigerator
Had a service rep come to house states that the alarm has to be ringing for him to tell me what the problem is . the frige 42 sideby side viking is not making ice or keeping anything cool
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
thumbs up
Aug 17, 2009 | Viking 42 in Built In Professional...
No ice
put your finger into the mold of the icemaker or get a mirror and see if there is any water in it, if not, pour 5 oz. of water into the mold and wait approx. 2 hours, if ice dumps out then you have a water supply problem. the fill tube line entering the the mold could be iced up, if it is then your water valve maybe leaking and freezing up. also the water valve may not be opening up and may need to be replaced if it still doesn't dump out the water you poured in the you will have a problem with the icemaker itself
May 07, 2009 | Viking 42 in Built In Professional...
GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost in the freezer
IS IT ICE OR FROST? IF IT IS ICE, THE DOOR MAY HAVE BEEN LEFT CRACKED OPEN.
IF IT IS FROST, IS THIS A FROST FREE FREEZER?
IF YES, IS THE FROST ON THE BACK WALL?
IF YES, THERE IS A DEFROST FAILURE AND YOU WILL NEED TO TROUBLESHOOT THE DEFROST CIRCUIT.
IF THE FROST IS ON THE FOOD OR AROUND THE DOOR OPENING, A SEAL LEAK HAS ALLOWED WARM MOIST AIR INTO THE FREEZER AND CREATED THE FROST. CHECK THE DOOR SEAL FOR A GAP WHEN CLOSED.
Mar 24, 2008 | Freezers
Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423 Logo
104 people viewed this question
Top Viking Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
