Home | Maytag | PYE2300AY Electric Dryer | My Dryer Maytag PYE...
Maytag PYE2300AY Electric Dryer
Problem for Maytag PYE2300AY Electric Dryer
My Dryer Maytag PYE2300AYW is dead
By rorrinita on Jul 19, 2009
My dryer is dead. If the thermal fuse is the cause, how can we test it? We also found another switch by the blower completely cover with lint, the p/n is listed as 53-2880 but I can't find any information on this switch to find the name of it and to see how it functions.
Best Solution
posted on Jul 19, 2009
Very Helpful)
meola64
Rank: Guru
Rating: 88%, 141 votes
You can test with a tester, just like you would test a car fuse, red on one side black on the other. If you dont have a tester, you can use a piece of wire, jump from one side to the other, do one thermal fuse at a time. Then plug in dryer and see if it works. When you find bad one, replace dont leave jumped you can a fire.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
Very Helpful)
localwonder
Rank: Guru  Maytag Expert
Rating: 92%, 2769 votes
HI. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Concerning the Control Thermostat(53-2880). This is the main control thermostat. if it is covered in lint as you have sated, this will confirm thermostat failure. this has tripped the thermal fuse in this case, totally rendering the dryer inoperable at this time. you will need to replace the Control thermostat and thermal fuse as well. this will fix your unit.
The thermal fuse can be tested be using a basic voltage needle but, it is really not needed. the thermostat has failed. the over cover of lint has shorted the device(lint will create an arch that will ruin the device)
Once the thermostat failed, the heat will rise to a unacceptable rate and, this will trip the thermal fuse and kill the dryer. its a safety feature to prevent a fire in your home.
Was this helpful?
Yes
No
Solution #3
posted on Nov 06, 2009
Not Rated)
craigslover9
Rank: Apprentice
Rating: 0%, 0 votes
Try this appliance parts store web page http://www.partsreadyonline.com/item.php?ItemID=87
Although this dryer thermostat is used, it is genuine Maytag part (Dryer Cycling Thermostat 53-2880) and cheap with pretty reasonable shipping charge.
Was this helpful?
Yes
No
Popular Solutions for Maytag PYE2300AY Electric
Questions and Unsolved Problems for Maytag PYE2300AY Electric
Do you recommend Maytag PYE2300AY Electric Dryer?
Answer
Answer
i received a free dryer, a maytag atlantis model# mde6400ayw. Upon trying to hook up the cords I... (More)
Answer
How to Replace a Broken Drive Belt in a maytag pye2300ayw Clothes Dryer?
Answer
my dryer is was working and then just stopped
Answer
i have a maytag mde6400ay...when i pull the timer knob to start a cycle, it won't start...i know... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Maytag PYE2300AY Electric...:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14709
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
