Question about Amana Kitchen Ranges
Amana model ARG7302LL oven will not light and
Amana model ARG7302LL oven will not light and temp was of by 100 degrees the igniter lghts up but no gas flow is there a thermocouple?
aborcass
  • 2651 Answers
SOURCE: low oven temp.
sounds like a bad oven/bake ignitor. very common problem on all gas ranges.
Posted on Oct 21, 2008
crayzeetrayn
  • 837 Answers
SOURCE: temp stuck on 100 degrees
try unplugging the range for at least 30 minutes
Posted on Feb 08, 2009
SOURCE: amana ACS3350AS stove temp in oven stays at 100
We had the same problem and it turned out to be a burned out lower heating element. Only the top one was heating and I could never get it over about 150deg or so.
Posted on Mar 24, 2009
Greg20
  • 149 Answers
SOURCE: Amana electric oven won't get above 225 degrees.
sounds like only the broiler is working which comes on low during bake cycle. unplug or turn off breaker, remove bake element and check for continuity or take to someone who can.
Posted on Jun 13, 2009
aborcass
  • 2651 Answers
SOURCE: Amana stove, oven igniter works but oven wont light
although the bake ignitor appears to be glowing, it probably does not glow with the intensity it needs to open the safety valve assy, VERY common problem, go aheadand replace the ignitor, this will correct your issue
Posted on Feb 09, 2010
Testimonial: "100% correct, I ordered the part from on line and it was a very easy fix and the oven is working great. Thank you"
I would like to replace the oven door on my Amana gas range model ARG7302WW, is it possible?
Yes, its possible.
Remove the door from the range.
Place the door on a flat surface with the front facing down.
Remove screws held the inner door panel.
Remove the inner door panel and you should get access to the door handle screws.
- Here are the break down diagrams for the Amana range Model ARG7302LL
Jun 04, 2008 | Amana Kitchen Ranges
Amana Model ACS3350AS Oven temp is 25 degrees hoter than display. What do I need to repair it? How do I find a manual for this. This came with the house.
Oven temperature can be adjusted for a maximum of 35 degrees farenheight.
Refer to the page 11 of your owner's manual.
A PDF version of the owner's manual can easily be find at
http://shop.amana.com
Jan 11, 2011 | Amana ACS3350 Gas Kitchen Range
Amana oven will not ignite
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jul 22, 2010 | Amana Ovens
Have Amana Gas Mod ARG7302LL S/N 98101818Range. Seems the oven takes longer than usual to come on. Possible Igniter?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 29, 2010 | Amana ARGS7650SS Gas Kitchen Range
Oven sometimes doesn't heat up. Sometimes heats up to desired temp, then quits working. Sometimes doesn't even heat up at all. When preheated light comes on, thermometer in oven usually says about 100...
This sounds like a weak igniter, it would have to be a gas oven and the symtoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 14, 2010 | Amana Ovens
Amana ARG7302LL Gas Oven won't light ... how to troubleshoot issue?
Oven Problems Replacing the Igniter
heatman101
fjsj
Nov 03, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Amana ACS3350AS stove temp in oven stays at 100 degrees . takes 1/2 hour to light or get to set tempeture. replace senor temperature and control panel. what should i do now
Mar 16, 2009 | Amana ACS3350AS Gas Kitchen Range
Temp stuck on 100 degrees
Feb 08, 2009 | Amana ACF3355AS Gas Kitchen Range
Kitchen Ranges Logo
160 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
