Posted on Jul 19, 2009
My cinego is stuck on search mode. From the moment it turns on it starts searching as if I was holding the searching button down . The modes all run but search will not stop.
Anonymous
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Jul 20, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
0
Helped
3458
Points
15
Try unchecking the "auto source select" box. Push the setup button on your remote (bottom row, second from the right), use the arrows (7, 0 , 9, or 5) to move across to "management" and down to "auto source select." Make sure it is unchecked (by higlighting it and pressing Enter, which is the 8 key).
Frigidaire refrigerator stuck on Sabbath Mode
Depends on model. Generic advice in the link and videos. You can effect a power reset by pulling that wall plug for 30 minutes.
Sabbath Mode is turned ON and OFF by pressing
and holding both the freezer "? Down" and refrigerator "? Up"
indicators for five (5) seconds. The display shows "Sb"
while in Sabbath mode
https://www.google.com/search?q=how+to+turn+off+sabbath+mode+on+frigidaire+refrigerator
PLEASE HELP TURN OFF SAFE MODE
To get turn off Safe Mode, please try the following.
1. Touch and Hold the Power key.
2. Tap Power off.
3. Once the phone is off, Touch and then Hold the Power key again to restart.
The phone should now be out of Safe Mode.
However, if the Safe Mode is still running after you restart your phone, I would then check to make sure your Volume Down button is not stuck. Check to see if it has anything stuck in it as well, dust, etc. Anything like this can cause the phone to go into, and get stuck in, Safe Mode.
If that doesn't work try this...
Use the Status Bar to turn off Safe Mode. Pull down (swipe) the status bar of your Samsung Galaxy S6. Now tap the "Safe Mode" button. This should turn Safe Mode off. Now your phone will automatically restart, so that it boots up out of Safe Mode.
Hope it helps you:-))
https://rankupplabs.com/
1helpful
Hw to get safe mode off a Nextbook tablet
To get out of Safe Mode, please try the following.
1. Touch and Hold the "Power" key.
2. Tap "Power Off".
3. Once the tablet is off, Touch and Hold the "Power" key again to restart.
The tablet should now be out of "Safe Mode".
If the "Safe Mode" is still running after you restart your phone, I would then check to make sure your "Volume Down" button is not stuck. Check to see if it has anything stuck in it as well, dust, etc. Anything like this can cause the phone to go into, and get stuck in, "Safe Mode".
Use the "Status Bar" to turn off "Safe Mode'. Pull down (swipe) the "Status Bar" of your phone. Now tap the "Safe Mode" button. This should turn "Safe Mode" off. Now your phone will automatically restart, so that it boots up out of "Safe Mode".
And lastly...
If you want to get rid of/disable "Safe Mode".
1. First turn off the tablet.
2. Next press and hold "Power" until you see the manufacturers logo on the screen, then release the power button.
3. "Quickly" press "Volume Down" and hold it for few seconds until you see the message "Safe Mode: OFF" or something similar.
4. If you wanted re-enable it, simply repeat the steps above, and you should see "Safe mode: ON" rather than off.
I’m happy to assist further over the phone at https://www.6ya.com/expert/latoya_8ed1bf3dc615c15d
4answers
My ipad is stucked.
This tutorial will explain how to force your iPad to restart if it gets stuck or freezes up.
Forcing your iPad to restart will not cause any loss of data - with the possible exception of any work you were doing at the time the iPad and/or App froze, forcing you to restart it.
Click and hold down the Sleep/Wake button (located on the upper-right corner of your iPad). While you're holding down the Sleep/Wake button, hold down the Home button as well (located on the front of your iPad at the bottom). Hold down both buttons until your iPad powers off. It will reboot and start again with a small silver Apple image on the screen. It takes about 30 seconds for the iPad completely start up.
6helpful
3answers
I have a motorola android phone. i goes to cool down mode and does not come back. Any solutions?
I found out the solution to this problem by accident, and there doesn't appear to be a solution anywhere else on the internet. Turn off your phone and restart it. As soon as you are able to do so, open up setting, or any other app. When your phone goes into cool down mode, hold down the home button. A screen will come back asking you to select an app. Select whatever you opened prior to cool down mode (If you need to get into settings press the search button and search for settings after your out of CDM). You then need to do two things. Go to Running services (Settings>Applications>Running services), find detect battery service, touch it and stop it. To the best of my knowledge, it doesn't do anything to your phone, other than activate cool down mode. Then go to manage applications (Settings>Applications>Manage applications) press your menu button and select filter> all applications. Find Battery protect, click on it, and select force stop. This allows your phone to get reception. You will have to do this every time your phone starts up, but it isn't too much of a hassel for a truely excelent phone. The Cool down mode problem is definitly a software fault.
9helpful
I have a Sony RDR-GX360. Some how I have changed the command mode from DVD1 to DVD 3. Now my remote has frozen and I can't do anything with the DVR player. Is there a reset button or please help.
To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
get away from player different room so it can not sence remote. Hold down enter and 1 button for 3 seconds and then try it
if its stuck in dvd-2 mode dold down enter and the number 2 button together for 3 secondsd and try it. The idea is you have to be far away from the recorder so it dosent recieve any inputs from the remote while doing this.bigsmile.gifclap.gifagreed.gifpuh2.gifbowdown.gifeek.gif To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
Hp pavilion s3015 goes to sleep at startup and does not recover
Shut down the PC by manually powering it off by holding the power button in until it is off. Start the PC. Does it boot correctly? If so, turn off all the Vista power modes.
Click on Start and in the "Start Search" block type "Power". Click on "Power Options" which should show up above the Start Search area. Put the dot in "High Performance" then click on Change Plan Settings, Change Advanced Power Settings, Click on Power Buttons and Lid, Start Menu Power Button, Click on "sleep" to reveal the other settings - select "Shut Down", then "Apply" then "OK". Close all open windows and shut down the PC using the Start button. Note the power button icon is now RED not amber as before.
Run the PC in this mode and see if the same problem occurs. If so, you have a different problem.
Apex44
4answers
I have a blackberry curve and am wanting to pair my bluetooth HS850 to it. Please help!
There actually is a trick to the HS850 - flip the boom closed, then hold down the button just until the light holds solid - IMMEDIATELY after it does flip the boom open and this should keep the light solid. Then on your cell/device search for bluetooth devices - you should be able to find it now. Passkey for most devices is 0000.
I have problem wiht Cinego D-1000
While it is frozen on that "Searching" screen, hold the SRC button down on the actual projector for an extended time. Then after letting it up, hit it briefly one or two times until it finds a source. Make sure that under Projector Setup/Management/ "Auto Source Select" is checked. This brought my Cinego back from the dead.
Top Radio Shack Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
