Question about Ruud UBHC Air Conditioner
I have a UBHA 17J11 Nuda a/c unit. Where is the furnace filter?
  • 614 Answers
Pull the bottom panel off and it should be inside.Russ
Posted on Jul 20, 2009
What are the tons of a RUUD AC HANDLER MODEL UBHA-17J11 SO SFFA SERIAL NUMBER MOO500 03485 and what type of CONDENSER & TONS CAN IT HANDUE WITHOUT PROBLEMS?
You can find the tonnage in the model number which increases by increments of 12, so if the model number is 24 =2 tons. Model number on your a/handler is 17. Thats a ton and a half. Really should match the evap and condenser for the best efficiency. ...
Sep 24, 2015 | Ruud Heating & Cooling
Direction of flow air conditioner filter
There are quite a few possible answers to this because you did not specify what type of unit you are asking about: Central Air, Window unit, Stand-alone-upright Unit, etc.
If this is a central-air unit or a unit that uses your furnace blower to circulate air, then in most cases the filter is a square or rectangular shape and is between 1 and 4 inches thick. The "Direction" the air flows through the filter is indicated by a set of arrows printed on the thin edge of the filter - usually with the word "flow" or "Air flow". Insert the filter with the arrow(s) pointing toward the furnace/blower. Another way to determine flow direction is if the filter has a mesh or screen on one side of the filter media. In this case the screen or mesh would go toward the furnace/blower when the filter is inserted.
Sep 13, 2014 | Heating & Cooling
Ruud ubha-21j00nuaa
Can you see the condition of the coil itself? If it is blocked this could be a cause for the frozen coils. Also, check the condition of the blades on the indoor fan. Dirt and dust accumulation on the blades reduces airflow.
Jul 14, 2014 | Ruud Handler Air Conditioner
UBHA-14J10SFDA
We will need a little more info in order to help you.
Is it a heat pump, furnace or A/C?
Although there is a recognized standard for wire colors and where they get hooked to, there is no guarantee that the installer followed the standard. More important would be if you would tell us what terminal letters you have at your thermostat and the type of system that you have.
That it would it easy for us to hlp you.
Nov 20, 2011 | Heating & Cooling
My son has a Rudd air conditioner Model UBHC-17J11. Where is the filter located?
If you pull the bottom door off, or where the blower motor is, the filter should be with
sight.
Aug 28, 2011 | Ruud UBHC Air Conditioner
Where are the furnace filters in my older furnace?
Open the door to the airhandling unit inside the closet by lifting upward on them. There should be two filters located on top of the A coil.
Dec 05, 2009 | Heating & Cooling
I just had the furnace installed six months ago and have used the air condtioner over the summer but never the furnace. When I went to change the controls for the furnace use, the blinking ''change...
Hi, sometimes depending if the unit is an up flow or down flow that depends where they put the filter.If you don't have a return grill in the ceiling, then it would be in the bottom of your furnace. I am sure its hard to remove as it is new, but i am sure it is there.Sometimes there is a grill on the lower wall beside the furnace they could have put it in. They may not have installed one? Good Luck, Sincerely, Shastalaker7
Nov 27, 2009 | Heating & Cooling
Where is the furnace filter located on the York P3CGD12N08001B
Residential furnaces have exterior filter boots supplied by installer, commercial york units have filter access doors. If this is a roof top unit your filters would be in the door to the left of the blower compartment.
Nov 18, 2009 | York Yankees Bedding MLB Comforter
Central air conditoner unit doesnt blow cool air into home has some ice on the inlet heat and cooling lines going into the central air unit
Change the furnace filter. Make sure you use a cheap one when air conditioning, as the better ones restrict airflow when they filter out so much stuff and then plug up, not allowing enough air to pass over the cooling coil in the furnace's air plenum. Turn the A/C off for a few hours (with only the furnace fan on if possible) to melt the ice off the cooling unit inside the furnace.
Sep 01, 2008 | Carrier Heating & Cooling
Filter Placement Ruud UBHA
hey brad first you need to indentify wich is your supply and wich is the return after you have done that the filter is allways on your retun side however not allways is the filter set up at the air handler sometimes its in a duct sytemn on the ceeiling or wall hope you find it
Jul 05, 2008 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
363 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
