Question about HP Officejet 5510 All-In-One Thermal Printer
REPLACING INK CARTRIDGS
I REMOVED THE CARTRIDGES AND PURCHASSED NEW CARTRIDGES. I CANNOT INSERT THE NEW CARTRIDGES
PLEASE SEND DETAILED INSTRUCTIONS
Where do I install the cartridge for the HP 5510 All in One - can't find where they go...............
  • 13 more comments
  • Herschey Nov 19, 2007
    My Officejet 5510 more often than not tells me that the phone is unplugged. I know it is not! I cannot use the stupid thing until the message "goes away". How can I fix this?
  • Anonymous Nov 23, 2007
  • Anonymous Dec 11, 2007
    bcjkwbcjkebck.e
  • Sunfluer Mar 18, 2008
    I can't insert the 58 photo color cartridge in HP 5510 all in one. Help!
  • Anonymous Mar 25, 2008
    change cartridge
  • PiaHodge Mar 28, 2008
    my officejet 5510 is out of black ink. I do not know where to start with replacing the ink cartridge as i cannot work out how to open it or where to look. I also cannot find the instruction manuel so am stuck! How do I replace the ink cartridge???
  • Anonymous Apr 05, 2008
    where do you install cartridge?
  • Anonymous May 13, 2008
    how to open door?
  • longshots Jun 10, 2008
    I don't know how to install new black ink cartridge on 5510. Came with the business and can't find manual.
  • Anonymous Jun 18, 2008
    nothing
  • Anonymous Jun 27, 2008
    HI I am not sure where to pull the door open for the HP Officejet 5510 to change the ink cartridge - can you post the answer as it seems I too have downloaded the Manual and it does not have this. Which would be common sense to have in a manual they have everyone else.
  • pcsandy-joan Jul 05, 2008
    do not know how to change cartridge
  • Anonymous Jul 21, 2008
    How to replace ink cartridges on HP officejet 5510?
  • Anonymous Nov 20, 2008
    I dont know how to replace me ink cartridge
  • johndedoes Nov 21, 2008
    bought a new cartridge, but cannot find the place to install it!!
For HP 5510 series for replacing the cartige, you need to lift the door just above the paper tray. Pull out the old cartidge, hold it so you can see the way it is inserted and click in gently in the same way.
Posted on Nov 26, 2008
I cannot remove the cartridges to my 5610 officejet all in one
Posted on Feb 05, 2008
Cartridge error
Posted on Jun 08, 2008
Directions for inserting ink cartridges
Replacing the Ink Cartridges for Deskjet 6940 and 6980 ...
support.hp.com/us-en/document/c00569593
Selecting the correct print cartridge, and removing and installing print cartridges. ... Damage may occur to the HP Deskjet printer if the print cartridges are not docked ...print cartridges, or continue to the sections below for detailed instructions.
Replacing a Cartridge - HP Deskjet 2540 All-in-One Printer
www8.hp.com/.../printers.../replace-ink...toner/.../replac...
Hewlett?PackardLearn how to replace a cartridge in the HP Deskjet 2540 All-in-One printer.
Replacing a Cartridge - HP Envy 4500 e-All-in-One Printer ...
? 3:56
https://www.youtube.com/watch?v=oJVYTXaI6e4
Jul 11, 2014 - Uploaded by HP Printer Support
The HP Instant Ink program is only available in the following countries - United ... ... Replacing a Cartridge - HP Envy 4500 e-All-in-One Printer ... HP ENVY 4500 WIRELESS SCANNERCOPIER REVIEW - Duration: 13:52.
Jan 16, 2016 | HP Office Equipment & Supplies
Why after installing new ink cartridges, the system says to realign scanner. never saw this before.
Realignment procedure is typical when replacing ink cartridges. It is a pretty straight-forward process and takes only a few moments. Most printers provided detailed instructions on the alignment page it prints - otherwise Google your printer for instructions. Alignment ensures that there are no gaps or white lines in text or images.
Jul 14, 2015 | Epson Artisan 810 AllInOne InkJet Printer
How do I install the ink cartridge
You will find two buttons on your printer.
One for power and the another is a function button.
Push them together at the same time while the printer is on.
In most cases this will move the ink head to the center on the machine in order for you to remove the old ink cartridges and install the new ones. However a different button may need to be used consult the manual in this regard.
The ink cartridges are clipped in, you will need to undo the clip!
Then pull the ink cartridge out, usually upward force applies.
Now once the old cartridges are removed you can install the new cartridges.
Be sure to remove any stickers that are meant to be removed, read the sticker and if it says "remove before use" then remove it.
Insert the cartridge and push them down, then the clip is to be clipped in.
Now to get the ink head to move back to it's lair first try pushing the function button.
If nothing happens then push both buttons together again.
Please read this session a number of times to get the jist of what needs to be done.
Also I would like to ask you to please rate this session with the use of the Thumbs on the right.
Thanking you very much.
Till next time!
damnor01
Mar 20, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Cant figure out how to put in the ink cartridges
Procedure for replacing Cartridge
When FIne Cartridges run out of ink, replace them. using the following steps.
*Important
Handling Fine Cartridges
-Once the protective tape is removed, do not touch the electrical contacts or Print Head Nozzles on a FINE Cartridge. The printer may not print out properly if you touch it.
-To maintain optimal printing quality, we recommendthe use of specified Canon brand FINE Cartridges.
Refilling is not recommended.
-Once you remove a FINE Cartridge, replace it immediately. Do not leave the printer with the FINE Cartridge removed.
-Replace empty cartridges with new ones. If you insert FINE Cartidges that has been removed once, the printer may not print properly due to some reasons such as clogging of the nozzles. Furthermore, with such cartridges, tlhe Low ink warning may not be displayed properly.
-Once a FINE cartridge is installed, do not remove it from the printer and leave it out in the open. This will cause the FINE Cartridge to dry out., and the printer may not operate properly when it is reinstalled. To maintain optimal print quality, use a FINE Cartridge within 6 months of first use.
-Color ink may be consumed even when printing a black and white document or when black and white printing is specified.
Color ink is also consumed in Print Head Cleaning and Print Head Deep Cleaning, which may be necessary to maintain the printer's performance.
1) Make sure that the printer is on, and then open the Front Cover.
The FINE cartridge Holder move to the left.
Cautuion : * Do not hold the FINE cartridge Holder to stop or move it.
* Do not touch the metallic parts inside the printer.
Important : If the Front Cover is left open for more than 10 minutes, the FINE Cartridge Holder moves to the right. Close and reopen the Front Cover to return the holder to the left.
2) Remove the empty FINE Cartridge.
a) Push down the FINE Cartridge.
b) Remove the FINE Cartridge.
Important: - Handle FINE Cartridge carefully to avoid staining your clothes or surrounding area.
-Discard empty FINE Cartridges according to the local laws and regulations regarding disposal of consumables.
3) Prepare the replacement cartridge.
a) Unpack a new FINE Cartridge and remove the orange protective tape. gently.
Important : - Handle FINE cartridge carefully to avoid staining your clothes or surrounding area.
- do not re-attach the protective tape once you have removed. Discard it according to the locals laws and regulations regarding disposal of consumables.
-once the protective tape is removed , to not touch the electrical contacts or Print Head Nozzles on a fine cartridge. The printer may not print out properly if you touch it.
-Be careful not to stain your clothes and hands with the ink on the removed protective tape/
4) Install the FINE Cartridges.
a) Insert a new FINE Cartridge all the way into the appropriate slot. The Black FINE Cartridge should be installed into the left slot and the Color FINE Cartrige should be into the right slot.
b) Push up the FINE Cartridges until it clicks into the place.
Important : The printer cannot be used unless both the FINE Cartridges are installed.
5) Close the Front Cover.
Hope this helps. Please rate my response.
Thanks,
Have a good day.
Nov 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Print cartridges missing or not detected
Are they new cartridges?
If so, have you removed the clear plastic protection strips from the cartridge heads?
Sep 15, 2009 | HP Photosmart C4280 Aio Printer
I want to chgange the black ink cartridge
Go to:
Canon MP620 Support
Select the "Support & Service" tab if it is not already showing.
Type insert ink tank in the space to "Please enter your question" block.
"How do I replace or insert an ink tank?" should be the first result showing.
Click on that link and it will open up detailed instructions with pictures on replaing the ink.
Thanks for using Fixya.
May 08, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Dial says to remove cartridges and check. Have replaced cartridge
After cleaning cartridges and replacing refilled black ink, I removed blck ink and replaced with HP 58 photo ink. this aborted the "check cartridges freeze". I still cannot align cartridges after removing #58 and replacing with new HP 57. the operation starts but will not complete.
Any suggestions on how to align cartridges?
dunbarj730
May 02, 2009 | HP PSC 2210 All-In-One InkJet Printer
Out of ink
In case you have not already found a solution....
Go to:
MP620 Support
Click on that link and it will open up detailed instructions with pictures on replacing the ink.
Apr 27, 2009 | Canon PIXMA MP620 All-In-One InkJet...
DETAILED INSTRUCTIONS - Follow this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00442122&lc=en&cc=us&dlc=en&product=441125&lang=en
You MUST do all with the printer ON..
Nov 09, 2007 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5510 All-In-One Thermal Printer Logo
367 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
