Question about Canon PIXMA MP130 All-In-One InkJet Printer
LCD shows waste Ink absorber is almost full - manual says contact supplier
  • Canon Master
  • 525 Answers
To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
OR
turn on the printer press menu
press scan, copy, scan to enter service mode
use> to get to nvram
set ABS-M level to 0
Set ABS-P level to 0
Press stop to exit......Done.
I hope this help!
Posted on Jan 15, 2015
    President:
  • 2,306 Answers
Yes, you need a Canon repair shop to replace the ink absorbers, and reset the absorber count in machine diagnostics.
Posted on Jul 20, 2009
Ink absober is full
Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during Print Head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible
Jan 11, 2011 | Casio Office Equipment & Supplies
What is e 27 and e 8??
Those two are error codes, and they mean the following:
E8 - The waste ink absorber is almost full. Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and machine maintenance.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations, etc.
E27 - Manual does not specify what this means, but tells you what you should do: Turn the machine off, and remove the power plug from the outlet. About ten minutes later, plug it in again, and turn the machine on. If the problem is not resolved, the machine may require servicing. Please contact your local Service Center.
You can read more about the error codes on Canon website.
Dec 02, 2010 | Canon PIXMA MP150 All-In-One InkJet...
"ink absorber is almost full, contact service center" - what does this mean?
Inkjet printer has waste ink absorber inside, sponge alike. The function of waste ink absorber is to localize and keep waste ink safe inside the printer and does not harm the electrical parts.
Waste ink is produced from print head cleaning process and borderless printing. When capacity of the ink absorber raise to about 90% then warning message appears.
You need to bring your printer to the nearest service center to get waste ink absorber replaced.
Source:
Printer Clinic: Printer Tips,tricks,troubleshooting
E-manualshop: Online source of service manual
Aug 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
How to solve the problem of "Waste ink absorber is full", then show "check printer" & "5800" after continuing to use it for Canon MP150 Printer?
Use this method with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full for Mp170
firstly download MPTOOL
Download here
Download manual guide how to use MPtool
download here
OK hope this can help
Jul 12, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Ink waste absorber is nearly full. What do I do?
You need to reset it.
E3-3 = Paper jam
E4 = No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
You need Mptool to reset your mp170
download mptool here
Manual guide to use mptool
download manual guide here
Jul 09, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Waste Ink absorber is full.
this msg show that you will need to reset your printer waste ink counter and replace the waste ink pad.. you can try to reset it with a resetter software here.
http://www.fix-printer.moon4ever.com/?cat=5
May 28, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Printer won't print. Says to contact service
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 10, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Ink absorber pad is full
You need to replace the waste ink absorber and then reset the counter. These can be obtained from some suppliers of ink and spares etc, otherwise you will need to contact Brother in your country or take the unit to a service engineer.
Generally when these errors occur the waste ink absorber needs replacing, if not your images will start to degrade in quality and you will start to see ink splays / splodges appearing as well as random spots and ink patches. In the mean time press RESUME /CANCEL to continue printing.
Oct 02, 2009 | Brother MFC-5440CN All-In-One InkJet...
Printer says ''waste Ink absorber is full'' see service center
This is what the manual says: Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. Press [OK] to cancel the error so that you can continue printing. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
Canon recommends to contact a Canon service representative as soon as possible.
Nov 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
110 people viewed this question
old marine
old marine
