Question about Nokia N80 Cellular Phone
My n80 doesn't appear on my computer
I'VE got a nokia n80ie with v5.071.9.0.2 firmware, i installed pc suite and conected the phone with its usb cable ca-53 then there were some options to choose from on the phones screen i choose pc suite ,but my computer doesn't reponde,that is it didn't appear on my computer,i tried it with other computers but no luck so i tried the cable with another n80 and it worked but i own didn't.
i need help please
  • dannisisco Jul 19, 2009
    how can i check the mob pin or repair it
  • 83 Answers
There is a problem in yur mob pin wher yu conec the data cable .. please chec tat nd repair tat if yu have 2.. den yur phon ll connec on ..
Posted on Jul 19, 2009
  • maveriksasha Jul 25, 2009
    try another cable to yur mob if tat works den the fault is in yur pin. yu ll ve to buy a new pin in the store if yu can fix or else give it in a servic shop
How to reinstall phone software by computer
On your computer install Nokia PC Suite and run it. Fully recharge the phone battery. Connect to the computer thru USB cable. In PC Suite backup the data of the phone. remove the SIM and the memory card. Now update the firmware. Follow the instructions, word to word. After some time you will be told that the firmware has been updated. Cheers.
Oct 30, 2013 | Nokia 5250 Cell Phone
Tip
Nokia Firmware Updates
Hello, this is a tutorial explaining which steps you should follow in order to perform a firmware update or "Flash" on you mobile phone.<br /><br />What you will need to do this Procedure:<br /><br /> <ul> <li>USB data cable</li> <li>Nokia PC Suit</li> <li>Nokia Software updater</li></ul>In this tip the link for both PC suit and Updater will be provider for download.<br /><br /><img src="lock123.jpg" /><br /><br /><span>Step 1:</span><br /><br />You will need to <span>backup</span> all the data on your phone before you start doing anything else. You can either do the backup by following either the steps below:<br /><br /> <ul> <li>If you have a memory card in your phone, you can do the following: Tools&gt;Memory select options&gt;Backup phone memory. Once the backup is complete, remove the memory card from the phone.</li> <li>You will also be able to backup your phone using Nokia PC Suit. Once you have installed it, you will need to connect your Phone to your computer using the USB data cable. Once the phone and the computer is connected, you will have an option to backup the phone data.<br /></li></ul>At the links below, you will be able to download Nokia PC Suit and Nokia Software Updater.<br /><br /><a href="http://europe.nokia.com/support/download-software/nokia-pc-suite/download">Nokia PC Suit</a><br /><a href="http://europe.nokia.com/support/download-software/device-software-update">Nokia Software Updater</a> (To download the correct version for your phone, you will need top select your phone model)<br /><br /><br style="text-decoration: underline;" /><span>Step 2:</span><br style="font-weight: bold;" /><br />Before you start the actual firmware update, you will need to charge your phone, to ensure that the phone will not disconnect during the updating process. If the battery does not have the sufficient charge, the process will not start.<br /><br /><br /><span>Step 3:</span><br /><br />Since Nokia PC suite is already installed, you will now need to install Nokia Software Updater. Once the install is done, you might need to check your Firewall settings to ensure that there will be no data blocked or filtered during this process. Click <a href="http://www.microsoft.com/windowsxp/using/networking/security/winfirewall.mspx">HERE </a>to see how to set firewall settings.<br /><br /><br /><span>Step 4:</span><br /><br />From now on it's really simple, just follow the guide and you'll be fine. The whole updating process takes several minutes to complete, don't try to cancel it in the middle in any case, your risk damaging your phone. You will need your USB cable in this step.<br /><br /><img src="lock123_0.jpg" /><br /><br /><span>Step 5:</span><br /><br />Lastly you will need to restore the backed up data once the update is compete. Again, this can be done in two<br /><br /> <ul> <li>if you used a memory card for backup then you simply go to the <i>Tools</i> - <i>Memory</i> select <i>Options</i> - <i>Restore from card</i>; if you used Nokia PC Suite you have to connect your phone to the pc via <span>USB</span> cable, select Backup and Restore</li></ul>And then you are done.<br /><br />I really hope this can be of help. Please feel free to share your thought and advise.<br /><br />Kind regards<br />Lock123<br /><br /><br />
on Dec 10, 2010 | Cell Phones
Block my securite code
Update your firmware using PC Suite.
Tools needed:
Usb cable
Computer
Instruction:
1. Download and install a compatible PC Suite for your mobile phone into your computer. You can get it here: NOKIA PC SUITE
2. Insert usb cable to the computer and insert the other side to your mobile phone (must be powered on)
3. Your phone will be detected by the computer and installs the drivers needed and wait till its finish.
4. Open the PC suite and Look for the k4r70.gificon and click it.
5. Wait until its finish updating the firmware of you mobile phone.
I hope this will help you. Good luck
May 30, 2011 | Nokia X3 Cell Phone
As soon as i go on to camera it says unexpected error occurred.restart phone.why?
Nigel,
It seems that the firmware of the phone has got corrupted. Do the following:
1. Fully charge the battery and connect to a computer via the USB cable.
2. Fire up the Nokia PC Suite.
3. From the PC Suite, backup the data.
4. From the PC Suite, update the firmware.
5. From the PC Suite, restore the data.
Live happily everafter.
Apr 03, 2011 | Nokia 5800 XpressMusic Smartphone
My mobile nokia 6500 my mobile conect to pc and
try to reinstall pc suite before installing first remove the installed suite check for ur data cable verify ur usb ports
Jul 13, 2010 | Nokia 6500 Slide Cellular Phone
The phone freeze if sending sms
probably software. go to nokia.com and download latest software to your n80 by using pc suite and your computer cable
Oct 17, 2009 | Nokia N80 Cellular Phone
How can i connect my nokia 5130 c 2 to my pc
Iam unable to conect my 5130c 2 to pc through data cable as the driver cd not supplied with the pack
Jun 22, 2009 | Nokia 5130 Cellular Phone
Contect service in nokia 3110c how can i solve i am mechenic
Install Nokia Pc Suite software on you PC and do not connect the USB connectivity cable before or during the Pc Suite installation. When the Nokia Pc Suite installation is finished, Nokia Pc Suite will automatically launch the Get Connected Wizard. The on screen instruction will guide you to connect the USB connectivity cable to your PC and to your Phone. The default connection setting will appear on your phone screen. Select Pc Suite.
Nokia Pc Suite will install the cable drivers. This installation may take a few moments and you may be asked to accept the multiple driver installation. Once your Nokia Pc Suite have been installed, you can connect to the internet using "One Touch Access"
Jun 18, 2009 | Nokia 3110 Cellular Phone
N80 not
firmware upgrade on your stock Nokia N80 and turn it into an N80ie!Because The Nokia cellular phone N80ie has VoIP/sip support which allows you to make WLAN phone calls, better WLAN support, new internet applications and some bug fixes.
Sep 15, 2008 | Cell Phones
Nokia 6070
6070 support ca-42, so what exactly u mean, it doesnt recognise your phone (restart phone once and plug it back to pc), or it doesnt detect modem (you need to manually add nokia 6020 cable modem, there are no 6070 modem drivers for ca-42) ??
Feb 22, 2008 | Nokia 6070 Cellular Phone
Cell Phones Logo
62 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
