Question about 10 10 Computer Network adapter Cable (MJ25M-8F)
F1 error when i start my computer .it give me error(F1 to continue and F2 to enter setup) i want to remove this problem
  • 1,511 Answers
What else it states;
There will be some detection details, that this and that device have been found on this/that location.
Or there is some other message.
Don't hesitate to reply.
Regards.
Posted on Jul 19, 2009
Hello, I went into my bios settings and did something wrong now when I start up my computer it takes me to the mi bios megatrend screen at the bottom of the screen says driver bad press f2 to resume f1...
go back into the BIOS by pressing F12 and look for the set BIOS to default values or something along those line. save those settings and reboot..
Please give feedback...
Dec 18, 2012 | Lenovo Computers & Internet
I need to press F1 when i am starting the machine
There should be an error that comes up, this error will tell you what is at issue. For example: the time is incorrect, press F1 to continue or F2 to enter setup.
Press F2 to enter set up and correct whatever the error is. Then press F10 to save and exit.
With out listing the error associated with your issue, I can only give you this general information.
Feb 10, 2012 | E-Machines Computers & Internet
When I startup my pc I have to press F1 before it starts . I am running windows xp home
This has nothing to do with windows, but is a cmos or bios issue. There should be an error something like, Time incorrect press F1 to continue or F2 to enter setup. Check the error and then press the correct key to enter setup. If the issue is the time, fix the time and date in set up. Most other issues will clear when you exit and save set up.
If you would like more information, please provide the exact wording of the error that you are pressing F1 to continue from.
Dec 14, 2011 | Microsoft Windows XP Home Edition
Start-up and shut down problems, When starting up it says, press f1 to continue, f2 to run set-up.... F1 works but I am getting tired of doing this. Now when the computer starts, it stops at...
Hi names Rui,
For your problem the computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this may be caused by any of the below reasons.
  1. New hardware has been recently installed.
  2. Error or confliction with settings in CMOS.
  3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS. Enter CMOS setup and save the settings and exit. If you continue to get errors continue to the next step.
If no new hardware has been added or you continue to get this prompt verify no error or conflictions exist in CMOS. Press the key to enter setup and verify that all settings are correct.
If your time and date are not set correctly, your battery is more than likely bad. Try setting the correct time and date, save the settings and then reboot. If after turning off the computer the time and date get reset again replace the battery.
If the time and date are correct and everything else appears to be correct try resetting the CMOS values to the defaults.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, your CMOS battery is bad. We recommended that the CMOS battery be replaced.
hope this will help you.
Jul 20, 2011 | Dell Dimension 2400 PC Desktop
Hi, When I try to start my Dimemsion 5150C in Windows XP computer, I received one of the following error messages "Floppy diskette seek failure Strike the F1 key to continue, F2 to run the setup...
The "floppy" disk-drive (3.5-inch diskette) on your computer is broken.
Press F1 to ignore the error, and to boot from your C: drive.
Or, press F2 to enter BIOS SETUP, and then navigate through those "setup" screens to tell the computer to "disable floppy seek", or change the setting from "3.5 1.44Mb drive" to "none".
Or, take the computer to a technician, and buy a replacement disk-drive, and get it installed.
Sep 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Strike F1 key to continue, F2 to run the setup utility
Please let me know what is the make and the model of the pc that you are using.. Also, go to the bios, under boot menu, make sure that you have hard drive as the first boot option.. For further queries please get in touch..
May 28, 2009 | Computers & Internet
MY LAPTOP(hp compaq presario v2000)BEEPS TWICE AND DISPLAYS PRESS F1 TO RESUME OR F2 TO SETUP!pls help
Hi, and welcome to FixYa
The computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this issue can be caused by any of the below possibilities.
Solution:
If no new hardware has been added to the computer or the new hardware has been removed and you continue to receive the error, it is likely that there is an error or confliction with the CMOS. Press the key requested to enter setup and verify that all settings are correct. If everything appears to be correct try resetting the CMOS values to the defaults and/or Reset Configuration Data. Additional information about how to do this can be found on document CH000976.
If all settings appear to be correct, save changes and exit CMOS setup. If the error continues to appear, enter setup again and restore all CMOS values to default.
· See our CMOS page for additional help and information with the CMOS.
· Additional information about getting into the CMOS / BIOS setup can be found on document CH000192.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, it is also possible that the CMOS battery may be bad or failing. Generally; when this occurs, the computer is not holding the time or date correctly. If this is occurring it is recommended that the CMOS battery be replaced.
regards
/Teis the Wiz - -> Vote "FixYa" :-)
Dec 05, 2008 | Computers & Internet
Problem when i start my computer have a choice F1 and F2
just insert the xp cd and choose repair in it .......it will remove the error message
Jun 20, 2008 | 10 10 Computer Network adapter Cable...
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
10 10 Computer Network adapter Cable (MJ25M-8F) Logo
470 people viewed this question
Top 10 10 Computer Computers & Internet Experts
Reg Varney
Reg Varney
Level 1 Expert
Tony
Are you a 10 10 Computer Computer and Internet Expert? Answer questions, earn points and help others
