MY COMPUTER IS HP 500B MT AND IS NOT ACCEPTING PASSWORD WHEN AM CONNECTED TO NETWORK UNTIL I DISCONNECT
What OS/ windows 10 ,w7, vista, XP, ?
local pw ?
or Microsoft online pw.?
here they all are:
if confused?, post photo of screen that fail.
or?
SOURCE: I need the network key code in order to access my wireless router
http://192.168.1.1 and press Enter. A logon window appears
like the one shown on the next page.
The Logon screen:
User name: leave blank.
Password: enter the default password admin in all lowercase
letters. (Later on, we recommend changing the default to your
own password for added security using the Password tab of the
following web-based utility.)
Click OK. The Primary Setup screen appears as shown in the
next step.
Go to the security tab. You should see your key there.
Here is the user guide.
http://www.la.viewsonic.com/pdf/userguides/wr100-1_ug_eng.pdf
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: flashing wifi symbol on netgear wireless router. iphone help
Hi
I will try to help you out with this....
Might be you tried to cinnect with the network many time thats why its keep on disconnecting,
you can delecte all the netwoks that you have in you 3G Iphone and try to connect fresh, if its still give you the same error then you need to change the channel on the router if still it wont connect I suggest you to change tehw ireless settings on you router and reconnect all the computer and you Iphone again with the new network...
Steps are below before you change any settings on teh router i would like to inform you that you will loss your wireless connection till you reconfigure and reconnect you computer with the new network again........
open the internet explorer on your wired computer
type in 192.168.1.1or you can type http://routerlogin.com
, it will prompt you for user name and password, the user name will be 'admin' and password will be 'password', make sure you type it in small case
click on the wireless settings under the heading of setup
check out another screen shot below :
a. Change Name SSID : name of your network that you want to have
b. CHANNEL : Change to 11 and if uts 11 change it to 06
c. Mode : change to G&b
d. Sceurity : Select WEP
e. Key1 ; type any 10 digit number or you can type 1020304050, as mention above as the password for your wireless network
you will able to see your wireless network name on your computer, simply select it and it will prompt you for password that will be your 10 digit number you punch in Key1
connect with it and you are ready to go with your wired and wireless connection
I hope above mention will resolve your concern.....
Thanks
Harmeet :)
SOURCE: We're trying to connect a windows vista laptop to
it is because of the ip address from the router. you should re-configure the router and allow to generate more ip addresses from the router.
SOURCE: Dlink DIR 615, network name changed, won't accept password
It appears your brother has changed your wireless router settings.
You can reset the Dlink back to the default settings by -
Power off the Dlink and press and hold the RESET button on the back of the Dlink and the power on the Dlink. Hold the RESET button for 5 secs. until the LEDs flash at the same time.
Connect a LAN cable from the computer to the Dlink. Open a browser and enter the Dlink's configuration URL
http://192.168.0.1
Default login = admin
PW = blank (just press Enter)
You can now change the admin password and set up a new passphrase (ie encryption)
For details on how to secure your wireless from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
SOURCE: How do I add a password?
the password for 2wire if you got it from your ISP is most likely on the bottum of the unit on a sticker
