Question about LG Vu CU920 Cellular Phone
How to lock LG vU phone?
Hey i have a quetion bout the lg vu HANDSET lock thingi... u said the current password iz 0000 but it does not work on mind
it said invild password what should i do hunn
Please help i locked my lg vu
With a password ? if not theres an unlock button on the right side of the phone
Oct 25, 2009 | LG Vu CU920 Cellular Phone
Can ou please provide the code to unlock my LG Vu? Thanks,
After powering on, go to the security setting menu to lock the phone. You must input the correct password when locking and unlocking the phone. This function prevents others from locking and unlocking your phone.
The default password is 0000; to reset the password, go to:
Settings->Security->Change PWD
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Oct 10, 2009 | LG Vu CU920 Cellular Phone
How do i reset my phone?
which phone you r using. did you put any passowrd for locking the phone. if no. then the default password for reseting the handset for LG is four zeros(0000).
Sep 12, 2009 | LG Vu CU920 Cellular Phone
How do i lock my lg vue so nobody can get into it without a code?
Go to the Tools menu, select More, select Security, select Lock Handset, then choose between when power on, when sim changed, immediately or off. Before you lock the phone just make sure you remember the factory preset security code 0000, or change it to another code that only you can remember, and write it down somewhere so you don't lose or forget it.
Jul 16, 2009 | LG Vu CU920 Cellular Phone
How do I lock my LG Vue so others can't get in it without the code?
Go to phone tools>Security>Lock Handset and choose which option you want. Just remember to either use the standard LG security code 0000, or make one up yourslef, but write it down and keep somewhere safe.
Jul 07, 2009 | LG Vu CU920 Cellular Phone
Bluetooth password mismatch?
Unless set by user otherwise, almost all Bluetooth passwords are 0000. Zeros
May 03, 2009 | LG Vu CU920 Cellular Phone
How to lock lg vu without nobody get it into mine????
Main Menu/Settings Tab/More/Security/Lock Handset/When Power On. Then go back to security/change codes/security code/current code is 0000/change code
Mar 05, 2009 | LG Vu CU920 Cellular Phone
How do I get security on my lg vu?
go to the menu then the setting menu then tap more and hit the security menu and a list should appear. at the bottom should change codes and tap that and then security code pin 1 and pin 2 should appear. jjust tap security code and enter the code you want it should set it to that code.
Dec 25, 2008 | LG Vu CU920 Cellular Phone
LG Vu CU920
i think you type the code in 0000 (zeroes) and there ya go. [: i went to att.com and typed in puk code and then it said type in 0000 so, hope that helped!
Oct 16, 2008 | LG Vu CU920 Cellular Phone
LG Vu CU920 Cellular Phone Logo
184 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
