Question about Garden
Yard Machine 11B504B352, idles high and then practically dies. Still mows ok.
  • 89 Answers
Try taking off your filter and look if your govenor spring is broke or come off the govenor is designed to always go to idle,its like tug of war which ever end is tighter it will win
Posted on Nov 04, 2009
Ryobi line trimmer plt3043a starts idles but dies when i attempt to increase speed
May I suggest checking along the fuel line and its attachments for a very minor air leak. The minute it sucks air it will stop. Check any rubber washers or O rings too.
Feb 02, 2015 | Ryobi Garden
Why wont my John Deere D130 will not stay running
You know the old adage, Keep it simple, lol.
I was mowing along on my LA145, which had about 200 hours on it, and it slowed down then died. Before it died, it was acting like it was losing power. It felt like it was only firing on one cylinder. I waited a bit and it restarted after a lot of cranking. I made a couple mowing passes, and then the same thing happened.
Because I have mowed commercially for many years, I know my equipment inside and out. This mower was in top running condition and should not have been acting this way. There were no engine misses, no backfires and it was not normally hard to start. I knew the carburetor was clean, the coils were good, and the plugs were new. The fuel filter was recently changed. I got off, lifted the hood and gave a general inspection of the engine compartment. I noticed the fuel filter was nearly empty. I pulled the hose off the tank side of the filter and saw there was no flow.
The gas should gravity flow from the tank to the filter, if the tank has a good supply of fuel. Not that I recommend this practice, but I have no problem with doing it myself....I wiped the hose off and blew air back into the fuel tank. It helps to take the gas tank lid off first. After I got a good flow of air going back into the tank (it required several lungs full of air, you can hear the bubbles) the fuel began to gravity flow back through the hose at a decent clip. This fixed the problem. There is likely silt build up in the tank and it settles at the output port blocking the flow of fuel.
The problem repeated itself several times last summer. Back at the shop, I used compressed air to blow the line clear. The problem has not shown up in quite some time.
Aug 29, 2014 | John Deere D130 22HP V-Twin Foot Pedal...
Engine growing black smoke
Usually this is a sign of oil being in the ignition chamber. Check the oil level, if too high drain and refill to proper level. Also if you have hills or slopes in your yard make sure that you are mowing up and down not across. If you must mow across the slope make sure to do it with the oil to the downward side. Caution if you do this too often the engine will be deprived of oil all together and seize up.
Apr 18, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
I have a 2001 Mazda Tribute and yesterday I started it and when I let it idal or I'm stopped it acts like it's going to die but when I'm driving it seems fine, Would anyone know what would be...
If this is idleing with the ac on then the idle up speed may require adjustment. not a good practice to leave any vehicle idling with ac on unless idle up control is set high enough to compensate for this practice. can be annoying to drive if set up too high
Dec 10, 2012 | Cars & Trucks
My mower will not keep a charge very long. It use to keep a charge long enough to mow my front yard and back yard. Now I can hardly keep a charge long enough to mow half the front yard. It is 3 years...
Is this a battery powered mower?
If so, it sounds like the battery is dying. Batteries do have to be replaced, but 3 years seems like a short life. Ask your dealer before buying another.
Gary
Jul 05, 2011 | Ultra Garden
I have a 4hp yard machine model # 11b504b352 that hunts for rpm. Surges constantly. Any expert sugestions? What's going on in the carb.?
Most likely, you will have to replace your carb. diaphragm. Its between the carb. and the gas tank. It collapsed. So the gas is not going from the tank to the carb. as it should be. It will get some gas, but not enough to run right. (Its starving for gas)
Apr 15, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
John Deere 105a series
Take the muffler off and clean the gunk out of the hole going to the motor and i would soak the muffler in some carb cleaner overnight, let it dry and shake out the gunk. Put it back on and i'm certain it'll fix the problem.
Jul 25, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
234 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
