Question about ViewSonic VA720 17" LCD Flat Panel Monitor
Green Pixles when TV should be displaying black or dark images
My 42" Polaroid LCD Television that I bought in 2008 is displaying green pixles when they should be black. It does this for both the TV connection and when watching movies on the DVD player. Both of these are connected thru separate HDMI cables. It does not do it all the time, sometimes the TV needs to be on for a couple of minutes before it starts. Does anyone have any idea what might be wrong?
SOURCE: No display, green light on ViewSonic VP201b 20.1 LCD
I have two broken VP201 monitors with different symptoms. One was black screen green light - like yours. The other was purple speks flying all over the screen., purple tint.
I swapped the power supplies and display boards, both monitors had original problems. I swap the inverters and the monitor which was black screen now appeared to work okay - but slightly pink and the monitor which was purple speks is now black screen.
I would therefore assume that both my inverters gone, one being on it's way out. You probably have the black-screen case.
Posted on Aug 27, 2008
  • 159 Answers
SOURCE: Viewsonic VA702B
Monitor going black after a few seconds can be caused by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Posted on Oct 05, 2008
  • 7 Answers
SOURCE: lcd tv with wrong color on one pixel
LCD screens occasionally have what are called "Stuck pixels". There is a tutorial in wikihow which might help you out here:
Try that and see if it helps. Stuck pixels are actually a slighty common problem.
Posted on Jan 02, 2009
  • 50 Answers
SOURCE: ViewSonic LCD (VA1912w) Went Blank
You have to change the capacitor....Better u replace your LCD monitor...
Posted on Feb 18, 2009
  • 1188 Answers
SOURCE: Viewsonic VP930b color problem - Red tint
Go to the setup menu on the LCD panel by pressing button 1 on the front. See if there is an option to reset the lcd to factory settings. Reset it and report if it helps not.
Posted on Jul 29, 2009
My polaroid tv just started to flash a black screen with red and green vertical lines on it. It flashes on and off. Is the tv fixable or am I better off buying a new tv.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 23, 2014 | Polaroid FLM-4201 42 in. LCD Television
Purple Pixles When Samsung LNT4661F TV Start Up
I also have this same problem, which seems to be occurring more and more lately. Any solutions?
Mar 24, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Green outline/shadow on dark images or backgrounds
LVDS Cable is corroded - This is the cable the provides video from the TV Video Process board to the LCD Panels Timing Control Board.
Honestly, if you can take the TV back do so. If not, Service it using the manufacturer warranty
Jun 24, 2009 | Vizio Televison & Video
Pink and green outline on people and text
How old is the TV?After a certain number of years the pixles will degrade and around key areas they will turn a rough color.Pink green orange blue,you name it.Otherwise It could be that it got damaged in a shipping process and then there wouldnt be much you could do except take it into the retailer where you purchased it and ask if the problem is fixable.
May 07, 2009 | Sony KLV-S26A10 26 in. HD-Ready LCD...
My Polaroid LCD tv picture is green!
if all r green meanns there is no use to watch the tv so for our support all should be in natural colours
Mar 14, 2009 | Polaroid FLM-2632 Television
Black line down middle
this sounds like the display has gone faulty if the line never moves and is always there im afraid that the display has lost its pixles the only thing you can do is change the display i would advise to buy a new set possibly a panasonic or samsung.
Mar 10, 2009 | Philips 32PFL5332D 32 in. LCD Television
My polaroid has sound and picture problems
This is a well-known problem with many Polaroid FP displays. Eventually, the picture will simply go black, rendering the TV useless. The solution is a new control board, ~$400.
Feb 27, 2009 | Polaroid FLM-4201 42 in. LCD Television
PDP-V401 Plasma
I am amazed it lasted that long. It could well be in the panel and would be expensive to fix. I think you would be better served at checking out a 40-42" LCD replacement. They've come a long way since yours was made.
Jan 06, 2007 | Pioneer PureVision PDP-V401 40 in. Plasma...
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
71 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
