Question about John Deere Garden
GX75 riding lawnmower 9HP trouble starting, runs for a few seconds when I put gas on spark plug then stalls getting strong spark . acts like motor is out of time or something could valve be sticking is there a remedy for this problem! Thanks from lancaster ny
2 Suggested Answers
rwvanlue
  • 486 Answers
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
Posted on Nov 08, 2009
What type of oil does it use? John Deere RX75
some use straight 30 some 5-30 others 10-30 jd has their own oil as well the following chart showes the type
May 12, 2016 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
My craftsman gasoline lawnmower will start when primed run less than a minute then cut out . how do I determine the problem...then fix it
Have you checked the fuel supply first. Its possible your jet valve may be plugged or dirt in the fuel bowl. One quick way of checking this is take the spark plug out and put a little shot of gas in the spark plug hole then reinstall the spark plug and put wire back in place and try to start engine. If it start and revs up for a few seconds till the gas is burnt up then stalls it is pretty certain its a dirty fuel jet or dirt in the fuel bowl. This quite often a real cheap fix .
Jul 20, 2015 | Craftsman Garden
GX75 won't key start
you will have to follow the line from the switch through the safety switches and see where the break is.use a continuity tester you will find the fault
Aug 04, 2013 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John deer gx75. 9hp kawasaki. Turns over but won't
check and clean air cleaner. Check main jet for blockage.
Jun 23, 2013 | Garden
My riding mower will not start,it turns over
remove your breather pour just a little gas directly into the bowl of the carburator less than a once then try to start it. if it starts and runs for a few seconds then dies then its not getting gas and most likely a problem with the carbuator. if it doesn't start at all by doing this then its not putting fire to the spark plug there are many problems for this so after you try this and your problem is in the firing of the spark plug let me know and i will give you a few things to check for this problem.
Apr 27, 2012 | Garden
Lawnmower working find put choke on engine ran rough and stalled and would not restart. I tried every trouble shooting method which includes air filter, spark plug , fuel, electric connections, fuel filter...
sounds as though the carburetor is not working, pour some gas into the carburetor and see if it runs, if it runs and quits then the fuel is not getting to the carburetor or the carburetor needs to be cleaned and rebuilt. Hope this helps Tim
Jun 12, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Have sx75 and starts fine. After about twenty min it starts to cut out and die. Almost like it is vapor locking. Wrapped fuel line with aluminum but didn?t help. Installed new plug and cleaned all...
Try this.
When the machine begins to stall, immediately loosen the gas cap.
If this works, drill out the vent holes on the cap.
Please post back to let me know if this works.
Gary
Mar 08, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Garden Logo
198 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
