Question about Monarch 9855 Thermal Printer
Invalid Command Hello, I am trying to connect a label software application, "label Matrix 5.0" to a Monarch (Paxar) 9855 Thermal printer and i keep getting the error "Invalid Command Line 01 Code 287"? The printer is set up on a AS400 from Manhattan version 2004r2. I retrieved the IP address from the system and set it up using the Printer set up. The only thing i can think of the problem being is that when i do set up the printer using the IP address, there is no Paxar 9855 driver the closest i could find was a 9830-CL. Either way the message is getting sent to the printer or i would not be receiving the Invalid Command error. If you could assist on this issue i would appreciate it.Thanks in advance,Jason
  • 113 Answers
Your 287 error has to do with an incorrect setting for printhead width, and in the control language that your software is sending to the printer, they either have something other than 0, or there is an invalid character like a carriage return or line feed being sent to the printer.
This is a difficult one to trace since the software sends the code and you cannot necessarily change what is being sent.
Please note that the software that you really should be using is PC Mate Plus, as this is a specialized printer for Paxar supplies called Care Labels. You may be able to cheat if your software allows you to select 300DPI print heads. If not, you'll need the software I suggest.
If you do not have this software, please contact Paxar (now Avery Dennison) at 1-800-543-6650 and ask to be connected to someone in technical support or if the customer service rep can offer you a link to a website for software download, or purchase.
Posted on Feb 06, 2008
Errors 001 to 405 and 429 to 435 are data errors. This type of error indicates that incorrect data was sent to the printer, and the printer is ignoring it. Your System Administrator should correct the packet and send it back to the printer. Error 411 is baud rate mismatch. Here's the manual:
Jun 17, 2014 | Monarch Paxar? 9855 Label Printer
Invalid command, line 01 code 400
Mornach 9825 printer is error "Invalid Command! Line 01 Code 400 ".How issue this error.
Apr 16, 2011 | Monarch Paxar 9855 Printer
How do you change the printer head
Here is the link to the 9855 operator's manual. Page 101 of 132 shows you how to replace the printhead. It's a pretty simple procedure.
Dec 13, 2010 | Paxar Monarch 9825 Thermal Label Printer
Where can I buy Paxar Monarch 9855, 9835, 9800 printer spares from
To buy a Paxar Monarch 9855 you can buy it to the nearest appliance center or any electronic center in your place. If you can not see that in your place you can buy it through online. Visit and inquire it in ebay or amazon website. or
Thanks and good luck!
Dec 23, 2009 | Paxar Monarch 9855 Thermal Printer
We have a 9855 Monarch barcode Printer. We are
If the printer display just shows Ready, but doesn't print, there could be a few things wrong.
1 - no data is going to the printer
2 - data is going to the printer, but it is not the printer's native language
3 - cable connectivity issues
4 - wrong cable is being used
5 - if wireless, data is not going to the correct IP
If using a 3rd party application, make sure that you've chosen the correct Monarch printer, as well as printing to the correct port. Sometime people print to LPT instead of Serial, as an example.
If using 3rd party drivers, make sure of the same thing.
To see if the printer actually works, press both of the arrows on the display, at the same time, after the printer is at the ready screen. As long as have the printer configured correctly (ribbon, supply type, etc.), the printer should print out a couple of labels.
Oct 26, 2009 | Paxar Monarch 9855 Barcode Label Printers...
Monarch Paxar 9855 Printing Errors
can you try a serial connection, what type of operating system are you using?
Aug 07, 2009 | Monarch 9855 Thermal Printer
Paxar 9855 print error
You have a format problem. Something isn't correct in your mpcl code.
Error 400 - "The character immediately following { is invalid or not an ASCII character."
Jun 01, 2009 | Monarch 9855 Thermal Printer
9855 ribbon take up reel not working
When you're sending data to the printer you're sending a command that is telling the printer you're NOT using a ribbon. When the printer receives the data it's shutting off the ribbon. Check your software.
You should be set for THERMAL TRANSFER.(RIBBON)
Feb 04, 2009 | Paxar Monarch 9855 Thermal Printer
Paxar 9855
If you have not found an answer to your issue, you may wish to call their tech support at
Labels are supposed to come off the liner, but if you have the supplies or ribbon loaded incorrectly, or if you have adhesive coming in contact with the ribbon before the media indexes to the next label, I can see where the ribbon can get attached to the labels.
You shouldn't have any slack in your ribbon when the printer prints, and if you do, you may need to make minor adjustments to take up that slack.
As for a heating adjustment, I'm not sure what you mean, but there is an adjustment to increase the printhead temperature, but that is only to increase the contrast on your labels, and should have zero effect on your reported issue.
Contact's tech support line if you find that the data in this response isn't able to guide you to the culprit.
Feb 13, 2008 | Paxar Monarch 9855 Thermal Printer
Monarch 9855 Thermal Printer Logo
373 people viewed this question
Top Monarch Office Equipment & Supplies Experts
David Payne
David Payne
Are you a Monarch Office Equipment and Supply Expert? Answer questions, earn points and help others
